Question about Dryers
Try to turn dryer on,it just hums and then kicks a switch on inside ,then nothing.
  • 121 Answers
This can be caused by a bad motor, a bad switch in the motor or something hung in the fan. If there is something hung in the fan get it out and it should go back to work. If there is nothing in the motor try cleaning the motor very good with a vacume cleaner and if you have one blow it out with compressed air. If that doesn't work replace the motor. http://www.appliance-repair-it.com/clothes-dryer-repair.html
Posted on Sep 16, 2010
What is the problem with my dryer?
The motor starting circuit is failing. Confirm this by giving the drum a push start when it hums. Most likely, the centrifugal switch on the motor is sticking (due to lint buildup) or broken. It has a mechanical component that operates an electrical switch. Check the mechanical operation, then check the switch. Also, check that the motor electrical connector is seated completely.
Apr 02, 2017 | Whirlpool Dryers
My whirlpool ler4634 electric dryer has electricity running to it but when turned on, the drum does not rotate. It only makes a loud humming noise. What can be the problem?
It sounds like you have a blown motot try holding down the door switch and push start and turn drum at same time see if it kicks in
Sep 22, 2010 | Whirlpool LER4634J Electric Dryer
Turn the no switch nothing just a little hum what
check the drive belt ... if broken, thank your luckey stars it was not the motor ... could be the motor start circuit.
Jan 05, 2010 | GE Profile Harmony DPGT750GC Gas Dryer
Kenmore 110 wont run. Motor hums like it is trying to do something but nothing happens. I can smell the motor getting hot
Reach inside and turn the drum. Is it hard to turn?
If so you need to get inside the dryer and find the cause. Some dryer pix
Aug 25, 2009 | Washing Machines
Dryer wont start when start button is pressed, but humming sound
I'd sure start by making sure the belt isn't broken. You can usually see the belt with a flashlight after accessing the panel (some are in front, others in the rear) - don't go probing around bare armed without unplugging the unit....
Jun 20, 2009 | Whirlpool LER5636P Electric Dryer
Dryer just hums
there a part inside the dryer called a capacitor i'm not sure where about on your dryer where is located but they are usually sit right next to the motor it might be white in colour with 2 clips coming off it chnge it good luck
shaun
Jan 10, 2009 | Kenmore 63942 Dryer
Dryer will not start
I had the same problem and this is how I fixed it ,,, i did a comfortor ,very heavy when wet .....next day i tried to do a new load ...when I turned start button all i got was a hum... I removed screws just inside door at top of lip this releases top of dryer,,,, exposing drum i rotated drum clockwise to check condition of belt ....looked good ....mine is 7 yrs old ...to soon to be motor problem ....so while turning drum i held start button on and finally motor kicked in and this solved my problem...you might be able to accomplish this without taking of panel ..though you wont be able to see belt ....by turning the drum from inside dryer while someone else turns on start button
Oct 25, 2008 | GE Profile Prodigy DPSR513GA Dryer
GE Dryer DWSR473GV0WW periodically just hums when turning on switch
might have a dead spot on the armuture or lint in the motor and or the centrifcal switch try taking it apart and cleaning the motor if that doesnt work replace the motor
Feb 14, 2008 | Dryers
Dryer problem
you need to either clean or replace the drive motor motors have two windings start and run windings both windings kick in on start up then the centrifugal switch kicks the start windings out and the run windings take over if nothing is jamming the tub go to the motor sme times getting the lint out of the switches and motor will fix it if not replace it
Jan 18, 2008 | Dryers
if it hums when you start it means switch is ok. problem may be the motor capacitor. to check, take off the top and give the drum a push in the normal direction of rotation. if it goes then motor capacitor is faulty - cheap part
Mar 28, 2007 | GE Profile DPSB619ED Electric Dryer
Dryers Logo
44 people viewed this question
Top Dryers Experts
