System we have here at work has BSOD 2x with xeskmdrv.dll error 50 blue screen - lookin for reason/solution on this
    Guru:
  • 1,082 Answers
As you probably know, this is a Xerox printer module. Below is more info on Stop 50 but in general, you might try reinstalling the printer with the latest drivers.
Stop 0x00000050 or PAGE_FAULT_IN_NONPAGED_AREA
The Stop 0x50 message indicates that requested data was not in memory. The system generates an exception error when using a reference to an invalid system memory address. Defective memory (including main memory, L2 RAM cache, video RAM) or incompatible software (including remote control and antivirus software) might cause Stop 0x50 messages.
Possible Resolutions:
• If you added new hardware recently, remove and replace the hardware to determine if it is causing or contributing to the problem. Run diagnostics software supplied by the hardware manufacturer to determine if the component has failed.
• Stop 0x50 messages can also occur after installing faulty drivers or system services. If the file name is listed, you need to disable, remove, or roll back that driver. If not, disable the recently installed service or application to determine if this resolves the error. If this does not resolve the problem, contact the hardware manufacturer for updates. Using updated drivers and software is especially important for network interface cards, video adapters, backup programs, multimedia applications, antivirus scanners, and CD mastering tools. If an updated driver is not available, attempt to use a driver from a similar device in the same family. For example, if printing to a Model 1100C printer causes Stop 0x50 errors, using a printer driver meant for a Model 1100A or Model 1000 might temporarily resolve the problem.
Posted on Sep 16, 2010
Tip
Laptop keeps shutting down with a Blue Screen
That seems for no reason, you computer shut download displaying a Blue Screen frequently. Learning "what is Blue Screen" and "why it happen" is essential. laptop keeps shutting down with a Blue Screen due to various kind of reasons. However, we can pay attention to the most common causes. With basic learning, you can troubleshoot computer crash problem yourself.
There is a misunderstanding that Blue Screen is a virus. In fact, BSOD is is known as a colloquialism used for the error screen displayed by some operating systems. The cause could be hardware and software relate. Computer experts provide us a result that shows the average causes of Blue Screen.
50% are the results of software incompatible or corrupt.
30% caused by virus. In this case, your laptop always gets freezing.
Other causes should be system bug and hardware failure.
It is difficult to repair the hardware. You have no choice but replace it. Here, we only talk about the system bug and software problem. The diversity of the cause makes us confused. However, fixing registry error is the easiest way to solve the problem. Registry is the database of Windows. It was designed to manager computer setting. Everything happened on your laptop is relate to the registry. Fox example, virus programs install on your computer and modify the registry key making your PC very slow.
Laptop keeps shutting down with a Blue Screen? It is recommended to use a registry cleaner. The program will diagnose errors accurately and clean up them in seconds.
on Sep 15, 2010 | Computers & Internet
BLUE SCREEN
So many computer face this blue screen fetal errors on windows.
This error comes usually when there is problem in software or driver compatibility issue with hardware or operating system.
Also this error comes when there is bed indexing unit in hard drive.
You can solve this errors with following 2 methods.
(1)When you power up the computer press F8 key then enter in safe mode.
Then if you are able to enter in safe mode then uninstall driver or software which you installed recently and face this error.
(2)If you are not able to enter in safe mode Then you need to fix error on hard drive.For that you need windows disk or recovery disk.
Boot your computer with that disk
For that when you power up the computer press F1 or F2 "del" key to enter in bios.
Then go to boot menu and set first boot device as your cd or dvd rom.
Then save settings and exit bios.
Insert windows disk in cd /dvd rom.
Then it boot with that disk.Then you get this message "Press any key to boot from cd.."
Then press any key.
Then follow the procedure then enter in recovery console mode then type in prompt "chkdsk /r"
Then type "y"
Then it fix error on hard drive.
Then check if again you are not able to enter in windows then boot again and this time choose "R" option for repair previous windows " then it repairs old windows then it loads again old windows.
Thanks for using FixYa.
Jun 06, 2010 | Dell Dimension E520 PC Desktop
Blue screen on my hp
For nontechnical people who need a solution on how to fix the Blue Screen of Death,there is no simple answer to that.
TheWindows operating system constantly refers to the registry to get informationabout all of the components such as hardware and software which are installedon the computer. The registry tells Windows what to do and how to access thevarious programs, files, and processes.
However,the registry can contain bad information which sends Windows off doing uselesstasks or running unneeded routines. Sometimes errors occur including the bluescreen of death. Other times the system slows down. Because of the sheer numberof factors that can affect the registry, there’s no one size fits all approach.You can’t just go into the registry and remove the bad information because it’snearly impossible to decipher which information is good and which informationis bad. That’s a job better suited for software.
Apr 26, 2010 | Computers & Internet
I hav an acer 5230e ,i want to install window xp but on window setup it shows blue screen error nd appear plz remove newly installed drive nd chkdsk on run /////////////tell me wht i do?
heeey dude ! I had the same problem.. and I just solved out how to fix the problem !.. the only thing you have to do is: Go to your Bios, and switch from SATA to IDE, and then it will be fine :-)
Apr 05, 2010 | Acer Computers & Internet
Blue screen Technical information stop: 3A0x00000024 280x00190203 2C0x81B599F8 2C0X0000102 2C0x00000000
Then press any key.
Then type "y"
Mar 04, 2010 | Dell Inspiron 2200 Notebook
Blue screen caused by SPCMDCON.SYS STOP:0x000000050 (0xfd3094c2,0x000000001, 0xfbfe7167, 0x000000000) M/c rebooted and blue screened again after about 5 mins this has gone on for an hour before I gave up
Then press any key.
Then type "y"
Feb 16, 2010 | Microsoft Windows XP Home Edition
Blue screen of death presario v2000
Then press any key.
Then type "y"
Feb 11, 2010 | HP Compaq Presario V2000 Notebook
Proxy host error BSOD on PH32DSP.dll
Many Windows 7 users are facing BSOD (Blue screen of Death) error.
Follow the below steps to resolve the error.
1. Startup in safe mode (tap the F8 key on your keyboard repeatedly as the computer is starting up)
2. Select a method of safe booting from the menu (first try with networking; if the crash still occurs, try without networking)
3. Once the system has booted, click the Start button and type MSCONFIG then press enter in Windows Vista (in Windows XP, click the Start button, then click “Run” and type MSCONFIG then press enter).
4. Go to the Startup tab.
5. Disable Kaspersky and any related items (e.g. kl1.sys), then press OK, then restart the system if it does not happen automatically. Startup normally (i.e. not in safe mode).
Alternatively you can launch the Kaspersky application and set it to not start at startup.
Aug 03, 2009 | Funk Software Computers & Internet
Computers & Internet Logo
70 people viewed this question
David Payne
David Payne
