Question about Dryers
My neighbors dryer will not heat up at all. some tech was there replaced heater elements fuse like thing that cuts out when too hot also the thermastatnear the overload -fuse like thing but still no heat.
  • Dryers Master
  • 43,501 Answers
The company should be called back and made to fix it correctly...
when replace the fuse the thermostat should always be replaced also...if the fuse blew it is because something else failed also...
heatman101
Posted on Sep 16, 2010
Kenmore 240 volt compact electric dryer not heating model # 110.89182990
U need to check the heating element ,u know how are CALl for service
Mar 13, 2015 | Kenmore Dryers
Replace fuse dryer model GEQ8821LLO
Hello;
My name is Peter. I am a retired field service appliance technician.
You never explained what the problem was. Dryer not running? No heat? Dryer shutting down. It could be as simple as cleaning out your dryer hot air distribution manifold. A dryer will not run if you do not have good air flow due to lint blockage. A dryer will not run if you have a bad door switch. You can Ohm components out with a multi-meter, setting the meter to the lowest Ohms (Omega Symbol). You should get a reading of "0" if the component is good.
1.) Dryer Door Switch - This switch replaces your dryer door's switch.
  • You may need to remove your dryer's lint screen and lint screen housing before lifting its top panel to reach its existing switch.
  • Be sure your dryer is unplugged during installation.
This Dryer Door Switch part #3406107 Cost $20.00
Dryer Door Switch - Unplug the dryer before replacing the door switch.
This Dryer Door Switch part #279782 Cost: $22.00
Thermal Cut-Off- This component is located on your heating element housing,. you may be able to access it at your hot air distribution manifold in the back of your unit.
  • When replacing your dryer's fuse, replace its thermostat, too. The thermostat should have prevented the dryer's existing fuse from blowing. The high-limit thermostat is functional to 250 degrees (Fahrenheit) and the thermal cut-off fuse to 360 degrees (Fahrenheit).
  • Install the fuse in your dryer's heater element housing box. Be sure your dryer is unplugged during installation
  • Part #: 3977394 Cost: $33.00
    25432459-jpgjqed1aonpcy4b0i04xdgb-5-9.jpg Cost: $34.00
    The high-limit thermostat replaces your dryer's thermostat.
    • The thermostat is functional to 250 degrees (Fahrenheit).
    • Install the thermostat in your dryer's heater element housing box. Be sure your dryer is unplugged during installation.
    This High-Limit Thermostat part #3390291
    Hot Air Distribution Manifold:
    This is in the back of your dryer and easily unbolted. If you are plugged up with lint your unit will shut down. Remove this component and clean the lower discharge end.
    25432459-jpgjqed1aonpcy4b0i04xdgb-5-14.jpg So, tell me what the problem is, and I will tell you how to fix it.
    Peter,
    Glen Burnie, Maryland, USA
    Feb 15, 2015 | Whirlpool Dryers
    I have a Kenmore Series 70 Dryer and I changed the thermal fuse got hot for a few minutes the model #110.74722400
    The cycling thermostat must also be replaced when replacing the thermal fuse. The cycling thermostat's failure to cycle off the heating element results in overheating of the dryer which consequently blows the thermal fuse open.
    Replacing only the thermal fuse should the dryer stops running and fails to start will result in its premature blowing or even the thermal cut-out (cut-off) located on the heater duct. Like the cycling thermostat, the high-limit thermostat must also be replaced once the thermal cut-out blows open. Refer to the parts diagram in the link below and look for item numbers 31(thermal cut-off), 34(hi-limit thermostat), 39(thermal fuse), and 41(cycling thermostat.
    Kenmore Series 70 Electric Dryer (110.74722400) Bulkhead Parts
    Aug 21, 2011 | Dryers
    I am trying to take the back off of my Whirlpool clothes dryer model LEQ8611LW1 to replace the heating element, but the back will not come off. How do I get to the heating element?
    The dryer doesn't have a removable rear access panel and the heating element is accessible through the bottom front panel. Using a flat-blade screwdriver, locate and release the two bottom front panel clips approximately 4 inches from the sides.
    Once the panel is off, locate the heating element housing is on the right side and remove the hex-head screw from the heater shield.
    Remove the hex-head screw from the side of the heater housing and slide the heating element out then slide the new heating element in and secure it with the hex-head screw.
    Note:
    The heating element is not necessarily busted and needs to be replaced when the dryer fails to heat up. The first thing to look at is the thermal cut-off. It blows open and cut power to the heating element if the high-limit thermostat is faulty. Disconnect the red wire from the thermal cut-off and the red/white stripe wire from the heater. Connect the red wire disconnected from the thermal cut-off to the heater terminal where the red/white stripe wire is disconnected from.
    Reconnect power then start the dryer. The problem is indeed with the two bypassed components if the dryer heats up. Replace both the thermal cut-off and the high-limit thermostat and it should solve the heating problem. Do not use the dryer with those parts bypassed due to high risk of fire hazards.
    Apr 01, 2011 | Whirlpool Dryers
    The dryer turns on, and tumbles. Yet it no longer get hot. I was thinking heating coil. But was told it could be a smaller part.
    It doesn't necessarily mean the heating element is busted when an electric dryer stops heating. The first thing to look at is the thermal cut-off which cuts power to the heating element when it blows due to the failure of the high-limit thermostat both located on the heater housing. The thermal cut-off must be replaced, together with the high-limit thermostat, if found open. Click on the link below for the detailed instructions in troubleshooting this problem.
    Troubleshooting Whirlpool and Whirlpool-Made Electric Dryers (Filter on Top and with Removable Back Panel) Running But Not Heating
    Mar 25, 2011 | Roper REX3614KW Electric Dryer
    No heat whirlpool electric dryer imperial 70 1986 vintage
    replace cut off switch fuse at the top of heater box
    May 02, 2010 | Whirlpool GGQ8831L Gas Dryer
    Stopped heating
    What I do is see if their could be an obvious reason for the dryer to quit heating. I determine how old the dryer is and ask if the heating element has been replaced and when, those sorts of questions then that give me an idea. I make it a point to clean and oil any dryer I work o. They all are going to have lint buildup in them and this lint is the main cause of heat failure. A small piece of lint gets on the heating element and causes a hot spot. The hot spot burns through interrupting the circuit93b855d.jpg
    I unplug the machine and remove the rear cover. 1c9e8bc.jpg I 1. Hi Limit (small limit upper right hand side of this pic) the most frequent problem if dryer RUNS but no heat AND you have
    checked the element and found it to be good. 2. Heater assembly. 7. Control thermostat(s). 5. Fuse(350F), if blown(open) the dryer will NOT run. 4. Heater element
    (if you do not have a meter remove and inspect this heater coil for breaks). I remove the lint chute(that the thing the filter lives in) and I wash that out because it gets clogged over time. I check the heater and limits for continuity. Then I remove the front panel and drum. Completely vacuum out the dryer and oil the rollers. d4f393f.jpg
    If this is a gas dryer you want to see if power is going to the gas assembly
    If this fuseeda36f9.jpg is blown on a gas dryer the dryer will run but the heat will not, If the dryer heats a little but quits then these coils are getting hot and intermittent94fb1fe.jpgif your igniter is blown a54d451.jpgor your sensor is open5650218.jpgthere won't be no heat.
    Apr 09, 2010 | Whirlpool LER5636P Electric Dryer
    Dryer not hot
    Tht means that the element is not heating on.
    You need to call a technician to test the element, the thermic sensor, and the control assembly.
    The most likely is a defective heating element, that must be replaced.
    Jan 31, 2009 | Kenmore 73952 Gas Dryer
    Whirlpool Dryer extremely hot
    If your dryer heating element does not cycle, you may have a bad high limit thermostat. The thermostat is used to regulate the internal temperature of the dryer and should cycle the heater on and off. The thermal cut-out is supposed to prevent the dryer from overheating and will blow like a fuse. It is a non-resettable device and must be replaced. It is strongly recommended that you replace both these components at the same time if you have found one of them to be bad. Both of these components will be mounted on the heater box housing. Usually the thermostat is the component closest to the ceramic terminals of the heating element. Most manufacturers sell these two components as a set. The dryer temperature at the exhaust on the back of the dryer should be about 140 degrees. If the temperature is excessive to the point where it is melting things and the cabinet is too hot to touch, make sure the heater is regulating as it should. I would use some extreme caution about using your dryer until you have this problem corrected. I would not use it under any circumstances if you are not going to be home, or if you are going to bed. Dryers are one of the number causes of fires in homes. Good luck to you and let me know if I can help any further.
    Feb 18, 2008 | Dryers
    Dryers Logo
    35 people viewed this question
    Top Dryers Experts
