Question about Alessi 9090/6
Steam escapes from the join
First time using the machine. bought new. instructions followed. steam escapes still.
anything I can do?
Some steam may escape even when the pot is put together correctly. However, make sure that the metal strainer disk is correctly nested in the thick rubber washer on the underside of the top piece, and that the washer is seated tightly and evenly.
Posted on Dec 12, 2009
Shark steam cleaner sc 505
you need a new seal to put on the lid
Mar 17, 2014 | Vacuums
Cuisinart Brew Master 00wpc brews slowly with most water escaping as steam
Try cleaning with white vinegar, using the method described in the owner's / instruction manual.
Jan 03, 2018 | Cuisinart Brew Central 12-cup Coffee Maker
Just bought the machine. Basically, the problem is that the steam wand goes of on its own (or as soon as I push the coffee button) and that I cannot turn the steam handle at all or do anything to stop...
Hi. Make sure all your buttons are off. (switches all facing the same direction). Then make sure the tap is turned off. Switch main power on. Then switch the coffee on. you should hear the pump start. usually loud at 1st, then it will get quiter as the water is pumped up through the group head. When water is pouring through the group head, switch off the coffee button. Now let it finish heating. If you can get to this stage, then everything is ok. If you cant get it to this stage then you have a problem with the machine. Most likely a themostat on the boiler. Darryn REPAIRER
Sep 22, 2011 | Rancilio Silvia Espresso Machine
We have a La Pavoni epg-8 Latte machine. When I turn it on steam escapes through the cap of the boiler. We have only used it about a dozen times, so its practically new. the O-ring appears to be in good...
I am an engineer that services these machines on a daily basis. Good news - you are not missing anything at all. The type of cap you have, has a safety release valve built in which will be the hissing sound. If you fill the boiler as normal, turn on the machine and allow to boil up as normal and if steam starts hissing out and does not stop then just give it a light tap and this should stop. Basically when these machines are new the spring inside sticks and once you have tapped it a few times to release it, it should loosen it up and it will give a brief hiss then stop as the machine heats up. I hope this helps but if you have any further questions you can get me at domesticespresso@live.com
All the best
Mr La Pavoni
Jan 05, 2010 | La Pavoni EPG-8 Espresso Machine
I have a brand new Classic and can't clear an airlock by following the advice in the instruction manual. Is the unit faulty?
Try to clear the airlock by having the steam knob open at the same time as the coffee switch is on.
This allows any air to come out of the group head and the steam arm.
Dec 22, 2009 | Gaggia Classic Espresso Machine
Decalcify - does the machine need to be serviced or can i do it myself
Hi
Go to your menu in the machine. Use your up arrow to go to decalcify and push enter. Have your solution for decalcifing the machine mixed in your water tank. Have a large container under the steam wand and cappuccinator on the left. Then open the knob for steam. Machine will say "Machine descaling". It has to finish the whole tank before it says "descale finished". Now rinse the water tank and put fresh water in it and put back on machine. Now close knob and then reopen it. Machine will say "Rinsing" When that tank is gone, it will say finished. Put water in tank and then go back to your menu and go down 1 to reset descale. push enter and chose "Yes" and hit enter to lock it. Now go down to water hardness and hit enter. Cahnge the # to 4 and hit enter. Push the escape button 2 times and your back. and ready to go.
Apr 24, 2009 | Saeco Royal Cappuccino Espresso Machine
Steam escapes while machine tries to heat up
That big nut is the pressure relief valve. It should normally be closed, unless the machine overheats, in which case it will vent the steam, thereby preventing an explosion.
The valve design means that it's somewhat normal for some steam to vent as the machine heats up, but once it gets close to working temperature, it should seal.
Pavoni does now have a replacement valve that avoids this problem. When your machine needs a major service, hopefully more than 5 years from now, you may decide to get the upgraded valve fitted.
Fergus.
Aug 22, 2008 | La Pavoni "PROFESSIONAL Chrome" 16Cup
Alessi 9090/6 Logo
337 people viewed this question
Top Alessi Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you an Alessi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
