Question about Sony Playstation 3 (PS3) Console
I have this yellow light flashing for a moment in my PS3...i think its a YLOD...wat should i do...i do not want to pay a fortune for a problem that i did not cause....PLS HELP....I REALLY NEED IT
    Scholar:
  • 142 Answers
This problem occur in all ps3.... you can solve this problem using ps3 repair guide... click here for your reference...
Posted on Sep 26, 2010
  • 4,102 Answers
Hi this is a very common problem and its to do with the ps3 over heating,
try the following.
leave it off and unplugged for an hour
check all air vents are free from fluff and dust and vac if needed.
make sure the ps3 is not being used whilst its on carpet
make sure the ps3 is not sitting on top of another electrical item such as dvd or sky box as this will cause it to over heat a lot quicker.
make sure its not wedged in a confined space it needs to have plenty of room around it to ensure cool air flow.
unplug all the leads from the back of the ps3 and the telly then plug them all back in, doing this removes any static that may have built up, then switch it on.
if after doing the above it still dont work then this indicates that either the gpu or cpu chip has over heated, if you have any warranty left take it back you need to check on the ps3 web site to see how old your ps3 is as this fault is covered by ps3 warranty for a couple of years but you need to check this.
now as for getting it repaired, well its a bit hit and miss i repair them myself and if it was an xbox 360 then i would say the chance of it working again is pretty high but as its a ps3 then these can be a bit hit and miss if the ps3 has over heated a lot and fried the cpu or gpu chip or both then the cost of repair would not be worth doing as it would be cheaper to buy a second hand ps3 or even a reconditioned one.
its not the kind of repair you can do yourself as you need to know how to test the circuit board to find out if the chips have been damaged.
Posted on Sep 16, 2010
  • joinpop Sep 22, 2010
    it was help full
    Problem Solver:
  • 5 Answers
Hi dude!!!!!!!!!! Don't worry with this problem.....this is the most common problem occurs in ps3.......it occurs due to over usage(over heating) of ps3......you need not pay for this.........just unplug your ps3 for an hour...........if the problem survive till..........
CLICK HERE
Posted on Sep 24, 2010
  • 76 Answers
I had same issue with my PS3, and was able to fix it using the video guide from http://www.ps3ylod.info You can get your copy and fix this problem, let me know if you need further help.
Posted on Sep 22, 2010
My playstation 3 console wont turn , when i try to it stops and a blue then yellow light flashes , what can i do to fix this.
source: http://www.edepot.com/playstation3.html#PS3_Model_Differences Yellow Light of DeathThe "Yellow Light of Death" or YLOD is the common phrase people use to describe the following sequence when they try to turn on their PS3:
  • Press Power Button
  • Red Light Flashes Three Times
  • Yellow Light Flashes
  • Green Light Flashes
  • Beeps Three Times
  • Red Light Flashes
The sequence above may vary a bit but you do see the flashing yellow light (sometimes shows up as orange) that normally you would not see when operating your PS3. The YLOD is a general hardware fault that can mean a lot of things. However, one of the problems is cracked solder that leads the PS3 to think one of its internal chips is not connected or is broken somehow. Cracked solder can happen when the chips get too hot (RSX most likely) and leads the motherboard to start bending, which may crack the solder. Changing the power supply (lower the average wattage going to the chips to lower the heat) and better thermal compound (heat dissipates faster to the heatsink) may prevent this error from occurring. However, if your PS3 has already had the YLOD, then you can reflow your motherboard every few months to keep it working (but it is not a permanent fix as the YLOD usually comes back).
Oct 10, 2010 | Sony Playstation 3 (PS3) Console
After pressing the on button it turns green for 5 seconds then it flashes yellow/orange for a second then it flashes red.
  • Beeps Three Times
  • Red Light Flashes
Oct 09, 2010 | Sony Playstation 3 (PS3) Console
Yellow light of deth
  • Beeps Three Times
  • Red Light Flashes
Light blinks red then turn on and blinks yellow once and back to blinking red
YLOD (yellow light of death) Replace your power supply inside the unit. Can pay Sony $150.00 USD or spend $40.00 USD on E-Bay. Very easy to install. Google PS3 YLOD Repair for indepth instructions.
Oct 03, 2010 | Sony Playstation 3 (PS3) Console
Ps3 flashes green then yellow then constant red
you have the ylod aka the yellow light of death basically 90% of that problem happens to be that the 2 chips in the playstation have been disconnected from the mother board so wat you will have to do is reheat the chips so they can reconnect look up on youtube for more indepth details
Aug 22, 2010 | Sony Playstation 3 (PS3) Console
Playstation 3 will not turn on when the on button is pressed it bleeps and then the green light flashes yellow then a red light flashes
what you got is what is know as yellow lite of death --YLOD
this is the site i got the info from...
http://boardsus.playstation.com/t5/PlayStation-3-General/Unofficia
l-Yellow-Light-of-Death-YLOD-Informative-Still-Thread-R/m-p/40726489
and you are not the only one to experience this. more and more ps3 owners are getting hit with this problem. your best bet will be to send it off to sony if its under warrenty for they'll fix it for free. but be cautious of this for they may even replace your system and you may not get your original system back. if its not under warrenty you'll get hit with an $150 charge. you can check youtube for videos on how to open up/fix your ps3. look for videos "YLOD FIXES" i get people telling me that their system only works for few days to few month so i have to assume that the fix is not a permanent. last i checked i think sony only cover your system for 30 days if they fix it. there are also guides you can buy.
background
The YLOD is a major hardware failure for the PlayStation 3. The specific cause is somewhat known, but Sony has not commented about this failure whatsoever. Some theories for the cause include:
overheating (accelerated by dust build-up), blu-ray drive failure, bad power supply, and/or a hard drive critical error.
**UPDATE**
According to an eBay store that repairs YLOD PS3's, the hardware failure is caused by either/or of two things:
1. Hardware malfunction on the motherboard due to heating/cooling (solder physically cracking/breaking) which can be fixed by "reflowing", which is a fancy way of using a machine that has a super controlled (+ or - .5 degrees) hot air nozzle to re-melt the solder on the base of the defective chip to re-attach it.
2. The power supply has the failure in one of its capacitors or diodes. This can also be fixed by "reflowing" but it is harder to diagnose due to the need to chase down which one it is.
**According to this eBay store, this scenario is a much more difficult way to repair PS3's with the YLOD. They state they can only repair 8 out of 10 PS3's with the YLOD**
You know you have received the YLOD when the following occurs:
* You power on the console.
* The console starts up normally for about 2-3 seconds,
* The console beeps 3 times while flashing a faint yellow light,
* The console continues to flash a red light
May 19, 2010 | Sony Playstation 3 (PS3) Console
Fixs my ps3? a red light keep falsing on and off and its not leting me take out my game
you probably have the YLOD(yellow light of death). Its an overheating problem. If a yellow light flashes then you have the ylod. To fix this either spend 150 dollars and send your ps3 into sony. Or spend 10 dollars, open up ur ps3 and fix it with a thermal compound where you can find at a Best Buy. If the red light just flashes and no yellow light, leave the ps3 alone, that means its overheated and needs time to cool off.
Dec 10, 2009 | Sony Playstation 3 (PS3) Console
My ps3 refuses to play anything at the moment? It just beeps 3 times and the red light flashes. Can anyone help?
previously overheated the fans on the bigger PS3 system cant handle the heat form the GPU after extensive play and it will begin to melt. im sorry friend but its about toasted.
Nov 22, 2009 | Sony Playstation 3 (PS3) Console
I load the game, the yellow and green lights flash then the yellow light goes out and the screen goes black
this is the yellow light of death u can ether send it in and pay 150 for it to be fixed or go to youtube and search fix ps3 ylod and this guy will show how to fix it your self threw his steps
Nov 10, 2009 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
95 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
