Question about Hotpoint First Edition FEW12 Front Load Washer
During spin cycle started making loud noise now drum feels loose
  • bazzahun Aug 08, 2008
    i have the same problem going to try replacing bearings
The large spider which connects to the drum not work repairing
Posted on Nov 14, 2009
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 24 Answers
I would say its definately the bearings. When you get it fixed its heaven. Listening to a silent machine!
Dont continue using the machine now the drum is so precarious or you will damage more parts and make it more expensive to repair.
All the best
sue
Posted on Aug 18, 2008
During spin cycle it makes a lot of noise could it be the bearings that have gone
Posted on Aug 08, 2008
My washer is making a loud noise during the spinner cycle. The drum is very loose.
Drum should be tight - noise you hear is the drum banging around all over the place as it spins.
Check the spindle and bearings where the drum is connected along with the tension on the belt that powers the drum.
Aug 29, 2015 | Washing Machines
The washer shakes uncontrollably during the spin cycle also a loud banging noise is heard during the spin cycle.....
If front load check the inner drum If it is loose at all you have a lot of problem . Very expensive.
Nov 17, 2010 | GE Washing Machines
During the spin cycle the washing machine becomes VERY noisy, sounds like its off-balance, but happens EVERY time, even with very small loads. The whole unit doesn't move when it happens, just extremely...
During the spin cycle the drum moves at a higher RPM and so the counter weight of the clothes within can make the drum rotate eccentric or out of sync.
So check if the belt is loose on the motor, checck if the spindle is tight with friction or the drum assembly suspension is out of alignment.
You must check the reason with the following points to confirm the drum spinning making noise. check point of noise , is this on hitting the sides , or from the motor, any foreign objects or the drum spindle. But you are the judge with a first view. Use good lighting to look out and confirm the fault.
Sep 16, 2010 | Frigidaire FEX831CS Top Load Stacked...
Washer making loud noise and wont spin
Check and see if the inner drum is loose and floppy.if it is, it's likely the bearings have collapsed, and require replacement...If the drum feels stiff and tight, it could be that something is jammed between the inner and outer drums. Both situations could be costly...Get quotes....Good luck...Nomess
May 22, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Loud clanking noise during spin cycle. Will not
If it is a front loader, then remove the rear panel, remove the belt, and soin drum by hand, if it feels rough, or is noisy and rumbling, then the main drum bearings have failed.
This is a major repair.
Feb 01, 2010 | Whirlpool LHW0050PQ Front Load Washer
Wfw8300sw01 - makes loud noise sounds during spin
The bearings have collapesd due to the seal going faulty. If bearings can be accessed to from the outside, it is possible you could do the repair. If big bearing and seal is accessed from the inside, suggest tech. do it as it gets dirty and a lot more complex.
Sep 20, 2009 | Washing Machines
Kenmore Front load washer model 3 970-c29042-00 The washer is making a loud noise and shakes like something is loose when the drum is turning..
I have a kenmore front load washer, model: 417 42042100
It makes loud noise and becomes louder during the spin cycle.
The drum is loose when I inspected through the front door.
My problem is how to open the cabinet and replace any broken parts.
Thanks.
Aug 04, 2008 | Kenmore 46462 Front Load Washer
Kenmore front load washer
My Kenmore front-load washer starts to make the huge noise. The noise happens during the wash cycle, but is mild. During the spin cycle, the noise becomes really loud. It looks like the drum is getting loose and hitting other part of the machine.
I checked the drum, and I can sway the drum easily with my hand. So it looks some supporting structure is broken. I don't know if it is easy to open the washer to check what has been broken.
May 20, 2008 | Kenmore 44072 Front Load Washer
During spin cycle started making loud noise now drum feels loose DURING SPIN CYCLE DRUM SOUNDS AS IF IT'S HITTING SIDE.. FEELS LOOSE WHEN I PUSH IT AROUND FRIGIDARE GLTF1040ASO
ckd your warranty papers sounds like rear drum support(spider) has broken will require new basket and rear drum half est cost 400-600 spider is not a separate part and rear bearing is probably damaged that too is not a separate part and require rear tub replacement
May 20, 2008 | Frigidaire GLTF1670A Front Load Washer
Noise during spin cycles
GE WPXH214ACC Washer drum makes loud noise when spinning sometimes. We've had it since 2005 & never had this happen before. Washer is level, must stop & redistribute clothes to correct. Just started happening now.
Oct 12, 2007 | Washing Machines
Hotpoint First Edition FEW12 Front Load Washer Logo
340 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
