I have a 245,000btu crown steam boiler with 2 risers in a moderatly well insulated 4 family unattched building ,boiler is less than 1year old problem is front riser ,farest from boiler takes very long to heat while the rear,closet to boiler heats very well. how can the heat be equalized ?
  • marc2280 Sep 16, 2010
    the distance to the farest riser from the boiler is approximetly 50 feet latterily the boiler seams to not be able to sustain the steam long or fast enough to comfortably heat the 2 front apartments on the morning cycle. it is a 2 story,4family building 2rear apts. heat fine, 2front apts. need adjustment
  • marc2280 Sep 17, 2010
    the piping is the correct diameter & there are only 3 45s on the run, 1 at the boiler riser, 1straight out at the end of the approx.50 ft. run, 1 to the radiators, 1st & 2nd floor approx. 10ft. in on the front wall
  • 2,427 Answers
There should be a valve on the lines that regulates gas pressure between the two risers,, (assuming its gas i ant familair with this model) ,, adjust it a bit to regulate the two,, a bit of trial and error will be needed..
ELETRIC..
same thing ,, in this case its a variable resistor which allows power flow to the two .. there should be once for each,, adjust that a bit to even it off.
Posted on Sep 17, 2010
  • 11,800 Answers
The pipes are too narrow and have too many bends.
You will need to completely redo the piping: connect the 2 front apartments directly to the boiler using larger pipes and with a more streamlined design.
Posted on Sep 16, 2010
  • Azrael SRL Sep 17, 2010
    That appears correct - but i would still fit larger pipes. In the mean time check the circuit for obstructions such as lime or corrosion deposits or other junk left in there during install.
  • 3,083 Answers
I don't know much about these, but here is a .pdf file that looks like it might have some information about riser equalization.
I can't open .pdf files due to a problem with Adobe, but here is the link:
www.mid-lakes.com/pdfs/ML_06_Heat_Catalog_Section_2.pdf
Hope this helps you.
Increase steam flow
If the steam is slow to recover the most likely issue is scale build up on the water level probe on the boiler. Scale builds on the probe and the boiler over fills leaving less room for steam to build.
the probe is usually easy to remove and clean but this MUST BE DONE WITH THE MACHINE COLD AND ALL STEAM LET OUT.
If you are unsure take the machine to an approbed repair centre to avoid risk of scalding.
Dec 14, 2014 | Coffee Makers & Espresso Machines
Tip
Hot Water Steam Efficiency Plus Comfort
Steam heat is a great warm, wonderful, and absolutely fabulous way to heat your house. Steam heat is almost always created from water in a boiler fueled by gas, oil or electricity. It then passes through pipes and radiators or convectors to heat your home. A steam heating system uses steam that is generated from a boiler. When the water boils, the steam rises through the pipes and into the radiators to heat them. The hot radiators then heat your home.
Steam is a great heat distribution medium because it moves easily through your system and it has an extremely high heat-holding capacity. The heat-holding capacity of steam is much greater than that of water. Steam heating systems often operate at very low pressures and usually under 220°F. Steam heat is usually distributed by either one or two pipe systems. In a case of a one-pipe steam heating system, a single main serves the dual purpose of supplying steam to the heat exchanger and allowing condensate to run back from the radiators also. A two-pipe system has two connections from each heat exchanger or radiator. In this system, steam and condensate flow in separate piping from each other. With a steam system all pipes must be well insulated and you must use pipe insulation rated for steam piping. If the insulation is removed the system will no longer work as designed. Noise and all sorts of problems will come from uninsulated piping.
When you have radiators on upper floors or radiators that are further from the boiler they should be adjusted to release more air to compensate for the increased air volume in the piping due to the distance from the boiler. If you have a valve that is clogged with mineral deposits or stuck shut, no air will be able to get out of the piping. Because of this no steam can enter the radiator, so it doesn't heat up. This will block the movement of steam into the radiator, or cause a very noisy hammering as pressurized steam tries to get through this water "dam".
Steam radiators need to have a valve that allows air to escape at a controlled rate so that the radiator can heat up. Steam heating systems will also lose a little bit of water all the time, so there has to be water makeup so that you do not run your boiler dry. Steam heating systems without an automatic water feeder are not safe. You will risk serious boiler damage should boiler water be lost. If the boiler runs dry it could also explode if water is placed into it while it is hot. There should always be a low water cutoff installed on every steam system. Therefore on a steam boiler the automatic water feeder serves as a safety device also.
It is very important that you find someone that is very familiar with steam heating systems when repairing or installing steam heating. Incorrectly designed, installed, steam systems and condensate piping is a huge problem in today's buildings and facilities. There are not many qualified to design and install properly operating steam heating systems. Incorrect steam piping will always cause costly premature failure of steam equipment such as steam coils, heat exchangers, and control valves. Not to mention the higher cost of operating a system that is not working efficiently.
http://www.fixya.com/support/r3904286-steam_system_steam_radiator_air
http://www.fixya.com/support/r4008078-differences_between_steam_hot_water
on Dec 29, 2009 | Heating & Cooling
Radiator not getting hot
As it's above the boiler, the most likely cause is air in the system - I would try bleeding the radiator.
If still no joy, then try reposting in a more appropriate category
Feb 05, 2014 | Computers & Internet
Make : Weil-McLain Model : CG-5-SPDN Series 12 I have the above mentioned boiler which is located on the 1st level of a three story one family house, the area where the boiler is located is insulated.
You don't have an optimum distribution of steam in your house. Try closing a little bit the valves supplying the heaters in the lower floors. Close a little bit more until you get the desired balance.
Nov 06, 2012 | Heating & Cooling
My silvia is less than 2 years old. Yesterday I let the steam switch on and forgot to turn it off after steaming. It was on for about two hours. Then it won't heat up either. Should I get new part
On the happy side, if you tried to re-heat the boiler and found this problem straight after it failed, the thermostat may still re-set once the unit cooled down. So leave it a day and try again. Alternatively, it could be a burnt out fuse or on the less happy side, a burnt out boiler.
If no lights come on its a failed fuse. But if everything else is normal but it still wont heat, the best option is to take it for a service to a qualified technician as it may be that the boiler was damaged.
Jul 13, 2012 | Rancilio Silvia Espresso Machine
My mavhine is less than 2 years old, never had a problem till now.It will not heat up .Where can I get parts , and do I need spaecial tools to fix if its the heating element? thanks steve
Hi
There is a reset button inside on the front side of the boiler (you have to take the top of the machine off. There are 4 screws and remove the water tank). It is located between 2 black wires and is a red button. Push it in and test. There is also another problem that you might have. If the brew thermostat is bad it won't heat. To test for this, push the steam switch and wait 15 seconds. Then open the steam knob and push the middle button and see if the water is warm. If it is then you need a new brew thermostat. That is the thermostat that has the red dot on the top. It sets on top of the boiler next to the steam thermostat. If you take the top off, make sure that the machine is unplugged.
If none of these things work check the heating element with an ohms meter. The reading in the terminals should be from 12 to 16 ohms. If no reading the elements is bad and you have to replace the boiler.
Apr 12, 2011 | Rancilio Silvia Espresso Machine
There used to be enough steam to froth milk for 2 cups of coffee, now I have to turn the knob off, to let the machine build up steam 3 times too get enough froth for 1 cup of coffee.
This a
clear problem from scale builds up in the boiler. The scale layer is acting as
an insulation layer which is reducing the efficiency of the heating element to
the boiler and also reducing the water capacity thus also the steam production
capacity.
So you
should first try to de-scale your machine three four times with intervals of
three days from each de-scale. Try also to perform the de-scale very slowly
like when you will flash the water solution from the water reservoir take about
30 minutes why drawing a coffee cup every five minutes. With this way you have
very good chance to remove a lot of scale and you machine heating efficiency to
be increased. If after the above procedure you have no difference then you need
a new boiler which is one unit with elements and sensor.
Here below we
have a link with more information for your machine which can help you.
http://www.partsguru.com/SaecoMagicDeluxeSuperautomatica.html
Dec 23, 2010 | Saeco Magic De Luxe Espresso Machine
Boiler not cutting out
hi thermosat or the water valve is staying open allowing the gas to flow at full rate when water is off hence the steam , boiler is very broken call a gas fitter to fix it .
May 06, 2010 | Heating & Cooling
My astoria aep2 boiler seems to be running a lot. Is 20 seconds every 2-3 minutes too much. Could I have a leak. I can't hear one but would the steam wand valve cause this or could the thermometer be...
Three thing can cause this problem.
First is as you mention the air valve is leaking and is only due to its 'o' ring which can be replaced or replace the whole air valve. Not any steam should be leak from it at all.
Second during winter the water supply is much colder than summer so every boiler refill then boiler heating automaticaly switch on.
Third also during winter the room temperature is lower so the boiler is cooling down faster than summer since their in not any insulation around it.
If the presurestat which control the temperature inside the boiler become more sensitive because of years of work this is not actualy a problem since is use the same energy but now in more times and more frequent but for less time each time. Unless it stuck and either you have continues heating with no stop or stuck at alway off so the machine is always cool no need to replace pressurestat.
Feb 04, 2010 | Astoria Argenta AEP-2 Coffee Maker,...
Tefal Pro Express Steam Generator doesn't.
OK... so I have fixed my problem of NO STEAM, just lots of water coming out of the iron press plate itself... I had already cleaned the boiler, so I tried adding 1/4 tsp - 1/2 tsp bicarbonate soda to the water and flushing it through. From what came out of the iron press plate, I would say the problem was caused by a build up of goop (technical term) inside the iron. Once cleared, the iron is steaming away again. Please note, u will need to have an old towel handy if this is ur problem, 'cos until it starts getting better, there is a fair amount of water coming out of the iron press plate. Just add the bicarb to the water reserve and use the steam buttons to bring the bicarb through. Do not attempt to iron clothing with the bicarb in the water!!! Carolyn ;)
Nov 12, 2007 | Tefal Ultraglide 1549 Iron
Heating & Cooling Logo
24 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
