Ok, for the digital coaxial input, that is for receiving dolby digital audio. So you would output from whatever device you are using that has a digital coaxial to your receiver, then just make sure the device is outputting through the digital coaxial output and the receiver is set to use the digital coaxial input on the corresponding input chosen. Also I am not sure why you would need to connect a pc monitor to it, You wouldn't want to output to a pc monitor and you can't to a laptop. You could output the laptop to it but that again would be an unnecessary step as you would output from the laptop straight to the tv. If you need further assistance please let me know.
Thank you,
Lee
Refer to p.16 of the manual located at this link:
http://usa.denon.com/AVR3803_ownersmanua...
You may need the on screen display to change some settings if so just plug in the monitor out to the tv.
Thank you and enjoy,
Lee
Did you try my solutions?
Thank you,
Lee
The coaxil is for an anteanne like a tv. It is an input meaning from a device like an anteannae to the receiver. The video jacks can be used on a tv or vcr.
If both the receiver and laptop have s-video, you could go that way. Otherwise at amazon . com they sell an s-video to rca converter cable for about $3-4
hallo fisherman, Do You think a s-video to VGA may work ? And is there such converter cable to buy out there ? S-video to Denon and VGA to mini laptop
There are video and audio inputs to hook devices up to the receiver. Then there should also be audio and video outputs. Usually rca jacks to hook the receiver up to a tv or vcr.
I need a solution to switch from analoge to digital input for my Denon AVR 3803. I use my amp as a 2 channel amp. And I want to be able to use the da in the amp from the CD both as analoge with two RCA and with a coaxial digital input. Is there a solution to use a mini laptop without S-video or hdmi input. Or is there a way on the receiver to switch without any monitor.
Thanks for any help regarding this
My main problem is how " the receiver is set to use the digital coaxial input on the corresponding input chosen "
How do I do this without using a TV screen ?
Regards, Ronny
