Question about HP LaserJet P1505n Printer
Hp 1505n laser jet, Makes clicking noises when printing. Slight smear on left side of page.
  • 48 Answers
There are two things that can cause print quality problems and a noises. One being the toner cartridge and the other being the fuser assembly. If you have already replaced the toner cartridge and it did not take care of the problem then the fuser may need to be replaced. You can take it to a local printer repair shop to get it fixed.
Posted on Sep 16, 2010
Smearing on HP laser jet 2055dn
That sounds like a drum issue. Try replacing the toner or have you done that already? Give me a call if you ever need to replace the toner. I can beat out Staples and Office Depot. Damien @ iPrint Technologies - 818.700.7419 Dir.
Aug 28, 2014 | Office Equipment & Supplies
HP 9050 with smeared or Ghosted print on the leading edge
Your printer might have dust on the hexagonal mirror and other optical components inside the LSU (Laser System Unit). If the printer it's dirty inside, all that dust flows and lay down on components. In course of time, it reaches the optical components and generates a "gradient wiped out" image from left to right as you are looking at the printed page. This problem is common on laser printers. On colour printers, you may find that only one or more colors have this gradient wiped out. Because they have separate Laser System Units.
May 08, 2014 | HP LaserJet 9050 Printer
HP 8600 makes clicking noise takes long time to start printing
Solved!
Found a misfed page jammed inside the printer on far
right side ( by the ink service station) - after removing the
"hidden" wad, the printer no longer makes "clicking" sounds
and prints right away!
Officejet Pro 8600
Feb 18, 2013 | HP Officejet Pro 8600 Premium e-All-in-One...
Hp laser jet P2035N has a crease down the center of the page as the paper exits it is actually slightly raised so the print is smearing
Check to make certain that the fuser unit is not damaged. Often a crease or dimple is caused by foreign material on the fuser roller or the fuser is damaged. If the fuser is damaged, look into replacing the device, it may be cheaper than repairing the fuser.
Jan 31, 2013 | HEWLETT PACKARD - LASER JETS New - Hp...
Hello, when it prints it makes a noise and bottom of page is smeared
Smeared output can result when you re-feed a printed page into the printer to make a double-sided page. This happens because the rubber rollers that grip the paper to pull it into the printer can pick up toner from the first side’s printing and smear it. So before replacing parts, this is an easy thing to check. Printing multiple pages consecutively will make the pages print progressively cleaner or you can clean the rollers with rubbing alcohol.
Smeared toner also happens because the nonstick coating on the fusing roller is scratched or has baked-on debris. This can happen if the printer is in a dirty environment especially. If you are comfortable removing the fuser, you can try to clean it with a soft cloth and alcohol, but make sure you let it cool down first!
Finally, if this does not resolve your issue then make sure the fuser is heating; toner that is not heated properly will fall from the page and smear. If the thermostat is bad or the fuser not working properly, you will most likely need to replace the entire fuser assembly. This will be pretty expensive to repair so hopefully it's one of those other issues.
As for the noise, there are several complex gear and roller segments that drive the paper between the paper tray, the scanner, the fuser, and the finisher. If these are not perfectly aligned or dirty the printer can make a grinding noise. It's even possible that if the paper is not being fed correctly, that the shift might leave segments of it less accessible to the fuser and prevent the toner from adhering to the page.
But I would try using WD-40 to lubricate some of these components and assume the noise and the smearing are separate issues.
Nov 18, 2009 | HP LaserJet 3330 All-In-One Printer
Failure to Allign
This could be the Fuser Assembly. The Fuser is the unit that heats up and makes the toner ahere to the paper. The fact that it is smearing, means that the Fuser is not heating correctly. I would call for service on it.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Sep 02, 2008 | HP Photosmart C7280 Laser Printer
Hp 1320
I want the software of laser jet 1320 printer
May 19, 2008 | HP LaserJet 1320 Printer
HP LaserJet P1505n Printer Logo
412 people viewed this question
Seeker5211
Seeker5211
