Question about Logitech Z-2300 Computer Speakers
Everything is plugged in and this morning the simply woul;dnt work i cant get any sound from the speakers either, do you have any tips
    President:
  • 2,571 Answers
Has something changed your default playback device?
USB devices can sometimes do this.
Right click on the speaker icon in system tray, or go to sound properties in control panel
Posted on Sep 16, 2010
Speakes dnt work on the rh side wen putin cd on wen putin aux in dnt work on the lh side wen radio on they all work
check the connection to the speakers at the speaker otherwise you may need a new sound card in the computer itself...
Feb 13, 2011 | Audio Players & Recorders
Dimension 4700 my headphones work fine but i cant
Are you have the headphones and speakers both pluged in? When you plug in headphones the speakers get muted. You need to change your sound settings back to your sound card if you use usb headphones. The plug on the front of the 4700 also automatically mutes the speakers.
Dec 13, 2009 | Dell Dimension 4700 PC Desktop
My sound hardware work but i dnt hear nothink in my output speack
Question: Are your speakers plugged in and turned on?
First check the hardware of your speakers, that they are plugged in, to the proper speaker port. then check the device manager to see if it recognizes the sound card /speakers, it not then go to add hardware app and run it , remove sound card and replace it with windows Plug and Play running. if it recognizes it then run your program to see if the sound is playing. Good luck hope this solves your problem.
Jul 12, 2009 | Computers & Internet
I cant hear no sound on my 6300 even thow i buyed a new speaker an fitted it in it still dont work
Please get sound IC changed from your authorized person to get the best original quality sound.
Apr 23, 2009 | Nokia 6300 Cellular Phone
,I cant find any sound in my pc
first touch and input of your speaker which is the tip of the cable aside from the power chord and higher the volume, if the speaker produce sounds, means your speaking is working fine. now try to uninstall and reinstall the driver of your speaker. see if it works,
Jan 13, 2009 | Computers & Internet
I cant plug in my ps2 to my tv!!
Soi didnt exactly fix this but basically i figured out that the ps2 is simply too old for that new tv. when i plugged in a newer system it worked just fine so i guess ill just have to deal.
Dec 13, 2008 | Panasonic PT-43LC14 43" Rear Projection...
Help with speakers!@!@!@@!!
The odd plug coming out of the speakers is to connect to a power adapter to power the speakers, the other is to plug into the output plug of your sound card. Normally this is color-coded on the back of the computer in a light green colour.
Dec 05, 2008 | Dell AS500 Sound Bar Computer Speakers
No sound from speakers
Believe it or not, not all speaker plugs, even if they are of the same size are NOT made the same.Some times the "male" PLUG pushes into the "female" socket in such a way that it makes NO connection or does not make the right connection causing the headphones not to work.
TEST: play music that u can hear through the internal laptop speakers, and while the music is playing, plug in the headphones.
The internal speakers SHOULD cut out, and under normal conditions the music should pass through the headphones.
If the speakers cut out and the headphones don't work, your plug is damaged.
If the speakers DON'T cut out after u plug in the headphones, your plug is open.
Depending on the audio circuit, your audio amp. inside the laptop is going to get damaged.
It depends on the WAY the audio circuit was made.
May 15, 2008 | Audio Players & Recorders
My logitech usb headset dnt work
your program is probably set to use the wrong input for the mic, check your settings.
Dec 27, 2007 | Logitech 250 Headset
Cd Player Lights Up No Music Coming Out Of Speakers
try resetting it, open faceplate, with pen tip ,press reset button
Sep 08, 2007 | Sony CDX-C5000X
Logitech Z-2300 Computer Speakers Logo
27 people viewed this question
Top Logitech Audio Players & Recorders Experts
Henry  Thomas
Henry Thomas
JP Services
JP Services
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
