Question about LG CHOCOLATE VX8500 Cellular Phone
My LG Chocolate Touch suddenly stopped recognizing my music files. The memory shows them to be there, but when I go to My Music, it tells me there are no songs. Downloaded a new file to it, but still the same problem.
SOURCE: saving songs on sd memory card
1. Put a micro SD card into your phone. (Make sure it's blank)
2. Format the card from your phone. To do this go into "Menu//Settings & Tools//Memory//Card Memory" then click on "Options" that should open the format screen. Enter your security code (usually the last four digits of your cell #) and format the card.
3. Exit all menu screens by pressing the "End" button and remove your card.
4. Insert your card back into your PC. It should recognize the card and open a "Removable Disk" window. (if not, manually open this window by clicking on "Start//My Computer//drive E: or F:" , they might vary depending on your computer set-up.
5. You should see a folder named "my_music". That's where you are going to drag your music files into.
6. DO NOT open any media player. Just find the location of your music FILES. Usually if you click on "Start//My Music" your music FILES will be stored there.
7. Simply drag and drop music FILES into the folder that I listed on #5. DO NOT drag an albulm. It won't work. Just the music file.
Posted on Feb 04, 2008
SOURCE: my mobile's music player wont recognize my mp3s
I had the same problem and found the solution on the following site!
http://www.lg-vu.com/index.php?topic=2660.0 Reading thru the blog you will find the best solution is to download the MP3 tag which there is a link for and untag the retag your MP3's and they will work. So easy but up to 6 hours or more to locate.
Scooter72908
Posted on Feb 04, 2009
SOURCE: LG KS360 Turns It's self Off!
I had the same problem, you will need it to be serviced. That fixed it by taking it back to who I brought it from, only problem is my phone is now really slow at opening menus. Have you encountered this? I dont want to take it back again unless i need to.
Hope it helps!
Posted on Mar 10, 2009
SOURCE: phone not reading music on LG enV from memory card....
i had the same problem with my original "the v" you may want to check the file type. If you have wma files, you should try converting them to mp3 or vice versa. research to see what file types your phone supports. I had to take mine into the verizon store to have them update the software on my phone to be able to play mp3 files.
Posted on May 21, 2009
rootbeer001
  • 352 Answers
SOURCE: LG vu music player wont show music in library
I personally do not have this phone, but I have done a search for you and found this website that might help:
Good luck.
Posted on Feb 08, 2010
My LG Chocolate touch vx8575 phone won't play sounds
It sounds like a failure in the earbud jack. Try plugging and unplugging a few times. If something got inside the jack, that could cause this issue. Shake the phone while you plug and unplug...
Jul 20, 2017 | LG VX8575 Cell Phone
I need to put music on my lg chocolate vx 8550 phone but i dont have the disc can i get some type of free software to put my music on my phone
if you have a memory card then you can get the adaptor you got with it and put it in your computer then drag and drop the music files from your pc to the folder in the memory card
Jan 05, 2010 | LG CHOCOLATE VX8500 Cellular Phone
It says i have music on the card but no show on my lg chocolate vx855olk
There is a small "lock" on the memory card that can slide from one side to another. Take out your card push the lock to the other end and then try accessing your music again.
May 26, 2009 | LG CHOCOLATE VX8500 Cellular Phone
LG Chocolate micro SD card
You need to format inside the phone. Go to Settings-Memory-Card Memory-Options-Format card. Do that, put it back in your computer, and put music (MP3's) into the My_Music folder.
Aug 14, 2008 | LG CHOCOLATE VX8500 Cellular Phone
Puting music on a chocolate phone
I think you can either format the sd card using the phone, or simply put four folders on your sd card with your computer. The folders are named
my_music
my_picture
my_sound
my_video
you just put the mp3s in the my_music folder. You will have problems with some files if they are right protected.
Mar 11, 2008 | LG CHOCOLATE VX8500 Cellular Phone
Music for my LG Chocolate
check how much memory is on the chip, if the memory chip is showing used memory then somethings wrong cuz it aint showing the songs. also when you were on media player did you drag the songs you wanted into the right coluumn and then sync. if you did then call for help or go to place of purchase
Feb 02, 2008 | LG CHOCOLATE VX8500 Cellular Phone
My LG Chocolate VX8550 wont recognize micro sd card
Here are the steps I took:
  1. Insert the micro sd card with the metal plates facing you (that took me a second). Don't worry about the little push you have to give.
  2. Go to the Settings & Tools option in the Menu.
  3. Select *. Memory
  4. Selct 3. Card Memory
  5. Select Options while the bar is on "1. Memory Usage". The only option available to me was 1. Format and select that.
  6. It will ask for the phone lock code-if you have never set it IT IS THE LAST 4 DIGITS OF YOUR TELEPHONE NUMBER.
  7. The phone will format the card and put the file folders on it.
  8. Use the adaptor USB reader or whatever you have to connect it to the computer. Copy songs to the my_music folder.
for mp3 as ringtones:
  1. You should select the part of the song you like, and can add effects with this:http://www.mptrim.com/
  2. To set it as a ringtone, send it as an attachments to you areacodeandyourphonenumber@vzwpix.com. It must be small to go through, around 30 seconds.
  3. You will get a text message, and select options. Select Save As Ringtone.
Jan 18, 2008 | LG CHOCOLATE VX8500 Cellular Phone
Saving music on my micro sd..
why cant i get my micro sd to show on my phone
Oct 26, 2007 | LG CHOCOLATE VX8500 Cellular Phone
LG CHOCOLATE VX8500 Cellular Phone Logo
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
