Question about Garden
Re Makita LS1040 blade guard mechanism, hi there i did a foolish thing yesterday instead of seeking professional advice off of the net i went ahead & removed the possi screw with the big washer on it which holds the guard mechanism together i thought you had to remove this to get to the bolt that retains the blade on the spindle.Ive managed to reassemble the mechanism but its not lifting the guard as it did before i tamperred with it,any suggestions would be much appreciated.Thanks Jim UK.
  • 384 Answers
SOURCE: i dont know what to use to remove the cover to
There no spark plug on an electric chainsaw.
Posted on Jun 16, 2009
  • 384 Answers
Most likely it is a Torx head type screw. Looks like a cross between a Allen & Philips. Go to your local hardware store or auto supply store and get a Torx driver with exchangeable bits (about $4.00)
  • 7733 Answers
SOURCE: Please tell me how to
Go Husqvarna Genuine Parts - Reliable Spare Parts for Homeowners
Posted on Nov 03, 2010
  • 7733 Answers
SOURCE: hi i have a
Go to this LINK and find the part/diagram that can help you.
Posted on Nov 04, 2010
  • 101 Answers
SOURCE: needing to change the 12
I don't believe you have to take the guard off,just roll it back out of the way so you can get a wrench on the nut. The rotation is clockwise to take it off.
Posted on Sep 01, 2011
I have no power on Makita LS1040, changed carbon bushes, any ideas
check the switch 651923-1 SWITCH, LS1040 behind the 415999-0 SWITCH LEVER, LS1040.
If you don't have the parts list, here's a link:
May 07, 2017 | Makita Saws
How do I lift the saw mechanism on a Makita LS1040. It is locked and cannot trace any release mechanism. Danie
It's on the righthand side of the saw at the hinge area in the back. If that is unlocked then it could be the guard linkage hanging up.
Feb 16, 2015 | Makita Saws
How to fit compression spring on makita LS 1040 mitre saw
Go to: They also have a video on how the replace the blade. Look closely at the parts diagram to see how and where the spring fits and fit accordingly.
Sep 09, 2014 | Saws
Guard spring replace
springs are available from the manufacture spares places or from a hardware store. Any spring of the same size and length will do the job.
Mar 29, 2013 | Makita 10" Compound Miter Saw LS1040
Do you have the wrench that came with the saw? It should be slid in the back somewhere, there is a lock on the top that you hold the motor locked with, unplug the saw, turn the nut on the blade, start the saw down and grab the guard with your thumb to hold it and then lift it up all the way to slip the blade out. You should be all set.
Jun 20, 2010 | Makita 10" Compound Miter Saw LS1040
My makita sliding mitre saw is off a few degrees How do I adjust...non laser...10''
move the blade until it is square to the fence then loosen the screws on the table with the degree increments and set to zero.
Nov 19, 2009 | Makita 10" Compound Miter Saw LS1040
Changing the blade
there is a nut holding the blade in the center , it is left handle thread , there should be a locking mechanism to hold the blade while you unscrew the nut
Oct 31, 2009 | Makita 10" Compound Miter Saw LS1040
How to lift blade on mikita 10 mitch saw
right side of saw is a spring loaded knob. push saw down and pull out knob - rotate knob 90 degrees.
Oct 14, 2009 | Makita 10" Compound Miter Saw LS1040
Blade acts unusual
Hi, Blade wobble at high speed can be very dangerous! The saw at the right ( wrong) wobble can destroy itself.There are a few things that can cause it, And you have to check them as best you can before you power it back up. Check the blade, you can lay two blades together and check for gaps anywhere. Check that the hub and spindle are flat where the blade goes. (No lock washers) Also check the spindle for side to side movement, there shouldn't be any. Turn the spindle by hand and see if you feel any grit or sandy type feeling, you shouldn't. Lastly, if you don't find anything, try a new blade of a different type, and if it wobbles again, check and see if you have any warranty left and even if you don't you should contact Makita about it.
About the best I can do from long distance. Let me know what you find, Please.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Mar 31, 2009 | Makita 10" Compound Miter Saw LS1040
Garden Logo
63 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
