I want to uninstall my kodak easyshare program. It won't let me and error code 60x11x0x is coming up.
    Guru:
  • 1,082 Answers
  1. Visit the Clear Utility for KODAK EASYSHARE Software Web page.
  2. Click the Download button, and then follow the on-screen prompts.
Posted on Sep 16, 2010
Screen says "Printer error."
Welcome to Fixya
If the error occurred when you were trying to use a feature of EASYSHARE Software:
  1. Run the Repair utility:
    1. Select Start > Settings > Control Panel > Add or Remove Programs.
    2. Click KODAK EASYSHARE Software.
    3. Click Change.
    4. Click Next.
    5. Select Repair, then follow the instructions.
  2. Try the feature again.
If the error occurred when you were installing or upgrading EASYSHARE Software:
  1. Uninstall your current version of EASYSHARE Software:
    3. Select Remove.
    4. Follow the instructions to remove the software.
  2. Go to the Clear Utility for KODAK EASYSHARE Software at www.kodak.com/go/clear, then follow the instructions to run the utility.
  3. After restarting your computer, go to KODAK EASYSHARE Software at www.kodak.com/go/easysharesw, and install the latest version of software, free of charge.
Thank you for using Fixya!
Mar 23, 2011 | Computers & Internet
Error code 3825
Answer: Answer last updated:11-17-08 Error code resolutions are updated on a regular basis. If, after you search, you cannot find a resolution to your error, the instructions below can help you.
IMPORTANT: Print this page before continuing.
Search for a resolution to your specific error code:
  1. Go to KODAK EASYSHARE Software Support.
  2. In the box under Find Answers, type the complete error code (without spaces), then click Search. An example is 12x413x1304x
If you don't find information for your specific error, follow the instructions below:
    3. Select Remove.
    3. Click Change.
    4. Click Next.
Nov 03, 2010 | Office Equipment & Supplies
Kodak Easyshare 5300 printer error code 3806
YOU HAVE TO REINSTALL YOUR DRIVERS FOR KODAY 5300 PRINTER.
GO TO CONTROL PANEL AND CHOOSE ADD/REMOVE PROGRAMS AND UNINSTALL DRIVER AND REINSTALL DRIVER AGAIN, YOU MAY GET SOLUTION.
Oct 03, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Can't get picture to scan
try doing this procedure to fix the issue.....
To perform a clean installation of the KODAK AiO Home Center software, follow the instructions below:
1. Disconnect all USB devices from the computer, including the Kodak EasyShare all-in-one printer.
2. Uninstall the KODAK All-in-One Printer Software:
    a. In the Control Panel, select Add or Remove Programs (WINDOWS XP Operating Systems) or Program and Features (WINDOWS VISTA Operating Systems).
    b. Select one of the following software programs from the list of currently installed programs, depending on which one appears in your list:
      • Kodak EasyShare software
      • KODAK All-in-One Printer Software
      • Kodak EasyShare 5000 series all-in-one software
    c. Click Change or Remove (WINDOWS XP OS) or Uninstall (WINDOWS VISTA OS).
    d. When the Install Wizard appears, click Next.
    e. Depending on the issue(s) you are experiencing, do the following:
      • If you are experiencing errors with KODAK EASYSHARE Software, such as a tri-code, in addition to errors with KODAK All-in-One Printer Home Center Software, select Remove, click Next, and follow the on-screen instructions for removing the software.
      • If you are not experiencing errors with KODAK EASYSHARE Software, select Modify to uninstall only KODAK All-in-One Printer Home Center Software, then click Next.
    f. In the Custom Setup window, select Remove from the drop-down menu for the Kodak All-in-One Printer, and click Next.
    g. In the Ready to remove the program window, click Next.
    h. In the Uninstall Complete window, click Continue.
    i. Restart the computer.
IMPORTANT:
    • If you selected Modify and only uninstalled the KODAK All-in-One Printer Software and did not uninstall the KODAK EASYSHARE Software, continue to Step 4.
    • If you selected Remove and uninstalled both the KODAK All-in-One Printer Software and KODAK EASYSHARE Software, continue with Step 3.
3. Run the Clear Utility to delete any previously installed KODAK All-in-One Printer Software components:
    1. Got to www.kodak.com/go/clear to download the Clear Utility for KODAK EASYSHARE Software.
    2. Select your operating system from the drop-down list and click the Download button to save the file to your desktop.
      Note: If the status indicator on the Clear Utility stops, check the taskbar on your computer for an active security program. If a security program appears in the taskbar, it may be prohibiting the Clear Utility from running. You must allow the Clear Utility to run on your computer before you can continue.
4. Delete the files and folders that can interfere with the installation.
    For WINDOWS XP OS, delete:
      • Printer folder in C:\Program Files\Kodak
      • Both the Eastman Kodak Company and KDS_Kodak folders in C:\Documents and Settings\All Users\Application Data
      • Kodak 5000 Series AiO folder in C:\Documents and Settings\All Users\Application Data\Kodak
      • Printer folder in C:\Documents and Settings\All Users\Application Data\Kodak\EasyShareSetup
    For WINDOWS VISTA OS, delete:
      • Eastman Kodak Company folder in C:\ProgramData
      • Eastman Kodak Company folder(s) in C:\Users\your name\AppData\Local
5. Run Disk Cleanup:
    1. Open My Computer.
    2. Right-click Local Disk (C:) and select Properties.
    3. Click the Disk Cleanup button.
    4. When the Disk Cleanup for (C:) window appears, select the Temporary Internet Files, Recycle Bin, and Temporary Files check boxes.
    5. Click OK , then click Yes to delete all files and begin the Disk Cleanup.
    6. When the Disk Cleanup is finished, click OK in the Local Disk (C:) Properties window.
6. Shut down all background applications.
    1. Select Start > Run.
    2. Type msconfig in the Open field, and click OK.
    3. Select the Startup tab.
      IMPORTANT: If not all the applications in the Startup Items list are selected, write down which applications are selected so you know which ones to turn on again later.
    4. Click Disable All , then click OK .
    5. When prompted, restart the computer.
7. After the computer restarts, install the latest version of the KODAK All-in-One Printer Software as a free download from the Kodak Web site at www.kodak.com/go/downloads.
    • If the customer has the latest version of the KODAK All-in-One Printer Software on CD, install the software from the CD.
8. Before restarting the computer again, turn on the background applications.
    2. Type msconfig in the Open field and click OK.
    4. Under Startup Items:
      - If only some items were originally selected, select the check box in front of the items that you noted in Step 5-c.
      - If all background items were originally selected, click Enable All, and click OK.
9. Restart the computer.
Nov 09, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Kodak Easyshare Software has stopped working
Close Easyshare Program > If you see an icon of easyshare at the system tray {lower right corner of the screen}
right click on it and choose Shutdown Easyshare
Right Click on the icon of Easyshare on your desktop{upper left of screen}
choose Properties, choose Open file location> Look for Catalog Folder > rename it to "old catalog" > close the whole window
Go to My Computer > C: Drive > Users > Public > Public Documents >
Look for ESBK.mb and ESBK.mbb
restart your computer
Relaunch Easyshare Program
Goodluck...
Sep 20, 2008 | Kodak EasyShare C613 Digital Camera
Kodak aio printer 5300/software problem
Greetings Jackie,
Sounds like you have a failed .netframework installation. This is a Microsoft feature, but is delivered during installation of Kodak software as well. To fix this, do the following.
1. Open the Control Panel.
2. Double-click Add / Remove Programs (Windows XP only).
3. Select Microsoft .NET Framework 2.0.
    IMPORTANT: If other versions of Microsoft .NET Framework are listed, do not perform this operation on those other versions. Follow this procedure ONLY for Microsoft .NET Framework 2.0.
4. Click Change / Remove.
5. Select Repair, and click Next.
NOTE: A progress bar shows the repair progress.
6. After the repair is complete, make sure the Restart the computer check box is selected, and click Finish.
7. After the computer restarts, start the KODAK AiO Home Center software.
IMPORTANT: If the KODAK AiO Home Center software fails to start or continues to display an error message, completely uninstall Microsoft .NET Framework 2.0 and do a clean reinstall KODAK AiO Home Center software. The Microsoft .NET Framework 2.0 will also be reinstalled with the KODAK AiO Home Center software.
    1. Follow steps 1 - 4 above.
    2. Select Uninstall, and click Next.
      IMPORTANT: Uninstall ONLY Microsoft .NET Framework 2.0. If other versions of Microsoft .NET Framework are listed, do not uninstall them.
    3. Restart the computer.
    4. Perform a clean re-installation of the KODAK AiO Home Center software:
      a. Disconnect all USB devices from the computer, including the Kodak EasyShare all-in-one printer.
      NOTE: Do not disconnect your mouse or keyboard.
      b. Uninstall the Kodak EasyShare 5000 series all-in-one software:
        i. In the Control Panel, select Add or Remove Programs (Windows XP).
        ii. Select one of the following software programs from the list of currently installed programs, depending on which one appears in your list:
          • Kodak all-in-one printer software
        iii. Click Change or Remove (Windows XP).
        iv. When the Install Wizard appears, click Next.
        v. Depending on the issue(s) you are experiencing, do the following:
          • If you are experiencing errors with the Kodak EasyShare software, such as a Tricode, in addition to errors with the KODAK AiO Home Center software, select Remove, click Next, and follow the on-screen instructions for removing the software.
          • If you are not experiencing errors with Kodak EasyShare software, select Modify to uninstall only KODAK AiO Home Center software, and click Next.
        vi In the Custom Setup window, select Remove from the drop-down menu for the Kodak All-in-One Printer, and click Next.
        vii. In the Ready to remove the program window, click Next.
        viii. In the Uninstall Complete window, click Continue.
        ix. Restart the computer.
      c. Delete the files and folders that can interfere with the installation:
      d. Run Disk Cleanup.
        i. Open My Computer.
        ii. Right-click Local Disk (C:) and select Properties.
        iii. Click the Disk Cleanup button.
        iv. When the Disk Cleanup for (C:) window appears, select the Temporary Internet Files, Recycle Bin, and Temporary Files check boxes.
        v. Click OK , then click Yes to delete all files and begin the Disk Cleanup.
        vi. When the Disk Cleanup is finished, click OK in the Local Disk (C:) Properties window.
      e. Shut down all background applications.
        i. Select Start > Run.
        ii. Type msconfig in the Open field, and click OK.
        iii. Select the Startup tab.
        iv. Click Disable All , then click OK .
        v. When prompted, restart the computer.
      f. After the computer restarts, insert the KODAK EASYSHARE 5000 Series All-in-One Software CD into the computer CD drive to begin the installation.
      g. During the installation process, when prompted, select to search for an updated version of the software on the Kodak Web site and install the updated version.
      h. Before restarting the computer again, turn on the background applications.
        ii. Type msconfig in the Open field and click OK.
        iv. Under Startup Items:
          - If only some items were originally selected, select the check box in front of the items that you noted in Step e-iii.
      Once restarted, you should be OK.If not call our 800 421 6699 and they will help further.
      Best Regards,
      Ron Baird - the friendly Kodak guy
Sep 18, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Kodak EasyShare 5300
Sorry to hear about your trouble. Since I am not sure of the details, let me offer a long review and suggestion. It may work for you, especially if the AiO software is not installing correctly.
If the KODAK AiO Home Center software fails to start or an error message appears, there may be a problem with the Microsoft .Net Framework 2.0 installation. To resolve this condition:
2. Double-click Add / Remove Programs (for Windows XP) or Programs and Features (for Windows Vista).
4. Click Change / Remove (for Windows XP) or Uninstall (for Windows Vista).
1. In the Control Panel, select Add or Remove Programs (Windows XP) or Program and Features (Windows Vista).
2. Select one of the following software programs from the list of currently installed programs, depending on which one appears in your list:
3. Click Change or Remove (Windows XP) or Uninstall (Windows Vista).
4. When the Install Wizard appears, click Next.
5. Depending on the issue(s) you are experiencing, do the following:
- If you are experiencing errors with the Kodak EasyShare software, such as a Tricode, in addition to errors with the KODAK AiO Home Center software, select Remove, click Next, and follow the on-screen instructions for removing the software.
- If you are not experiencing errors with Kodak EasyShare software, select Modify to uninstall only KODAK AiO Home Center software, and click Next.
6 In the Custom Setup window, select Remove from the drop-down menu for the Kodak All-in-One Printer, and click Next.
c. Delete the files and folders that can interfere with the installation.
For Windows XP, delete:
i. Printer folder in C:\Program Files\Kodak
ii. Both the Eastman Kodak Company and KDS_Kodak folders in C:\Documents and Settings\All Users\Application Data
iii. Kodak 5000 Series AiO folder in C:\Documents and Settings\All Users\Application Data\Kodak
iv. Printer folder in C:\Documents and Settings\All Users\Application Data\Kodak\EasyShareSetup
For Windows Vista, delete:
ii. Eastman Kodak Company folder in C:\ProgramData
iii. Eastman Kodak Company folder(s) in C:\Users\your name\AppData\Local
Jan 31, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Kodak easyshare DX 4530
I have upgraded my Easy share software to version 7.1 ever since I cannot open the program. It comes up with The message of "One or more system DLL's could not be loaded :ES App.dll " then appears the message of "Easyshare unable to run. Please run Setup and choose repair to fix the application.[0,5006,0] " . When I run the repair program, it blocks part way through and the error message of 1334x97x3839719742x appears. Short of getting rid of Kodak off my computer which I dont want to do as I have important pics in the album, and I have a Kodak digital camera. What can I do to fix.
Oct 15, 2007 | Kodak EasyShare DX4530 Digital Camera
Kodak EasyShare Software/Printer problems
Kodak has been making a lot of changes to that program, due to problems. If you loaded the software that came with the camera, it is very likely out of date. You need to visit the Kodak website and download the latest version of the software.
Aug 30, 2005 | Kodak EasyShare CX7430 Digital Camera
Computers & Internet Logo
David Payne
David Payne
