VOSTRO 1510 TURNS ON THEN OFF WITHIN 5 SECONDS. nO FAN, HARD DRIVE OR ANY OTHER SOUNDS
  • 2,567 Answers
1. Take the battery out of the laptop & try to turn on the laptop using power adapter only. If the computer turns on, then the battery is defective & needs to be replaced.
2. Make sure the power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
3. Make sure the DC jack is not loose or broken. A loose DC jack will need to be re-soldered. A broken one will need to be replaced.
4. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work.
5. The power button could be bad.
6. The motherboard could be defective & needs to be replaced.
Posted on Sep 18, 2010
I am having issues with my laptop Dell Vostro 1510. Getting a black screen and white cursor in the upper left hand corner.
The error code indicates that the system is not able to access or detect any Hard Disk Drive.
If comfortable you can try the following:
1. Open your laptop following the below guide
2. Look for the Hard Disk Drive
3. Remove it from the system
4. Re-seat the Hard Disk drive
5. Re-start the system
If still the HDD is not detected I am afraid to say that the Drive is gone bad and needs a replacement.
Kindly feel free for any further clarification or assistance.
How to take apart Dell Vostro 1510 notebook
Sep 13, 2012 | Dell Vostro 1510 Laptop
Vostro 1510 screen black and lock #9 blinking blue
Try reseating RAM. The flashing lights indicates a fault on the motherboard. I read online where this fixed many laptops but not all and not mine. I suspect the motherboard is dead in my case. May be same for you but first try reseating RAM, hard drive and maybe the processor.
Jim
Oct 07, 2011 | Dell Vostro 1510 Laptop
When I boot up from the hard drive I get the Dell screen and then a black screen with a diagnostic stating "No Operating System Found". I tried to do a repair from the XP Professional CD on the...
That is the sign of a bad hard drive, or your OS being erased.
Run Dell Diagnostics
When the DELL™ logo appears, press <F12> immediately. Select
Diagnostics from the start menu and press <Enter>.
Run Hard Drive test
Dec 22, 2010 | Dell Vostro 1510 Laptop
Hi, I have bought this dell vostro 1015 laptop one and half year ago. Day before yesterday my windows XP hanged and I was unable to shut down. So I pressed power on button for few seconds to switch off...
It sounds like your hard drive has gone bad. As this is a laptop you can try to reseat the hard drive, if that does not help then it might be a case of hard drive crash.
Oct 29, 2010 | Dell Vostro 1510 Laptop
My Dell vostro 1510 starts bt the hard drive is nt detected.......I hav tested the hard drive, it's all right....plzz help!!
make sure hdd is set "master". make sure ide cable is connected correctly to hdd and mb. may have to change jumper setting on hdd either to "master" or "cable select". in bios, make sure ide control is set to "both".
Oct 23, 2010 | Dell Vostro 1510 Motherboard System Board...
My Dell Vostro 1000 computer shuts off within 25 seconds of turning on. It doesn't have time to repair itself before shutting off. I've checked the fan, power supply, battery, and removed the hard drive...
Has this problem been resolved? My immediate suspicion is an underpowered peripheral--do you have some sort of expansion card or adapter in your Express Card slot? If you have something like a USB 3.0 adapter or TV tuner card, remove it or provide it with an external power supply.
Oct 19, 2010 | Dell Vostro 1000 Notebook
I got a hard dish read error..
A hard disk read error is normally an indication of a failing hard drive. If you can, back up any important data because you will most likely need to replace the hard drive.
http://shop.ebay.com/?_from=R40&_trksid=p3907.m570.l1313&_nkw=vostro+1510+hard+drive&_sacat=See-All-Categories
Jul 05, 2010 | Dell Vostro 1510 Laptop
Reset bios/cmos password
on the bottom of the vostro 1510 there is a large panel that covers the hard drive, wifi card, and cmos battery connector. remove the cover unplug the red and black wire connector and remove the battery. also make sure the system is unplugged from power. i waited about 5 mins and pushed and held the power button for about a min. after that plug the main battery in and test to see if your password has been removed
Jun 06, 2010 | Dell Vostro 1510 Laptop
Dell vostro 1510 boot problem
Hi. If you don't have any important files in your hard drive, you can recover your computer to factory image
by restarting your computer and keep tapping F8 when you see the Dell screen to go to windows advanced Option.
Select repair your computer, press enter and click next. enter your administrator password and choose Image restore.
Hope it helps! ^_^
May 29, 2010 | Dell Vostro 1510 Laptop
Computers & Internet Logo
60 people viewed this question
David Payne
David Payne
