Question about KitchenAid (KSRD22FKST) Side by Side Refrigerator
Side by side-freezer side will not maintain set tempertature
  • KitchenAid Master
  • 17,129 Answers
Make sure that the evaporator is not clogged witin as the auto defrost timer is not working well. If you open the back panel of the freezer tofind frostingg, then the perrformance of the freezer will be poor. So make sure that the timer is working , locate this at the rear bottom and check for the movement. This can be one reason for poor temperature setting to maintain.
Secondly you must check the gaskets for wearing, if so the temperature can be low.
Also the radiating fan also must blow to cool, check if there is damage on the fan.
finally the thermostat can be faulty and is not correcting, can be due to faulty links, wires that gets effected with frost( wires wearring out) Check also comrpessor relay, capacitor and voltage on mains.
The solution can be one of these.
Posted on Sep 16, 2010
Freezer too cold
Is this a model=>FGHC2342LF Sounds like the freezer=> 240597203 Thermistor may be defective??There should be one in the freezer that regulates the temp and this one may be causing the compressor to run continious and you may not be getting the correct reading from freezer. Have you seen this?
Sea Breeze
Jan 06, 2014 | Frigidaire FGHC2342LF Gallery Series...
What is freezer and refrigerator temperature suppose to be set on
If you want to set the temperature your Fridge/Freezer should maintain, you need to set the Freezer to between -19c and -23c, however if you will be keeping Ice-cream in this freezer then it's best to set the base temp @ -21c minimum, -23 preferable, or the ice cream may begin to break down (very slowly I might add). The Fridge needs to be set to a maximum Highest temp) of 5c, any higher and the food will not stay as fresh and bugs will be able to breed, preferable temp is approximately 3-4c.
Jun 20, 2012 | Jenn-Air JSD2789GES Side by Side...
I have a side by side jen air. The refrigerator side quit working altogether. The freezer side maintains a temp that the refigerator side usually runs at...
Check contol settings. Vacuume out bottom fridge coils carefully. Factory settings are the middle number on both controls. If all else fails turn the freezer control up a couple numbers.
Jan 28, 2011 | Jenn-Air Refrigerators
Freeze maintains normal temperature but the refrigerator does not. Already checked temperature settings. What could be wrong?
check to see if fan inside freezer is running.
is the evap coil in freezer froze up ?
if fan is running and coil is froze up u need a defrost timer.
Sep 23, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
ED25PQDW01 side by side refrig -freezer is inconsistent. Need to have full cold to maintain freezer temp. cleaned coils, but still an issue.
Do you see a light coat of frost in freezer section about 12 inches up (defrost problem indication) ? Has the icemaker slowed down a bit in ice production ? What is the refrigerator control set on ? When you turn the freezer up completely , it cuts off the cold air flow which cools the refrig section . If refrig control is set mid way , turn it up higher , so refrig will run longer , but lower the freezer setting so some cold air will enter the refrig section . Also check to see if the freezer fan is working .
Aug 15, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool intgrated fridge/freezer is not keeping
7 is coldest. but how cold is the freezer? all cold is made in freezer. ma be developing a frose problem
Jul 06, 2009 | Whirlpool ED2GHEXN Side by Side...
Freezer does not maintain temperature/moisture in freezer
The door seals are letting air in or the seal at the ice dispenser has gone bad and is letting outside(hot) air in and it is the cause of the moisture.
Jun 10, 2017 | GE GSS25JFM Side by Side Refrigerator
Side X side TFX20JA refrigerator not freezing or maintaining cold
Thank you for your help!! I was able to repair my refrigerater thanks to someone who had previously had the sam problem and was given three things to check. The problem was the heater in the freezer was burn out.
Jan 25, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Fridge tempertature
I have the same symptom too - freezer temperature flashes at -2. "Power Freezer" or setting it to any other temperature is not working either.
As a result, no ice being made. Please help!
Aug 03, 2008 | Samsung RS2630SH Side by Side Refrigerator
KitchenAid (KSRD22FKST) Side by Side Refrigerator Logo
82 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
