Question about Kenmore 57029 Side by Side Refrigerator
Shelt stud broke. How to get out and replace with a new one
    Champion:
  • 202 Answers
Just drill it out be sure u can get a new one first ot just drill a small hole in the center and place a larger one over it
Posted on Sep 16, 2010
Jbl 75815 stud broke
First, it really depends on your car model. normally its easier to replace broken stud on the rear disk than the front if your car is a rear wheel drive. On the rear, the moment you remove your tires you only need to initiate impacts on the disk to loosen it and after removing the disk you can hammer the broken stud to dislodge it from its fitted hole then pressure fit the new one in place by hammering it in unless you have a machine that can do it. On the other hand, replacing broken stud on the front requires you more efforts as you need to detach other items like the disc plate cover, and if necessary dislodge the spindle assembly from the velocity joint to create space for the broken stud to be removed from its hole.
Aug 02, 2014 | JBL 2447H Driver
Wheel studs broke off
A shop can install new studs in a short time. The old studs can be pressed out or punched out, and new ones installed and drawn into a tight fit.
Nov 30, 2012 | 2000 Buick Park Avenue
How do you remove the Wheel hub from a 2003 Acura mdx awd? I broke a wheel stud while getting the tire off and now am trying to replace the wheel stud.
if memory serves,you should be able to replace wheel stud by hammering it out backwards/inboard.then replacement is a case of pulling new stud through.
May 11, 2010 | 2003 Acura MDX
I need to replace the studs on the front drivers side rotor, three of the broke off when I was removing the wheel to replace the brakes. What does it require?
The studs are in the hub behind the rotor and it has to be removed because the studs have to be driven out with a hammer (and punch when broken) and driven back in. When you buy the new studs, you'll see what I mean.
Oct 26, 2009 | 1998 Nissan Altima
Does the wheel barring have to be replaced when the stud is broke
If you use a hammer to drive the broken stud out you can cause damage to the bearing.
If you use a wheel stud press, the hub bearing will not be affected. The press will remove the old stud and install the new one.
Good luck.
Regards,
Aug 18, 2009 | Honda Civic Cars & Trucks
Broken lug nut stud on 98 civic dx coupe
knock it out... use an old nut that will fit the new stud and install the stud. the nut will pull the stud in tight to the flange.
Jul 19, 2009 | 1998 Honda Civic
Front wheel stud broke off
Knuckle needs to be removed and the center hub 'pressed out' using a hydraulic press (accepted procedure). You can avoid this by using an air hammer and disk cutting tool to remove the old stud, then trim the 'stop flange' on the new stud (1/4 moon cut) in order to install it.... however, you gotta know what you're doing so you don't compromise the integrity of the new stud.
Jul 04, 2009 | 2002 Hyundai XG350
I was trying to remove my front passenger tire & broke wheel stud
You just have to hammer it out. and rotate the hub so you can get it out. then put the new 1 on and tighten a lug on it till it's locked in
Jun 05, 2009 | 2005 Pontiac Grand Am
Broken wheel stud.
Studs are pressed in. Heat the studs with a propane torch, and then use a ballpein hammer to pound them out. Insert new studs, and use nuts to draw them into place
May 11, 2009 | 1996 Pontiac Grand Am
2003 hyundai elantra gls front wheel stud broke
grab a large punch and hammer and knock out the old broken one. Push the new one in and re tighten. This will pull it into place and because it has splines it should not spin while doing so.
Apr 05, 2009 | Hyundai Motor 2003 Elantra
Kenmore 57029 Side by Side Refrigerator Logo
32 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Jude24
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
