Question about Konica Minolta magicolor 1690MF All-In-One Laser Printer
Says "Caution Transfer Jam Open Cover" I open the cover and even restart it? Keeps showing up? Any help? Thanks Kurt
schmoody68
SOURCE: caution 2nd side cover is open
Hi Andeawo, It sounds like while moving the copier, you may have broken or bent a door interlock switch or the door actuator that depresses that switch. On the door that showing ajar, look for a small pin (could be plastic or metal) and see if it's bent or broken. If that appears fine, slowly close the door and look for a small hole where that pin would go through and depress the interlock switch. Once located, look to see if the switch is misaligned or broken. I'm thinking that one of these 2 items is the culpret.
Been a copier tech for 12 years and have seen my share of both. Let me know what you find...
Posted on Sep 29, 2008
SOURCE: top cover open error when printing
I had the same problem and fixed it by sticking the end of a pen (the writing part) in the hole on the right side when you open the top cover.
In other words if you open the top cover and look on the top cover you will see a tab that goes into a hole(the hole is next to the picture of the print cartridges). There is a hole with switch/tab(I don't know the proper terminology) on it that is activated when you close the top cover. If you stick the end of a pen in that hole it should activate something and the print cartridges will start to make noise and move around. You can then close the cover and it should close all the way.
You can then try to print a test page.
Good Luck
Posted on Dec 29, 2008
  • 48 Answers
SOURCE: KONICA MINOLTA magicolor 2490MF paper jam. It
I believe the duplex door is in the back of the printer.
Posted on Jun 01, 2009
devdeep545
  • 137 Answers
SOURCE: Dell 3000cn paper jam open reg cover
Don't take risk about your equipments. consult a enjineer.
Posted on Aug 09, 2009
  • 990 Answers
SOURCE: 1st side cover is open
Hello sir; Are you using duplex unit, check your duplex unit.
Posted on Oct 13, 2009
Card Jam Error 112 & 245
please calibrate the Lam Film sensor.error 245 is lam sync error please check Lam power/connections and restart the Printer.
Oct 02, 2012 | Fargo HDP5000-LC ID Card Printer...
Keeps showing follow instrctns in right cover to remove. Unable to copy
ther is a paper jam in the machine, open the side cover and remove the paper jam, if the paper is not visible then there is a small piece stuck somewhere.
Nov 17, 2010 | Ricoh Aficio 2015 Copier
I have a paper jam and it says to open the front cover, put the front cover just shows the ink cartridges and there is no visible paper jam. how do i find the jam and remove it? It's a canon image...
The paper jam could be in three places.
First:
Open the cover of fixing section, its above bypass, and check for jamed paper
Second:
Open the transfer cover, these cover has handle and it goes by pulling toward you, and check for jamed paper.
Third:
In hight of first paper cassette, on left sideway of copier, beaneath the bypass are small door, open it and check for paper jams. Be sure that you closed them properly because if they arent closed the check printer cover message will arrise.
Hope that helped
Jul 07, 2010 | Canon ImageRunner 1600 Copier
Error during 1st install of paper
konica minolta magicolor 1680mf service call 0094
Help me
May 30, 2010 | Konica Minolta magicolor 1680MF -...
How do I fix a paper jam? I've got paper jam around the exit roller and I can't get it out?
There should be a way to unlock one of the sides. Try taking out the toner cartridge and going in that way. If you can see the paper, get a pair of needle nose pliers and SLOWLY see if you can pull the paper out.
Sep 21, 2009 | Samsung CLP-510 Laser Printer
Dell 3100cn
the BTR cover is also called " Bias Transfer Roller " cover it should be that roller that seen when open the front cover most likely the Bias transfer roller door sensor in NOT detecting the dorr closed. make sure the tab isn't broken this will produce this error if it is.
Jul 23, 2009 | Dell 3100cn Laser Printer
Back cover open message on brother mfc 7820n
Had same problem. Closer inspection revealed bit of paper out of sight. Removed the toner cartridge and worked to free torn paper. Then restart. Hope it helps.
Dec 15, 2008 | Brother MFC-7820N Printer
http://www.fixya.com/support/t150137-one_more_person_back_cover_open_problem
Oct 24, 2008 | Brother MFC-7820N Printer
Paper jam
If the jammed sheet is entirely within the printer, remove the sheet as follows:
r_1.gif Make sure that the printer is turned off.
r_2.gif Open the printer cover by pressing the latch on the left side of the printer and lifting the cover up all the way.
r_space.gif r_warn.gif Warning: r_space.gif r_space.gif Opening the printer cover exposes the fuser, which is marked CAUTION Hot Surface Avoid Contact. Be careful not to touch the fuser. If the printer has been in use, the fuser may be very hot.
hppe004.gif 1. CAUTION Hot Surface Avoid Contact
r_3.gif Remove the developer cartridge.
r_space.gif r_caut.gif Caution: r_space.gif r_space.gif When removing the developer cartridge, never touch the developing roller under the flap; otherwise, print quality may decline.
r_4.gif Remove the photoconductor unit.
r_space.gif r_caut.gif Caution: r_space.gif r_space.gif Never touch the photoconductor unit's light-sensitive drum; otherwise, print quality may decline.
r_5.gif Remove the paper from the paper path.
r_space.gif r_note.gif Note: r_space.gif r_space.gif If paper is jammed at the fuser, grasp the bottom of the paper and pull it out.
r_6.gif Reinstall the photoconductor unit, and then the developer cartridge.
r_7.gif Close the printer cover.
r_8.gif Tap the edges of the stack of paper on a flat surface and carefully reload it into the MP tray. (Do not reload curled or wrinkled sheets.)
Printing automatically restarts from the page that jammed. If the Paper light stays on after removing all jammed paper, open and close the printer cover to clear the error.
Oct 16, 2007 | Lexmark X7170 All-In-One InkJet Printer
"Offline"
which cover are you opening? You must pull open the bottom cover not the one under the keyboard. It's the bottom front cover not the top front cover.
Sep 26, 2007 | Brother IntelliFAX 4100 Laser Fax
Konica Minolta magicolor 1690MF All-In-One Laser Printer Logo
361 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
