Question about Philips 42PFL3603D 42 in. LCD TV
Where can I buy an IR sensor board for a 42" Philips model # 42pfl3603d? I can only seem to find them for model #'s 42pfl3603d/27 or 42pfl3603d/F7 but not for mine. Will parts from either of these models work for me? I hear it's an easy part to replace and don't want to pay hundreds for someone else to do it for me. Thanks so much!
  • bprican14 Sep 16, 2010
    It seems the back of my TV tells me what my box didn't... I have a 42pfl3603d/F7 but the few places I've found that sells the ir sensor board says they're out of stock. Can anyone find one anywhere for me and post the link? Thanks.
  • 4 Answers
SHORT CAPACITOR ON IR BOARD NEAR CONECTOR FROM KEY BOARD ITS THE PROBLEM FOR REMOTE COMANDER NOT WORKING .
Posted on Jan 21, 2011
My TV Philips 42PFL3603D/F7, have same problem, this Philips tv is pure ****, same to all Philips products are scams.
Posted on Dec 01, 2010
I have a Philips 42" TV mod 42PFL3603D/27 serial;YA1C0824019426 Does not turn on any more the red light at the bottom of the set does not come on either
check for bulging capacitors on the power supply board. you will have to remove the back cover from the television set to get a good look at the power board. If you do notice swollen capacitors, desolder the bad ones out and solder new ones in.
Sep 19, 2016 | Philips 42PFL3603D/27 42 in. LCD TV
Turned on my Philips 42pfl3603d/f7 and you can see the images but everything is blue what part went bad and can I replace it my self
It sounds that the fault should be with its main digital board. To get more details, http://electronicshelponline.blogspot.com/ Pull up older posts. Try and determine whether you can repair it by yourself.
Nov 29, 2013 | Philips 42PFL3603D/27 42 in. LCD TV
Blue screen on Philips 42pfl3603d/f7
same result with all inputs? check all your input cables & connections
Remote sensor is bad on my Philips 42PFL3603D/F7 LCD TV. Can I fix it?
Yes just replace the IR sensor board very easy to do. You can get the repacement IR board from www.tvcircuitboards.com
Dec 13, 2012 | Televison & Video
Need to find out a part # for my philips 52PFL7403/f7 for the ir sensor
Join Date: Nov 2011 I have a Philips 47PFL3603D/F7 with the same problem. It was the IR sensor board causing the problem. You can search online to find the board, which almost everyone will most likely not have in stock, and cant be ordered. The part you need is this: 313926859181 IR Remote Sensor.
Models it will fit are as follows: Substitute Parts 313926859182
Known Models
MAGNAVOX 42MF438B/27
MAGNAVOX 42MF438B/F7
MAGNAVOX 52MF438B/27
MAGNAVOX 52MF438B/F7
PHILIPS 32PFL3403D/85
PHILIPS 42PFL3403D/27
PHILIPS 42PFL3403D/F7
PHILIPS 42PFL3603D/27
PHILIPS 42PFL3603D/F7
PHILIPS 47PFL3603D/27
PHILIPS 47PFL3603D/F7
PHILIPS 52PFL3603D/27
PHILIPS 52PFL3603D/F7
If you can find the board, great! A replacement board costs about $12.00. If you can't... we'll there is something you can try ; )
Either way, if you know it's the board, what's the harm in trying?
Remove the back from the TV. You can actually leave it on your stand to do this if you can spin it around to gain access to the back of it. Be sure to unplug everything first!!!
Looking at the back of the tv, the board will be located in the lower left side by the speaker. It will have 2 cables attached to it. Remove them, and take out the screw or two that holds it in place. There will be a plastic tab that keeps it in place also.
Take your fingernail and bend the tab back, and the board should come free. After that you should be holding the board in your hands. The side of the board with the connectors on it is the side you want to manipulate. There will be a tiny surface mounted capacitor beside one of the wire connection sockets. Take a utility knife and scrape it off/ you could use a soldering iron but it should come off very easy with a knife.
Plug it back in, and give it a try! If it works... great! If not, find a replacement board, and try that.
May 30, 2011 | Philips 52PFL7403D 52 in. LCD HDTV
My remote has stopped working. We have replaced the batteries with no luck because of this we cannot switch between sources My TV is a Philips 42" Model # 42PFL3603D/F7 Serial # VA180905005250
Hi:
The IR remote sensor in side of the television need replacing, this is the sensor that receives the commands from the remote and relays them to the microprocessor of the TV. Have the remote sensor replaced.
Mar 10, 2011 | Philips Televison & Video
My tv is actually a 42pfl3603d/f7 , had it for one year, the picture is green, but i can hear sound. what could be the problem?
Ur Tuner signal board is dead.Replaced this board will solved this problems.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish Tuner signal board for the replacement.
Mar 13, 2010 | Philips 42PFL3403D 42 in. LCD HDTV
Philips 42PFL3603D 42 in. LCD TV Logo
1,652 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
