Question about Yard Machines Garden
Mcculoch mt 300mcculoch petrol strimmer carb two adjustable screw bolts ones for petrol, ones petrol & air mixture hich one does which
  • 183 Answers
Actually both screws are for petrol mix. The screw closest to the engine is the Lo side. Lo side jet provides petrol at idle and during the ramp up to speed. Hi side jet (closest to air filter) only effects the mix at high speed.
From McCulloch, these were set at 1 1/4 turns out.
Posted on Sep 16, 2010
Why does the engine only run at full choke?
You're not telling us anything about its history or other symptoms. Given that, it's got fuel delivery problems, to possibly include: clogged fuel filter, cracked or collapsed fuel line, leaking purge bulb, clogged carb screen, stiff or leaking carb diaphragm or loose carb mt bolts, for starters. Replace lines, bulb & filter & rebuild carb first, in that order. Pay close attention to fuel line routing- take pix. You'll need a special tool to adjust carb mixture- Husqy carb tool
Jul 08, 2014 | Poulan Pro Chain Saw 46cc 20"
ADJUSTING CARB ON A YZ 450 F
Hi, Anonymous the carburetor throttle shaft wheel has two cables the cable closest to the right side of the bike is the throttle cable and the one closest to the left side is the idle cable. Right about the middle between the two is the idle adjustment bolt it faces out towards the air filter end of the carb . The engine should be at operating temperature with the enrichener off to set the idle between 950-1050 rpm. Turn the idle adjustment bolt clockwise to increases idle speed and counterclockwise to decrease idle speed. If you have access to your air fuel mixture bolt you may adjust it as well if not there is a video below on how to gain access, make sure you start with clean or new spark plugs. Gently turn the air fuel mixture bolt clockwise until it starts to bottom out "STOP" do not over tighten as it will damage the taper on the end, now back it out 2 full turns to establish a starting point start the engine and check the idle rpm's and adjust the idle adjustment bolt accordingly for 950-1050 rpm if necessary, adjust the air fuel mixture bolt 1/4 turn at a time and let the engine settle for about 10 seconds, clockwise for a leaner mixture and counterclockwise for a richer mixture you are seeking the highest rpm your air fuel mixture bolt can acquire without going past 3 full turns from bottom then readjusting the idle adjustment bolt back down to 950-1050 rpm If you can not detect any rpm change and can not stall the engine by turning the air-fuel mixture bolt all the way in then your pilot/low-speed jet is too big. Final adjustment should be made with a clean air filter mounted to the carburetor. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
Yamaha YZ450F story about fuel screw
How To 4 Stroke MX Fuel Screw Adjustment YZF CRF KXF RMZ FCR Part 1 of 2
Yamaha YZ450F Owner Service Manual
OEM parts for Yamaha
Yamaha YZ450F Owner Manual
Apr 04, 2014 | 2003 Yamaha YZ 450 F
1998 air screw setting
how to adjust yamaha yz125 carb
Yamaha yz125 carb adjustments
Yamaha YZ125N1 Service Manual
http://mybikemanuals.com/yamaha/yamaha-yz-owners-manuals
Jan 13, 2014 | Yamaha YZ 125 Motorcycles
2001 Yamaha XVS 650 Dragstar carburetor adjustments
Hi, Samtburke the carburetor throttle shaft wheel has two cables the cable closest to the right side of the bike is the throttle cable and the one closest to the left side is the idle cable. Right about the middle between the two is the idle adjustment bolt it faces out towards the air filter end of the carb. The engine should be at operating temperature with the enrichener off to set the idle between 950-1050 rpm. Turn the idle adjustment bolt clockwise to increases idle speed and counterclockwise to decrease idle speed. If you have access to your air fuel mixture bolt you may adjust it as well if not there is a video below on how to gain access, make sure you start with clean or new spark plugs. Gently turn the air fuel mixture bolt clockwise until it starts to bottom out "STOP" do not over tighten as it will damage the taper on the end, now back it out 2 full turns to establish a starting point start the engine and check the idle rpm's and adjust the idle adjustment bolt accordingly for 950-1050 rpm if necessary, adjust the air fuel mixture bolt 1/4 turn at a time and let the engine settle for about 10 seconds, clockwise for a leaner mixture and counterclockwise for a richer mixture you are seeking the highest rpm your air fuel mixture bolt can acquire without going past 3 full turns from bottom then readjusting the idle adjustment bolt back down to 950-1050 rpm If you can not detect any rpm change and can not stall the engine by turning the air-fuel mixture bolt all the way in then your pilot/low-speed jet is too big. Final adjustment should be made with a clean air filter mounted to the carburetor. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
Pilot Mixture Screws Star 1100 Wiki Knowledge Base
Synching the Star Carbs
http://braindump.donfick.com/media/9d/Yamaha%20v-Star%20650%20Shop%20Manual.pdf
YAMAHA XVS650 Owner Manual
May 27, 2013 | 2001 Yamaha XVS 650 Dragstar Classic
How to set my idle mixture screws on 2000 r1
Hi, Merlin the carburetor throttle shaft wheel has two cables the cable closest to the right side of the bike is the throttle cable and the one closest to the left side is the idle cable. Right about the middle between the two is the idle adjustment bolt it faces out towards the air filter end of the carb . The engine should be at operating temperature with the enrichener off to set the idle between 950-1050 rpm. Turn the idle adjustment bolt clockwise to increases idle speed and counterclockwise to decrease idle speed. If you have access to your air fuel mixture bolt you may adjust it as well if not there is a video below on how to gain access, make sure you start with clean or new spark plugs. Gently turn the air fuel mixture bolt clockwise until it starts to bottom out "STOP" do not over tighten as it will damage the taper on the end, now back it out 2 full turns to establish a starting point start the engine and check the idle rpm's and adjust the idle adjustment bolt accordingly for 950-1050 rpm if necessary, adjust the air fuel mixture bolt 1/4 turn at a time and let the engine settle for about 10 seconds, clockwise for a leaner mixture and counterclockwise for a richer mixture you are seeking the highest rpm your air fuel mixture bolt can acquire without going past 3 full turns from bottom then readjusting the idle adjustment bolt back down to 950-1050 rpm If you can not detect any rpm change and can not stall the engine by turning the air-fuel mixture bolt all the way in then your pilot/low-speed jet is too big. Final adjustment should be made with a clean air filter mounted to the carburetor. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
http://www.r1-forum.com/forums/4-mechanical-help/2215-my-two-cents-carb-idle-mixture-screws.html
R6 Carburetor Fuel Mixture Adjustment
2000 2001 Yamaha YZF R1 Service Manual R1 Moto Data Project
Apr 13, 2013 | 2000 Yamaha YZF-R1
How to adjust idle on fj 1200
FUEL MIXTURE SCREW ADJUSTMENT PROCEDURE
Carb tunning
Yamaha 1992 FJ1200 Service Manual
http://mybikemanuals.com/yamaha/yamaha-fj-owners-manuals
Nov 16, 2012 | Yamaha Motorcycles
How do I adjust the carburetor mixture screws on a 2001 yamaha ttr 125L
Hi, Anonymous the carburetor throttle shaft wheel has two cables the cable closest to the right side of the bike is the throttle cable and the one closest to the left side is the idle cable. Right about the middle between the two is the idle adjustment bolt it faces out towards the air filter end of the carb. The engine should be at operating temperature with the enrichener off to set the idle between 950-1050 rpm. Turn the idle adjustment bolt clockwise to increases idle speed and counterclockwise to decrease idle speed. If you have access to your air fuel mixture bolt you may adjust it as well if not there is a video below on how to gain access, make sure you start with clean or new spark plugs. Gently turn the air fuel mixture bolt clockwise until it starts to bottom out "STOP" do not over tighten as it will damage the taper on the end, now back it out 2 full turns to establish a starting point start the engine and check the idle rpm's and adjust the idle adjustment bolt accordingly for 950-1050 rpm if necessary, adjust the air fuel mixture bolt 1/4 turn at a time and let the engine settle for about 10 seconds, clockwise for a leaner mixture and counterclockwise for a richer mixture you are seeking the highest rpm your air fuel mixture bolt can acquire without going past 3 full turns from bottom then readjusting the idle adjustment bolt back down to 950-1050 rpm If you can not detect any rpm change and can not stall the engine by turning the air-fuel mixture bolt all the way in then your pilot/low-speed jet is too big. Final adjustment should be made with a clean air filter mounted to the carburetor. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have wonderful a day.
Stock TTR125 Carb Screw Settings
Ttr 125 Carb Idol settings
YAMAHA TT R125 Owner Service Manual
YAMAHA TT R110E Owner Manual
Apr 30, 2012 | 2002 Yamaha TT-R 125 L
Petrol strimmer,, spark at plug,, petrol & 2
I have a flymo 430 petrol strimmer and cannot start it. ive cleaned the filter, put in new plug it went first time and then stopped and wont start again the plug seems to get wet all the time any ideas
Jul 03, 2011 | McCulloch Heavy Machinery
I just put on a new rebuilt carburator on my 460 v8 1987 xlt 250 ford truck 4 WH. drive. its a motorcraft stock holley. I cant seem to find a way to ajust it. Wont run smooth or idle? It was set up for...
You have two setting screws on front of carb, You start off by adjusting all the way to the left, Then back off 3/4 turn to both setting screws, Then you have to set your air fuel mixture by just slowly turn your setting clock wise do so until vibration go away. Sorry there is no easy way to explain, Good luck to you,
Apr 03, 2011 | Ford F-250 Cars & Trucks
How can I adjust the mixture on my Briggs & Stratton carburetor?
there isnt a true mixture screw on most of the walk behind mowers.
All you can do is remove the main jet *(its actually the bolt you remove to take off the carb bowl!) and clean out the passages in it. Be sure to clean the very small jet at the top of the threads. It is so tiny you will need a magnafying glass and a wire brush cleaning to see it.
Old style carbs had bottom screws with adjustable jets in them. If your equipment is old enough you might see one of these. Otherwise it is just a hollowed out bolt.
You could also adjust the float level....increasing float level will richen up your mixture. It also sometimes improves priming.
Good luck and be careful
Jul 14, 2010 | Briggs & Stratton Garden
Garden Logo
596 people viewed this question
Top Yard Machines Garden Experts
dannydoesita
Phil Walker
Phil Walker
Dean Gruber
Are you a Yard Machines Garden Expert? Answer questions, earn points and help others
