Question about Carrier 38CKC024 Air Conditioner
What is SEER rating for a Carrier 38ckc024 Air Conditioner
  • 54 Answers
SOURCE: ruud achiever 10 seer air conditioner
It sounds like your condenser fan motor may be locked up or the capacitor that helps give the condenser fan motor a kick to get it started may be defective. Try turning your system on and using a long screwdriver try to push the fan blade on the condenser fan motor to see if it will run normally if you give it the starting boost it needs.If it does run at full speed and doesn't over heat or start and then slow down then you probably only need to replace a simple 10-12$ capacitor. If it barely turns, makes an odd humming sound or overheats etc. then you will have to replace the condenser fan motor. This is assuming that the outdoor condenser has the 220v supplied and the 24v supplied to the compressor relay, that the compressor relay is engaged and suppling 220v to the condenser fan motor.
Posted on May 30, 2008
cactus bob
  • 267 Answers
SOURCE: what is the cooling btu on my BDP company division of carrier
is this unit real old ? it does not come up in my book . the btu is 30000 that is the same as 2.5 ton it may be 6,7 or 8 seer i dont think its a 10 seer because the 10 seer units are listed and yours is not . if this sounds wrong please look up the mod # again and post the ser # too ......... Please if this answer helped , please rate this 3 or 4 stars . and keep me in the paid answer department . A 1 or 2 may knock me down into the unpaid ranks. Thanks Cactus Bob .
Posted on Mar 15, 2009
  • 189 Answers
SOURCE: air conditioner replacement--new size required?
567C024RCU In this model number is the # 24. That stands for 24,000 btu's. This is a two (2) ton unit. Has this two ton unit cooled ok in the past? if so replace with the same size. But make sure yo change the indoor coil to match the size "and" efficiancy of the ew unit.
Posted on Apr 14, 2009
SOURCE: ERROR CODE 5 FLASHES CARRIER SPLIT SYST. AIR COND. 42G250HP-1
5 flashing is ' compressor drive' and check the high pressure, condenser fan motor capacitor for proper running
Posted on May 21, 2010
hvac1
  • 338 Answers
SOURCE: Ruud achiever 10 seer air conditioner wont turn
Have you check the outside breaker box? If thats not it then its probably the contactor.
Posted on Jul 09, 2010
Looking for seer rating on carrier air conditioner model 38ckco48300
Dear All.
I am looking for PLUG ELECTRICAL,
RATING: 280/230 VAC,1 PH.MATERIAL,METAL PLASTIC FOR COMPRESSOR MODEL NO.38CKCO48300 SERIAL NO. 5098E08327
MFR: CARRIER CORPORATION
PART# 317749-407 QTY-1 PCS.
Regards.
Imran Abbasi
Mobile: +966 567897901
e-mail: imran@tsources.com
Aug 02, 2012 | Carrier 38CKC036 Air Conditioner
How many tonnes does this air conditioner have?
First digit after 38CKC_0_ is the seer rating this is a 10 Seer unit.the next two digits are BTU's of cooling to the thousands. For every 12,000 BTU's you have 1 ton of air conditioning.38CKCO_36_ would be a 3 ton unit.
Serial number first two digits are the week the second two are the year24 would be 24th week. 02 would be 2002
Jul 08, 2012 | Carrier 38CKC036 Air Conditioner
The AC quit working and the top of it is HOT
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Aug 27, 2011 | Carrier 38CKC024 Air Conditioner
We are upgrading carrier a/c outside and need to know if model 38ckc024 is R-22 or R410a
It could be either really . But if you have a choice in this day and time I would use R22- BUT remember they are beginng to ban it as well .. I have personal feeling about this but they are mine But in your case either will be fine .
Jul 25, 2011 | Carrier 38CKC024 Air Conditioner
How do i connect the capacitor to my 38ckc024 ac unit. i have 2 yellow, 1 brown, 1 blue wire.
Here is a link to the wiring diagram for this unit
Hope this answers all your questions
Please remember to Rate/vote for any solution that helps you out.
Leave a comment if you need more help.
Thanks for using Fixya
Jul 05, 2011 | Carrier 38CKC024 Air Conditioner
How do i know the tons and seer of my york unit model h4db060s06a ser #wglm032b12
That is a 5 ton system but I do not know the SEER rating. See that 060 in the middle of the model number? That means 60,000 BTU or cooling capacity and that is 5 tons.
Jun 20, 2011 | Carrier 38CKC042 Air Conditioner
I have a carrier air conditioner model 38CKC024340 it cool the house sometimes, then a block of ice will form on the unit outside and it stops cooling, what could be the problem
Have you changed the air filter?
The 2 main reasons for frozen units in cooling mode 1. Not enough air flow. 2. Low on refrigerant.
You can fix #1.
#2 will require a service call.
Jun 02, 2011 | Carrier 38CKC024 Air Conditioner
What tonnage is my new Carrier A/C model # 24ABC642A300 and how many sears is it?
The AC unit you inquired about is 3.5 ton unit. With a 10 seer rating.
Hope this information helps.
Mar 01, 2011 | Carrier 38CKC042 Air Conditioner
What is the cooling btu on my BDP company division of carrier
Mar 15, 2009 | Amana Comfort Zone 12M32PBEH Air...
Carrier 38CKC024 Air Conditioner Logo
266 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
