Shutdown probs cased by ati
Hi you told me 2 rebot my comp and start-run msonfig but im not very good on comp could you explain how i do this
    Genius:
  • 2,785 Answers
Thanks dear
can you do one thing do have yahoo messenger if yes then i can give you online suggestion, i am online now
Posted on May 17, 2008
  • Rajkumar Bordoloi
    Rajkumar Bordoloi May 17, 2008
    ok follow the steps
    you will see start button in the left hand (bottom)from where you use to shut down the pc.
    click on start-then click on run, you will get a space in run to type just type "msconfig"(without the quotes)and press ok then you get system configuration utility, on that screen just click on startup then you will get a list of programe with tick mark,just go to below and click on disable all then click on apply then click on ok.
    close the system configuration utility and you will get the message for rebooting just click to confirem and your pc will reboot,after rebooting just click on mesage you get and again you reboot and see the problem is solved or not.
    post for any help
I have a asus striker extreme that shutoff by itself
did you check already the switch mode power supply unit of your pc? might drop the voltage or need to upgrade with higher wattage.
Jul 04, 2012 | Computers & Internet
Have a Medion desktop PC model MS-7646 Since loading COD4 & Fallout newvegas the radeon 5670 card has stopped working 14 times - the screen pixilates, then turns black and everything freezes. Have 4gig...
I so have the same comute, dont use the windows 7 upgrade for the ATI card 5670, the latest driver fails miserably and will give blue screen, I had to revert back to the driver from Medion Support, also if your computer is clicking 4 times on shutdown, you need to fix that issue as well, its the ieee394 fire wire causing the prob with shut down, if you download device doctor it will source the correct driver for you, install all new drivers except the ATI drivers, I have two of these beasts and cant kill them no matter what I throw at It, also download the new direct x 11 drivers and I hope you have success as the tower is a good solid built comp with two years warranty
cheers
paul
Nov 03, 2010 | Computers & Internet
The wondows gets shutdown when I try to connect my mobile via Lg PC suit. My model is Lg KP 500
I bought my cookie the other day and saw the same problem, each time you select pc suite on the phone the comp crashes, instead choose "music sync" or "mass storage" the later means you dont have to have the pc suite software running on the comp you can drop and drag in windows just like its a usb flash drive, when ur ph is connected you'll see a new drive appear in "my computer" (2 drives if you have a micro sd card inserted). Now you can drag and drop your files into these folders, I had probs with the software installation ended up downloading drivers of net one for music sync (which uses pc suite software) another for mass storage which'll end up being the only one I connect with, It looks to me like a software fault which makes the comp crash when you select pc suite. hope this gets you up and running, good luck :)
Aug 20, 2009 | LG KP500 Cookie black on T-Mobile U-Fix...
Keyboard locks on startup, mouse pad works, FN & ECS (for Standby) works
your comp is infected for sure.i`ve seen many cases where my customer`s comp is infected and they face the same problem.
make sure you have ethernet cable plugged in to your laptop so we can use safe mode with networking. shutdown your computer.on top of the keyboard you have F8 key.the moment you`ll press the power button to turn on the computer start tapping F8. advance boot up options will appear. select safe mode with networking
try restoring your comp to a previous time when it was working. if it doesn`t work don`t worry just follow the steps below.In any case you have to clean virus out of your computer.
download,install and run this software.after running the scan clean all the infections and restart your comp.
http://www.download.com/Malwarebytes...dlPid=10878968
Good Luck!!
May 19, 2009 | Dell Computers & Internet
Capture driver present in Device Mgr but ATI card says no
hi,remove the drivers restart, shutdown relocate the card to different pci slot, reinstall the drivers, then try again hope this helps,good luck, if you have the install disk use that, then go for newer drivers.
Feb 13, 2009 | ATI ALL-IN-WONDER X600 PRO, (256 MB)...
How to rebot acer 4220 laptop
usually holding down the power button for a long time will force a reboot. I am not sure if that is what your asking
Dec 05, 2008 | Computers & Internet
Video cardis it true?hope someone help me this prob. tnx!
Well if the card you bought is an PCI-express card and the port on your motherboad is an APG....you cant use it!
Oct 16, 2008 | ASUS P5PE-VM Motherboard
Comp. components
1. ATX Case
2. Intel Motherboard with PCIE 2.0
3. SATA Hard Drive
4. Quad Core Processor
5. 2G or 4G of 800mhz or 1066mhz RAM
6. CPU Cooler
7. 80mm Case Fans
8. Creative Sound Blaster Sound Card
9.Gigabit NIC
10. Newegg is a good cheap place to get this stuff. Or tigerdirect.
Jul 23, 2008 | ATI RADEON 9250, (256 MB) PCI Graphic...
Shutdown problems
boot your pc then follow the steps
start-run-msonfig(type in run command box then hit enter) in msconfig dialog box go to startup-disable all then click apply then click ok reboot,it will take some to reboot, then a message come just clik ok.
when your pc reboot again you restart now you check if the problem is solved
if you want any help fell free to post
May 17, 2008 | Computers & Internet
System error loading
try restarting and go to bios,set to default config.
Also,
This issue may occur if your computer BIOS does not correctly manage or support the capacity of the hard disk on which you are installing Windows XP.
See this article:
http://support.microsoft.com/kb/326676
Dec 15, 2007 | ASUS P4VP-MX Motherboard
Computers & Internet Logo
David Payne
David Payne
