Question about Kenmore Vacuums
Hi ! I have a Kenmore central vacuum (model # 34326), 3 inlet valves on different floors. the inlet valves on the second and third floors are already connected. I need to connect the inlet valve located in the basement near the vaccun cleaner. There is one cable on the third floor with 4 wires, black and red on one screw and yellow and green on the other. This is OK. There are two cables on the second flloor, The black and red wires of the two cables are connected together on the same screw and the yellow and green wires of the two cables are connected together on the same screw. This is OK I have two electrical cables in the basement one has a red and black wire and is directly connected to the vaccum. The other coming from the second floor has a red,black,green and yellow wire and must also be connected to a central vacuum inlet valve. I must attach the wires to two screws located on the inlet valve but I can't seem to figure out how to connect the different wires together. Thanks for your help.
  • Kenmore Master
  • 1,420 Answers
By your description it seems that You have telephone wire used. You only need two low voltage wires to complete the circuit to turn on the power to the central vacuum unit. The low voltage wires must be arranged so that when you insert the hose into any valve it closes the circuit. You will wire it as if the black and red are just one wire and the green and yellow are the other, they are actually doing exactly the same as if you only had two wires.
Posted on Mar 05, 2017
  • 1073 Answers
SOURCE: how to connect a 220 stove with 2 110 cables
cannot be done you would be using the same side of the line and it would be a direct short
Posted on Apr 27, 2008
SOURCE: Kelvinator Stove Power Cable Connection
You should unscrew the small back panel, on the undercover should be a scetch of the wiring.
If not the three red are live, black is neutral and the g/y is earth, from number 5 to 1 connect as follows: 5 and 4-black,3,2,1 red and look for a screw type fitting or green wires to connect earth.
Its important to connect earth before operating the stove as it cuold lead to serious injury if not connected.
Hope this helps
Posted on Nov 23, 2008
  • 5911 Answers
SOURCE: 3 prong to 4 prong.
The following link will explain this for you:
As stated in the link, the WHITE wire from the power cord should be connected to the other WHITE wire at the terminal block and NOT grounded to the equipment frame. The neutral wires are to be connected at the terminal block only. The extra white wire you mention, may be a jumper wire that originally jumpered the neutral to the equipment frame from the 3-wire configuration. This wire may be reconnected to the frame with the GREEN (ground) wire from the power cord. I hope this helps you. If you still have questions, please let me know.
Posted on Jan 04, 2009
woobie dog
  • 1273 Answers
SOURCE: I need to install a kenmore range. the wires
Hello, Here's how to hook it up:
Black from wall to black at stove.
White from wall to red at stove.
Copper from wall to white and green at stove.
Hope this helps. --W/D--
Posted on Jul 31, 2009
  • 5 Answers
SOURCE: how to wire in a honeywell 9400c timer clock 4 ch
One of these wires is contains permanent live, neutral and earth. The other wil be heating on and hot water on, the earth on this wire will probably not be used.
you will have to trace the wiring back or test it!! Be carefull!!
Posted on Nov 04, 2010
Wand attached to hose - how do you detach? Kenmore central vacuum system model s107 34730
Many central vacuums have similar or the same parts made by a small number of manufacturers. I found the MD Central Vacuum website to be very helpful and I hope it solves your problem. I have attached pictures and descriptions from their website so you can see if this is what your wand looks like. If so, to separate the wand from the floor brush unit there should be a lever or button on the brush housing you can push with your foot to release the wand. If you are asking about where the wand connects to the hose you push that black button that you see at the top of the wand in the picture, the top smaller black part. I hope this helps.
Sep 08, 2017 | Kenmore Vacuums
My central vac is in the basement, I am getting suction in the basement, but no suction on the main floor and the second floor. How do I know if somehting is blocking it or if there is a hole?
That means that you have a clog in the lines where the basement inlets are connected to. They can be tough to get out, you might need to call a professional.
Jan 10, 2010 | Electrolux Central Vacuum
Central Vacuum works when power switch on canister is turned on, but will not turn on when connecting the hose.
DOes it not work on any of your wall inlet valves? If all wall inlets appear dead take a coin making a connection with both of the contacts inside the throat of the valve. If the vacuum turns on the problem is in your hose or the powerhead. If nothing happens plug in your hose and try wiggling the low voltage wires at the vacuum as you leave the hose plugged in with the swich on your in the "on" position ( if you have a switch) If still nothing unscrew all valve plates from wall leaving wires attatched. Inspect all connections for loose wires or wires that have come off terminals. .
Nov 09, 2009 | Kenmore Vacuums
My electrolux central vac outlets work on the main
You might have a plug or clog in the upstairs lines. for information on how to remove a clog in a central vacuum system see this article:
Oct 24, 2009 | Electrolux Central Vacuum
I have a Nutone central vacuum model number CV450W that was working great until I recently removed the hose and it now runs continuously until I pull the plug....any suggestions please
Disconnect the thin low voltage wiring between the vac and the rest of the house. If the vac continues to run you have a defective relay in the vac motor housing.
If the vac stops you have a short in the wiring in the house, likely behind an inlet in the wall.
If any inlets have been disturbed for painting or renos lately that would be the first spot to look in the house for a problem. Look for wires behind the inlet valve which are touching against each other or a mounting screw or against a metal mounting plate behind the inlet. Start at the last inlet used. Be careful not to loose the spring under the screws where the wiring attaches to the inlets
Oct 08, 2009 | Broan-NuTone CV450 Central Bagged Central...
Nutone 353 central vacuum....all of a sudden, poor suction at all house outlets.. Checked hoses and pipes for obstruction...none found
I think this unit has a utility valve on the front. If so, do you have good suction at this valve? If not, disconnect the inlet piping and check the suction directly from the inlet. Make sure the utility valve is closed while checking the suction on the inlet. If you have good suction, you have an open pipe or valve somewhere in the house. If you have any vacpans, check these first. Next, turn the unit on and walk through the house and listen for air whistling. If you do not have good suction from the inlet at the unit with the utility valve closed, replace your bag and look for a secondary filter that may be plugged. Good Luck!
Nov 26, 2008 | Broan-NuTone CV353 Central Vacuum
De clogging pipes
You can try these as long as you have some airflow. If you have no suction or airflow from one particular inlet, you can reverse the main unit by hooking the inlet piping to the exhaust of the unit. Tape all other inlets closed, and turn the unit on. This should blow the clog out through the inlet door. (be prepared for a some mess with newspaper or something else to protect your floor in front of the inlet) If you still can't unclog it, borrow a portable canister vacuum or a shop vac and try to **** the clog from the inlet while you blow from the other end with your central unit. Good Luck!!
Sep 08, 2008 | M&S Systems AirVac AVP1200 Platinum Series...
Disconnect the inlet piping from the unit and check the suction there. Be sure that the utility inlet on the unit is closed. If you have good suction, you have an open/broken pipe somewhere, or possible an inlet valve or vacpan that is not sealing when closed. The easiest way to find it would be to install your tubing back into the inlet of the unit, turn the unit on, and walk around the house listening for air leaks. Good Luck!!
Jun 29, 2008 | Broan-NuTone CV353 Central Vacuum
No suction on lower level
Generic problem for all Vacuums
Posted by phil55555 on Apr 23, 2008
Nutone central vac
no suction on lower level second floor fine
ran fish tape but it does not go all the way through,
do i need to take pipe out.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
Not @ first, try to get a central vacuum cuff and go to each and every inlet / outlet down the basement and put the cuff in the inlet – the central vac should come on and possibly might unclog the pipe, 2nd, try taking another canister type vacuum while the central vac is running and open the inlet door and try to “pull apart the clog in the pipe” – this does work upon occasion if not you can try a plumbers snake – but be careful because the walls of the pvc pipe are thin wall and you don’t want to poke a hole in the pipe or other wise you will have to replace the pipe. The absolute last resort should be to replace the pipe if all other do not work. Feel free to contact your local vacuum dealer in your area or in the yellow pages , or contact the factory @ the phone #’s listed below: --- Customer Service
NuTone Inc.
9825 Kenwood Road Suite 301
Cincinnati, OH 45242
In U.S.A. call:
1-888-336-3948 for Customer Service
1-888-336-6151 for Technical Support
In Canada call: 1-888-882-7626
Thanks, Don – The Vac Man
Go Ahead. Use Us.
Apr 23, 2008 | Vacuums
Vacuums Logo
252 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
