Question about Vacuums
Smells like burning rubber as if belt was broken but on inpection, it is intact. What else could cause this?
  • 32 Answers
The belt could be snagged and stuck as the motor is turning. i had this problem when i put a belt on my vacuum that was too small then again when there was hair caught in the belt turning mechanism
Posted on Sep 16, 2010
My hoover steam vac is making a horrible noise and smells like its burning
Something may have jammed the brush roller, preventing rotation. This causes the motor shaft to rotate in one spot on the belt, causing the burning rubber smell. Eventually, the belt will break. You need to find what caused the jam and remove it. It would be a good idea to replace the belt as a burned belt is unlikely to last much longer.
Dec 18, 2014 | Hoover Steam Vac Dual V w/ SpinScrub...
Burning smell Kenmore 50558
If the burning smell is an electrical smell it could be motor or wiring problems which are best handled by a professional. If it smells like burning rubber it is probably the belt. If it smells like burnt wood it could be the belt slipping on the brush roll, if the brush roll is made of wood. Dust and debris can also accumulate behind the end caps of the brush roll causing friction which can cause a burning wood smell.
Mar 30, 2014 | Kenmore 5055, 50557 and 50558...
Smells like burning rubber when running
Vacuum belts lose elasticity and will slip. It may spin the brush roll ok when you look at it but be so loose that when. Vacuuming carpets the belt will stop turning. The motor shaft is still spinning and will melt the rubber belt causing a burned rubber smell. Belts on almost All vacuums need. To be changed at least twice per year.
Nov 13, 2011 | Riccar 8955 Upright Vacuum
Hi, the cleaner is making an unusual griding sound and smells like burning rubber. Ideas?
broken belt or dislodged belt on the roller unit. Check and replace belt, it's pretty simple to do but you will have to remove a few screws and a plate to get to the belt/rollers.
May 27, 2011 | Hoover F5872-900 SteamVac Wet/Dry Vacuum
My Hoover upright model 6437-900 makes a distressed sound when I turn it on and it also burns rubber. The roller turns. I've checked the thick black belt and it's intact, but has lots of 'pitting'. ...
It certainly sounds as though the belt needs replacement. (Part # 38528035) If the belt has stretched, it will slip, causing a burning rubber odor. Get a new belt and compare it to the used one.
Feb 22, 2011 | Hoover U6437-900 / U6439-900 Windtunnel...
Runs, Smells like it is burning up
If it smells like burning rubber then it's possible that the belt is broken.
Feb 11, 2011 | Hoover U5753-900 WindTunnel Bagless...
Our vacuum smells like burning rubber. Does it
Burning rubber smell means the brush belt need attention. Make sure the brush is turning freely and replace the belt
Jul 05, 2009 | Eureka Vacuums
Dirt Devil vacuum M85845 broken belts. Can't get
call all-type vacuum &janitorial supply.lisa can help you.314-275-8006
Apr 08, 2009 | Dirt Devil M085850 Featherlite Bagless...
Rainbow Vacuum smells like something is burning.
Your belt is worn and that is why there is a burnt rubber smell. You need to change your belt. You can find a replacement belt and instructions here:
Rainbow Replacement Belts
Apr 02, 2009 | Rainbow E series Canister Wet/Dry Vacuum
The vacuum turns on but wont run smells like burning rubber I took the bottom off and the belts dont appear to be broken but the one connected to beater bar seems like it may be loose
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=542493
Generic problem for all Vacuums
Posted by mmetcalf on Apr 24, 2008
the vacuum turns on but wont run smells like burning rubber I took the bottom off and the belts don’t appear to be broken but the one connected to beater bar seems like it may be loose
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
In answer to your question, the reason it smells like burning rubber is because the belt is too loose and it is burning the inside of the belt because it is to loose, the average belt change for a Kirby vacuum is every 4 to 6 months, the tighter the belt the better the cleaning and always use the genuine Kirby belts because they are designed to work with the Kirby, there are replacement belts that will work and are less but they are made to the correct size but Kirby vacuums always s work better with genuine parts. If you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://kirby.com Contact Us by Phone
United States and Canada 1-800-494-8586
Between the hours of 8:00 am to 5:00 pm EST
Monday thru Friday
www.A-1Vacuum.com 1-800-657-1874 If you cannot find a local dealer near you they can ship you the parts UPS.
Thanks, Don – The Vac Man
Go Ahead. Use Us.
Apr 24, 2008 | Vacuums
Vacuums Logo
51 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
