Question about Dishwashers
I have a GE Model#GSD433OZOOWW dishwasher, I am changing the color from white to black. I have ordered all the parts to do this but the insert for the eschutcheon is no longer available. Is there a safe way to remove the old insert? or should I just paint the plastic black? Thanks in advance
2 Suggested Answers
  • 246 Answers
SOURCE: GE Dishwasher GSD4020Z panel color change
Yes!!! Go to www.applianceart.com, they have white, stainless, and a ton of other options.
Posted on Feb 25, 2010
How do I replace jvm1490sd broken handle?
Disconnect, open door, remove screws from rear of door, dismantle door. Here's a diagram showing how it fits together.
01 Control Panel Door Grille Case Parts for GE JVM1490SD003
The part you need is #1801 on diagram
Microwave Door Handle
Color: Black. For white order WB15X10070. For bisque order WB15X10071. For the screws order WB01X10305.
by GE
Part Number AP3184331
May 19, 2014 | Microwave Ovens
Hello -- We own one of these KitchenAid dishwashers. Our model has a black exterior. We are thinking of re-doing parts of our kitchen. Is it possible to change the color of the main front panel? (Not the...
YES THIS IS POSSIBLE IF YOU ENTER YOUR FULL MODEL NUMBER ( YOU ARE MISSING SOME OF THE NUMBER) ON THE SEARS SITE THE ILLISTRATED PARTS BREAK DOWN WILL GIVE YOU CHOICES OF COLOR.
http://www.searspartsdirect.com
Apr 25, 2010 | KitchenAid 24 in. KUDI01IL - Multiple...
Need a part number
The part number for the door handle on this model dishwasher is either:
W10142998 (STAINLESS)
W10142999 (BLACK)
W10143000 (WHITE)
The handle is listed as item 14 under the "Door and Panel Parts" section at searspartsdirect.com. The part numbers are based on the color, so make sure you use the correct number to get the matching handle for your dishwasher. The kit inlcudes all the mounting hardware as well.
You can check these others sites as well to compare prices:
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
If you have any questions, please let me know. I hope this helps you.
Dec 29, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Can I buy a new door for my GE dishwasher?My dishwasher is white and all my other appliances are black. Can I just replace the door?
Most likely, yes, outer door panel at the least, plus you'd most likely replace the lower panel and trim parts. If the unit is not too old, those parts are probably available. If you list your full model number, I can try to give you an idea of what parts it would take.
Aug 28, 2009 | GE 24 in. GHDA960K Built-in Dishwasher
Would like to change white color to black or stainless
If your model number is correct you can find door panel parts at appliancepartspros.com. Type in your model number and look under Section 3, Door and Panel Parts for item 4. There are several different colors available including black and stainless. Make sure you select the correct part number. I hope this helps you.
Jul 19, 2009 | Whirlpool GU2455XTS Built-in Dishwasher
I have a GE nautilus dishwasher Model GSD4000N10BB that is white and I would like to replace the white door with a black one. Is this possible and how much will a new door cost?
hi, I believe it is possible to change the colors. I looked up your model # and found only black listed. I then changed the 2 end letters to "WW" and found the doors are white. If you would call C.E. Sunberg @ 1-800-621-9190, they will be able to confirm that this is possible.
I hope this helps you. Please let me know.
Thanks
Vic
Jul 13, 2009 | GE Nautilus 24" Built-in Dishwasher
Need new dishwasher replacement door panel in white model numberGSE3600G00BB Nautilus
here is a great site for getting parts cheap..(ggod quality...cheap prices)...and quickly....HOWEVER.....i did a parts check and I think you have a serial..# and not a model...#...I have learned over 35 years that GE...USED to use a WD..at the beginning of their model #'s...or DW...but they may not now....However the model # can be found on the inside of the tub wall on a metal plate...(or some kind of plate)...but the # you gave does not even pull up..a DW at all..the beginning part of the # pulls up a group of Electric ranges...but that's it...please check your model # again...I can help further if you get that...but with the site I provided you you should be able to find the part you need...If you want me to locate the exact part.....I will....provide model #...thank you and I hope this helps and thanks for rating my effort......Good Luck...The Fang.
http://www.appliancepartspros.com/
Apr 04, 2009 | GE Nautilus 24" Built-in Dishwasher
Sep 05, 2008 | GE 24 in. GSD4020Z Built-in Dishwasher
Front panel color
I have the use&care guide for this unit. It explains how to change the panels - I also notice in ebay that you can order generic stainless ones. I'm going to remove my white panel to install the stainless.
Jul 28, 2008 | Whirlpool 24 in. DU1100XTP Built-in...
Front door panel, stainless for GE dishwasher
Ebay has a guy selling stainless panels, cut to size; search dishwasher stainless panel
Jun 09, 2008 | GE Nautilus 24" Built-in Dishwasher
Dishwashers Logo
32 people viewed this question
Top Dishwashers Experts
Owen Barnes
