Question about LG DLE2532W Electric Dryer
The LG Throm DLE2516W "check filter" light will not go off and within 2 seconds the dryer shuts off.
PSITECHNICAL
  • 71 Answers
SOURCE: check filter light wont shut off and setting.lg tromm dryer
You might need to check the exhaust on the rear of the Dryer, or the blower motor iether one has lint inside, restricting the air flow
Posted on Dec 23, 2009
SOURCE: Error Code on LG Dryer
The solution is not the thermister it is a board in the console with the transformer on it. That's what my tech says.
Posted on Apr 29, 2008
jgwhomeequip
  • 1902 Answers
SOURCE: LG dryer check filter light
Have you checked the lint trap? If not this is what it is talking about. If you have then you should check your dryer vent line. Your lint trap should be on the inside of the dryer. If you need more help let me know. Also if you unplug the unit after checking what I said and the light still is one. Unplug it for 1 minute then plug back in this should reset everything
Posted on Feb 09, 2009
  • 108 Answers
SOURCE: lg dryer dle2516w doesn't heat up. everthing works
the heating coils may be burned out.
Posted on Dec 22, 2009
omaharox
  • 161 Answers
SOURCE: LG Dryer DLE2516W contiuously trips breaker but
Your circuit breaker may be bad. Run dryer and if breaker gets hot after 10min or so the breaker is bad.
Higher heat settings draw more amperage thus tripping the bad or undersized breaker. 30 amp 2 pole breaker required.
Ck. the power cord for signs of arching. Replace power cord or outlet if damaged.
Posted on Jan 20, 2010
My lg 2240 clean filter light blinks even though the filter is clean. when started it runs for 3 to 4 seconds then shuts off. if you wait for about a minute it will start again then shut off after 3 to 4...
This problem usually is caused by a restricted or blocked vent. The filter itself can be clean, but the duct work in the dryer after the filter, or the vent hose attached to the dryer, or the exhaust door attached to that hose is either restricted, plugged or blocked. Lint likes to build up in all areas the exhaust air goes, so check them all. The dryer has a sensor that will shut the dryer off if there is a restriction. Cleaning all of the duct work, from the filter all the way to where it exhausts outside, will usually solve this problem. An easy way to check is to unhook the exhaust hose from the dryer and run it. Does it keep running now? It is possible the sensor in the dryer has gone bad, but that is rare. 99% of the time it is lint build up in the venting.
Dec 12, 2013 | LG WM-2277HW Front Load Washer
We have a LG DLE2516W dryer. It does not get hot enough to dry clothes in less than two hours. We have checked the lint drap and the vent pipe. Both are clean. It does not matter whether there is a...
It could be a thermostat in the unit there are two and it could be registering wrong and shutting down the fire early. No way to check them though unless you put a tester on them while its running and see if they are shutting off the fire during a cycle
Dec 29, 2010 | LG DLE2516 Electric Dryer
LG Dryer DLE2516W contiuously trips breaker but only on heat setting greater than low
Jan 04, 2010 | LG DLE2516 Electric Dryer
LG Tromm door reversal
IF YOU SWITCH THE DOOR YOU MIGHT WANT TO MAKE SURE THERES NO SWITCH OR ANYTHING THAT THE DRYER READS TO SAY THAT THE DOOR IS SHUT OR OPEN IF NOTHING THEN IT SHOULD BE A PRETTY EASY SWITCH
Mar 09, 2009 | LG DLE2514 Electric Dryer
Dryer powers up but stops within 4 seconds. Is louder than normal. When I press the power button, the check lint filter message lights.
Oct 30, 2008 | LG Dryers
LG DLE5977 Electric Dryer
Below are some solutions that other customers have cited. The control board seems to have a glitch in it, so I would take it back and get a replacement. New product is covered by a factory warranty or a dealer replacement guarantee. My husband and I just BARELY bought an LG Electric Dryer. I'ts model #DLE2516W. As soon as you hit the power button, "check filter" comes on. The right after that, the error code "Te1" flashes and it does nothing but beep. Clearly, the filter has NOTHING in it because I've never run a load of clothes thru it. When I look in the troubleshooting section of the owners manual, it tells me that this means that the thermistor is open and needs to be replaced. But I'm confused as to why a BRAND NEW dryer already needs a part replaced. Can ANYONE please help me. I have lots of laundry to do. Haha!
Comment by Amanda02, posted on Sep 11, 2007 Well... we took it back to Home Depot and they are replacing it. i was trying to fix it because it takes 3 weeks to get a new one. They don't have any in stock!! And it takes 3 darn weeks to get a new one.
Jun 11, 2008 | LG DLE5977 Electric Dryer
LG DRYER DLE2516W
The timer is not advancing itself to the OFF or open cam, which opens points and stops the timer motor.
You will have to replace the timer to correct the issue.
Dave E. (Illeagle)
May 30, 2008 | Dryers
LG DLE2532W Electric Dryer Logo
446 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a LG Dryer Expert? Answer questions, earn points and help others
