Question about Rio Carbon MP3 Player
More Rio Trouble >.<
Having fixed the sound i thought my problems were over, but i have a new problem :(
I was recently checking the tracks on my carbon from within RMM when i clicked 'play' on one of the tracks. The carbon just suddenly completely stopped and shut down; now it won't turn on at all. I have tried opening the back and securing the hard drive (in case it dislodged at some point) and using the reboot button however nothing I've tried has worked. Is the hard-drive permanently damaged and needs replacing?
I hope it doesn't need replacing as i have only recently found out how to back up the tracks i had on the carbon. A break will mean i have lost everything :(
If anyone can confirm if its completely broken or can still be salvaged, i would greatly appreciate it.
Regards, Nemp.
  • nempozpag May 19, 2008
    Well i tried taking the hard drive out an putting it back in and it now works... Perhaps it dislodged at some point although i'm mystified to be honest. I downloaded the 3.04 update which means if my scroll wheel ever dislodges again i will be able to control it manually.
    Also, since putting the hard drive back in, the battery life seems insanely low (about 5 hours- poor for a carbon) have i done somethin wrong?
    Guru:
  • 155 Answers
I presume that your computer does not pick it up at all.
Try taking out the hard drive carefully and putting it in a usb card reader. Then if it picks up, format it, put it back in your carbon. Your pc should then pick it up and then reformat it (may be needed) and reload the firmware (from: http://www.rioaudio.com/support/rio/product.asp?prodID=215)
If it doesn't pick up then your hard drive will be bust :(
for less than a 10er you can buy a 1GB CF card and replace it with that (see my post: http://www.fixya.com/support/r590688-replace_broken_hard_drive_in_rio_carbon)
Hope this sheds a bit of light on your problem
Mowcius
Posted on May 18, 2008
  • mowcius May 22, 2008
    Your hard drive might have 'stuck' like has happened in a few people's carbons.This is often where the the arm for reading the hard drive gets stuck/gets confused as to it's position and needs tapping to sort it out.
    Regarding your battery life I'm not sure.
    Try flattening it then charging it for a day or two. I'm not aware of anything that you could have done to wreck the battery life of your carbon apart from shorting the contacts when you had it open.
    Mowcius.
When it rains or is wet out the car starts but idles funny, it sputters and sounds like the engine is choking or stalling. The problem goes away when the car warms up.
try new plugs,leads and caps, it sounds like the ignition spark is tracking and causing a misfire, moisture helps this happen, but there must be a crack or problem with the insulation
Apr 08, 2011 | 2001 Kia Rio
Why does my car vibrate and noisy at red light and stop sign
My rio kia bought on from uyi technical dealer in benin city, edo state of nigeria only 4 months ago is vibrating with noise while driving. The noise is noticed by other road users even in motion, making a very loud noise or sound that is highly embarrassing. The dealer mechanics have checked more than twice yet no result, instead the hub bearing is observed; tyres are turn over yet the noise persists.
What do think is resolution to the problem? pls help me. Vinson- kvinson3000@yahoo.com
Mar 11, 2009 | 2003 Kia Rio
PC says there are tracks, Rio says no
http://www.fixya.com/support/r3774047-solve_mp3_player_connection_problem <- copy this address into a new window see if this helps.
Oct 24, 2008 | Rio CE2100 MP3 Player
No sound
i think your speaker is working in good condition
but your computer audio out not working
due to driver or hardware problem
  1. check sound driver is properly installed
  2. using other multimedia software instead of now using
  3. check audio hardware trouble
Jan 16, 2008 | Altec Lansing Multimedia Computer Speakers
Samsung DVD/VCR combo (DVD v4600) makes loud sound when playing dvds
probably cheaper to replace than repair sounds like theDVD drive has worn parts or is about to go out.
Jan 13, 2008 | Samsung DVD-V4600 DVD Player/VCR
Macintosh itunes won't write rio s35s
HAVING SAME TROUBLE DLING MUSIC FRM MAC 2 RIOS35.HELP???
May 19, 2007 | Rio Sport S35S MP3 Player
I can not acess the Rio Database to add new tracks or remove old tracks via the Rio Music Manager
Have you always used this on NT? I would suggest: 1-Upgrade to win2k 2-go to http://www.digitalnetworksna.com/support/rio/product.asp?prodID=235 and install the latest music manager.
Jan 14, 2007 | Rio CE2100 MP3 Player
Rio Carbon 5gb pearl transfer problem
hi first of all update uour firmware: http://www.replaytv.com/support/rio/product.asp?model=267&SKU=90260554 also go to Software tab and update your Music Manager i belive this will solve all your problems good luck
May 01, 2006 | Rio Carbon MP3 Player
Rio Carbon MP3 Player Logo
55 people viewed this question
Top Rio Audio Players & Recorders Experts
Mohammad Abumuailek
Mohammad Abumuailek
Joseph Hoffmann
Are you a Rio Audio Player and Recorder Expert? Answer questions, earn points and help others
