Question about Electrolux Insight EKC6049X Stainless Steel Range
THE COOKER IS MAKING A BUZZING SOUND IM TOLD ITS BEACUSE MT TIMER ISNT SET RIGHT... WHEN I SET IT IT JUST GOES BACK TO THE BUZZING SOUND A FEW MINUTES LATER.. MAYBE IM NOT DOING IT RIGHT AS I HAVE NO MANUAL>??? electrolux EKC6047X insight oven
2 Suggested Answers
  • 40 Answers
SOURCE: need a manual for electrolux insight cooker
try the electrolux website. www,electrolux.com
Posted on Apr 07, 2010
I have just baught a second hand belling double oven cooker, we have switched it on and the timer is constantly buzzing! And the top oven and grill don't work! Any ideas on wot could b wrong?
The timer has been set and the cooking time is finished. That is why it is buzzing and the oven is in a turned off state. You need to acknowledge the cooking time finished, and set the oven back to Manual operation from Automatic. In the old days you pressed one of the buttons by the clock that was used to set. I used to have a Belling Double Oven in the UK, but I can't remember about the timer.
Google
make model manual
Google
Dec 19, 2016 | Belling Ovens
I have a Phillips Fla screen and a few days ago it started making this loud buzzing/hissing sound that somewhat goes away once the TV is on but comes back with a vengeance when we turn the TV back on i...
Most likely if a buzzing or similar sound that is there even with set off--you have a noise coming from a transformer in the standby power supply which is running all the time if the set is plugged in----
Someone would have to open set and listen for it---either a part, a board, or hot glue would have to be used to mute the vibration that is making the sound----one way we locate is with cover off probe with a plastic tool to see where it is.
If you are not able to do this have a tech or a shop "look" for it.
Dec 03, 2012 | Televison & Video
Buzzing and clicking sound every few minutes
Compressor start relay - white plastic part - sitting right on the compressor, disconnect it shake it - u'll here it if it's damaged. :)
Oct 01, 2009 | Jenn-Air JCD2389G Side by Side...
Same like you
that buzzing click in the back is the timer problem.the timer is trying to rotate but it is not able to rotate.as the spinning part of the timer which moves is got worn out or getting blocked by rust or dust.the cost of new timer is not more then $50. its available at www.repairclinic.com or at www.partselect.com thanks.
Jul 11, 2009 | Amana ABB1927DE Bottom Freezer...
Gas range makes buzzing sound which goes away when disconnected from electrical outlet.
possible to have abad relay on the circuit board itself, only real way to fix is to replace the control board assy
Nov 04, 2008 | Kitchen Ranges
Zanussi Built-In Oven Clock keeps resetting?
The 1000uF/10V condensator in the timer unit has to be replaced.
Sep 29, 2008 | Zanussi ZBF360 Electric Single Oven
Humming/buzzing sound
We usually find this is the cabinet back rattling. To confirm, when this happens turn the volume on the set all the way down and see if the problem is still there. If it is still there the put your hand on the back of the tv and gently press to see if the buzzing goes away. If the sound does go away the cure is to loosen all of the back cabinet screws around the edges of the set and gently push on the back as you tighten the screw. tighten the screw in an order much like you would tighten the lug nuts on a tire. in other words thighten the top left screw, then the bottom right screw and kepp alternating as yougo around the dabinet back untill they are all tight.
Oct 23, 2007 | Panasonic TH-50PX60U 50 in. Plasma HDTV
Buzzzzzzz
Hello to all you buzzers, I have the answer to your problem. First this is what's happening. The buzzing is coming from the power relay. It vibrates at 60hz because the power supply filter capacitor is not doing its job hence you have a rough d.c. pulse going to the relay.To solve the problem remove back of t.v. slide circuit board out (you will have to disconnect white wire from degauss coil,located on left front) look for a blue box approximately 3/4"x1 1/2" this will be the power relay. Now look for capacitor location #c622 near the relay. This capacitor should be 470uf 25v. Remove and replace with 470uf 35v capacitor, connect white degauss wire temperarily put back on and give it a spin. Hope this solves all the buzzin,robert
Jul 12, 2007 | Sanyo DS24425 24" TV
Electrolux Insight EKC6049X  Stainless Steel Range Logo
42 people viewed this question
Top Electrolux Kitchen Ranges Experts
Mike Henne
Level 1 Expert
Dominic
Dominic
Are you an Electrolux Kitchen Range Expert? Answer questions, earn points and help others
