Question about Samsung Office Equipment & Supplies
ML 1610 wont pick up paper. - Samsung Office Equipment & Supplies
  • lizgormail_r Sep 17, 2010
    I have tried your suggestion but still the paper is grabbed and then jams. So this did not solve the problem. Any other ideas?
  • Samsung Expert
  • 2,973 Answers
There is a paper sensor that works when the new sheet is to be pulled in. Please clean the area just below the lower roller and also the rollers, both upper and lower with a moist (not wet) soft cloth or tissue.
Posted on Sep 16, 2010
Doesn't pick up[ paper
Possible that the intake detect or the pick in rollers are not aligned properly . You need to check the opto-couplers and the roller settings.Remove and check with a paper to see the uniformity of the gap between the rollers.
Jan 20, 2012 | Samsung ML 1610 Laser Printer
Paper didnot pull or paper jam
I had success on a canon printer by taking a can of air and blowing out the paper receiving area. It started picking up paper and no longer saying there was a jam. I think I must have had dust or a piece of paper blocking sensor.
Dec 21, 2011 | Samsung ML 1610 Laser Printer
Hi my samsung ml-1610 mono laser printer shows red light contineously i dont know what the problem is can u help me please
see, you have inserted the paper well. if not solved, your catridge have low ink or empty. so bring a new catridge or if you can, refill the catridge. 1610 catridge can be easily refilled.
Aug 27, 2011 | Samsung ML 1610 Laser Printer
The Samsung ML1610 picks up paper and stops half way. If I hold the end of the paper and push as it picks up it will then print. I have cleaned as well as I can, but access iis difficult.
This problems occured two sence
1.Problem on LSU(Laser unit dirty need clean)
2.Problem on cartridge.
You can check it change your old cartridge.
Tareq Bin Mostaq
Bangladesh
Aug 13, 2011 | Samsung ML 1610 Laser Printer
How tha cheng samsung ml 1610 pickup rollor
maybe you mean How to change paper pickup roller?
If YES - follow this simple steps:
  1. Open front cover
  2. Remove toner cartridge
  3. Look for two plastic pins (left and right side of the roller) on top.
  4. You have to use flat screwdriver to unlock this pins but be careful to avoid any damage on it.
  5. The trick is to unpin left and right pins at the same time.
  6. To turn back this roller you have to put first bottom pins then press the roller up until you hear a sound as click.
Warning:
Be careful with tire direction, if you turn it with wrong direction printer does not pick up the paper!!!
Good luck!!!
Mar 21, 2011 | Samsung ML 1610 Laser Printer
Paper not getting inside the samsung Mono laser printer ML-1610
The paper pick up fingers and rollers get smooth and polished with use and then slide on the paper. Clean the rollers and pick mechanisms with isopropyl alcohol to rejuvenate them and restore their grip on the paper. Do this as far along the paper path as you can get, using Q Tips where necessary and turn the rollers to clean their whole surfaces.
Mar 05, 2011 | Samsung ML 1610 Laser Printer
My samsung ml-1610 printer always getting paper jam on print job. Is this problem related to fuser or something else? please help me...
There are a series of rollers which are made of rubber in the unit. When these rollers become dry or covered with dust (usually from cheap paper) they arent able to pick up paper correctly any longer.
Think of it as though you are trying to turn a page, and you have to lick your finger to do so.
Its the same concept. When your printer grabs the paper, it cannot hold it while it is rolling it through the printer.
There are kits available through your manufacturer or a local print shop which can clean your printer and help to restore it to its working order.
Hope this helps!
Feb 23, 2011 | Samsung ML 1610 Laser Printer
Why the printer is taking more papers at a time and gets jammed. I am using 75 GSM paper
This is caused usually by dirty or faulty/worn out rubber paper pick roller. Try gently cleaning it with damp soft lint-free cloth. Moreover, it is better to use 80GMS paper.
Hope this helps!
CreativeTECH
Dec 09, 2010 | Samsung ML 1610 Laser Printer
The paper has jammed in my ML-1610 printer.
The paper jams mostly, because the rubber band that feeds the paper to the printer is broken/split. Check the rubber band. It's located within the plastic wheel that feeds the paper.
Mar 09, 2009 | Samsung ML 1610 Laser Printer
51 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
