Question about IBM Computers & Internet
While installing Winxp on my laptop i found BootMgr is missing ..press ctrl alt delete. System info:LenovoG560 64 bit OS:W7 Home premium prior to installing Winxp. after finding the above message i 'm unable to use the W7 OS config Please help me ASAP
    Guru:
  • 1,082 Answers
Reformat the disk and reinstall XP. Be aware there may not be XP drivers for your model.
Posted on Sep 16, 2010
How can i boot my Windows Seven OS if the "bootmgr is missing"? I'm installing windows seven but when windows start copying files but error message appears that required files for the...
What you need is bootable DVD/CD for installing or repairing Windows 7 to get missing 'bootmgr' or repair corrupted bootmgr...If there are files corrupt on your CD, you can get new one from shop you have purchased..Maybe just need to clean up your DVD/CD, so your DVD drives can read properly the files installation..
Aug 07, 2011 | Computers & Internet
Hi . Iam ASHOK . my Laptop hava some problem (BOOTMGR IS MISSING PRESS Ctrl+Alt+Delete .) my laptop configuration is intel 3i Pro, Hdd 500 gb , Ram 4gb , OS is Windows 7 . place help me ...............
Hi Good day!! There might be a corrupted files in your windows (BOOTMGR) you will need a windows 7 CD
* Insert your Windows 7 disk into your DVD player and restart your computer.
* The next screen you see should have the Language, Time and Currency and Keyboard boxes.
* In the lower left side there are two options: "What to know before installing Windows" and "Repair your computer."
* Click on "Repair your computer"
* Windows will then try to find the installation directory for Vista or Windows 7, depending on what you have.
* Next up is a screen with a box called Recovery Options. Click the first option, Startup Repair.
* You'll see a Startup Repair box with the message "Startup Repair is checking your system for problems..."
* When it's done, it will prompt you to reboot. If there is more than one problem it may reboot again to continue repairing.
* At this point, you can remove the DVD, reboot and everything should be working.
Thank you for using FixYa
Please accept if my solution helps you!!
Nov 08, 2010 | Dell Computers & Internet
Boot mgr is missing
Boot Manager is missing If the boot partition no longer can be found, then Vista will display the following error: BOOTMGR is missing. Press Ctrl+Alt+Del to restart
The Windows Boot Configuration Data file is missing required information
More Info MS KB 919529 More Info MS KB 927391 Check points for fixing missing boot-manager: Check that your boot device is configured properly Boot into Windows Recovery Environment (WinRE) and perform a "Startup Repair". Boot Manager is compressed If by accident having compressed the entire boot partition, then Vista will display the following error: BOOTMGR is compressed. Press Ctrl+Alt+Del to restart OR maybe try this first. Check points for fixing compressed boot-manager: Boot into Windows Recovery Environment (WinRE) and perform a "Startup Repair". If the above doesn't solve the problem then boot into WinRE again, but when selecting the Vista-installation, then press "Load Drivers" (Instead of "Next") and use the mini Windows Explorer to right-click the boot-drive and deselect "Compress this Drive" and choose Apply to sub-folders and files. If that also fails then boot into WinRE again, and go to the "Command Prompt" and execute these commands: compact /U C:\bootmgr compact /U C:\ntldr If you for some strange reason have lost your Vista DVD, then you can also use a Windows 2000 / XP install CD and enter the recovery console instead and execute the following commands: attrib -c c:\bootmgr attrib -c c:\ntldr
Try start up in Safe Mode press F8. Choose Safe Mode, when at the choice window, to select either Safe Mode Desktop, OR System Restore, chooses system restore and choose a time before you had the "Problem" and follow instructions. This should get you back.
Feb 21, 2010 | Acer Aspire 8920-6048 Notebook
Bootmgr is missing
You have formatted the HDD in another computer and the “boot manager” was destroyed.
There is no operating system on the HDD and therefore the error message: “BOOTMGR is missing Press Ctrl+Alt+Del to restart" appears
The second message “PXE-M0F: Existing PXE ROM” says that the notebook tries to boot form the LAN but it’s not able to find an OS using the LAN connection!
Why all this error messages appears?!
Well, I think the CD/DVD drive cannot read the inserted WinXP CD and therefore in switches to LAN.
Note; You can boot from the drive by pressing the “C” button immediately after notebook starting or you will press the F12 to get the booting menu. Then you could choose the ODD as booting source.
If you will be not able to boot from your WinXP CD I assume either the CD is faulty or the CD/DVD drive cannot handle this CD.
Jan 20, 2010 | Toshiba Satellite A135-S2356 Notebook
Bootmgr missing
Windows Vista?
Insert the installation CD. Once it boots from CD, click "Repair Your Computer", select the drive, and then "Startup Repair". This should fix it.
More info here.
Apr 16, 2009 | Computers & Internet
BOOTMGR is missing Press Ctrl+Alt+Del to restart. Im trying to format an older computer with XP Pro. I physically took out the only hard drive in the computer and hooked it up externally to my laptop to...
The problem is caused by Formatting the HDD in Vista before moving back to the system.
Simplest fix, hook it back to the Vista system and delete the partition from the drive in disk management. Once that is done, then put the drive with no partition in the XP system and boot to the XP CD, create a new partition and install XP
Jan 29, 2009 | Computers & Internet
Presario c751nr bootmgr missing
Have them load whatever OS you lost to them, if you have the OS cd, try installing it yourself.
Dec 14, 2008 | Acer Aspire 5500 5570-2609 Laptop
Compressed boot manager
Windows Vista includes a new Boot Manager (BootMgr) that replaces the old NT Loader (Ntldr).
This can usually be solved by checking the boot devices, and if no problems found then use Windows Recovery Environment (WinRE) and perform a "Startup Repair".
This can usually be solved by using Windows Recovery Environment (WinRE) and perform a "Startup Repair". If that fails then use WinRE to enter the "Command Prompt" and execute these commands:
  • compact /U C:\bootmgr
  • compact /U C:\ntldr
Aug 28, 2008 | Computers & Internet
first u go to bios settings and change first bootdevice cdrom and reboot system u put winxp cd in cd drive
u will see this message
press any key to boot from cd
u press any key
winxp setup start automatically
and repair winxp
som case hardisk partition probelm , that case u will format drive and re install winxp
Jul 12, 2008 | Computers & Internet
Computers & Internet Logo
52 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
