Question about Maytag MFI2568AES Stainless Steel Bottom Freezer French Door Refrigerator
Maytag Code PE0000 - Maytag MFI2568AES Stainless Steel Bottom Freezer French Door Refrigerator
I am talking abt maytag refrigerator . New board panel and the PE0000 just keeps flashing
You need to program the new board. Programming Mode:
NOTE: The Program Code is located on the Serial Plate on this unit after the word Code.
1. Press and hold the Door Alarm Keypad .
2. Press and hold Freezer Temperature Down Keypad .
3. Release the Door Alarm Keypad and wait 3 seconds.
4. The control will display PE to indicate the programming mode.
5. Entry is confirmed by pressing the Freezer Temperature Down Keypad once more.
6. The control will display the current Program CODE. This value should be validated with the
Program CODE printed on the unit serial plate.
NOTE: If the Program CODE is correct, the Programming Mode is exited by pressing Door Alarm Keypad for 3 seconds.
7. Press the Refrigerator Temperature Up Keypad or Refrigerator Down Keypad to change the digit value with each key press.
8. The decimal point indicates the selected digit. Press the Freezer Temperature Up Keypad to select the next digit.
9. Once the desired Program CODE is entered, press and hold the Freezer Temperature Down Keypad until the Program CODE begins flashing indicating it has been saved.
NOTE: If you attempt to enter an invalid Program CODE the control will not save the new code, but will beep. (The unit will NOT run with a Program CODE of 0000).Once the Program CODE has been saved the Programming Mode is exited by pressing any key. If the new code is incorrect this process should be repeated.
The Programming mode can be exited at any time
Oct 13, 2016 | Maytag Refrigerators
I have a maytag 5000 series washer. We are getting an f21 error code. I unscrewed the white drain filter and cleared it. There was little in it. I keep getting the f21 error though. Can you help?
Search Results
    whirpool f21 error code - YouTube
    ? 3:04
    https://www.youtube.com/watch?v=b24PVv-ORqg
    Jul 1, 2012 - Uploaded by davidmontabon
    whirpool f21 error code. ... Maytag , Whirlpool Washer Repair - Drain pump error, no drain - F9E1- MHWE201YW00 - Duration: 4:29.
    My maytag 5000 series steam washer stopped and said Sud ...
    www.fixya.com/support/t8682656-maytag_5000_series_steam
    Mar 17, 2011 - my maytag 5000 series steam washer stopped and said Sud and now says ... Clicking this will make more experts see the question and we will .... I bought aMaytag 3000 seris in 2008 and I am getting these messages: F21 ... Maytag 5000 Series washer F21 error code was flashing and door will not open.
    Whirlpool/Kenmore/Maytag & more-F02/F21 & Sd error codes
    fixedappliance.blogspot.com/.../whirlpoolkenmoremaytag-more-f02f21-...
Feb 09, 2016 | Maytag Washing Machines
HP PE0000 Plasma Brightness Issue
Is it possible that the TV is not set to HD or a higher resolution, you may be pulling a low Pixel per inch, aka pi, where you want 480, 720 or 1080...check your settings...Good Luck!!
Jan 09, 2014 | Televison & Video
After installing a new mother board on a 5 year old Maytag 3 door Model # MFI2568AEW the display reads PE0000 and the control buttons do not work. Is there a reprogramming procedure?
It's board are already programmed so check it's wiring for open, look for deformed component it may cause it not buttons to work. Also do not overlook the possibility of a factory defect control board sometimes it do happened. Be sure that you installed it correctly the same as the old one. Look for loose connection.
Thanks for asking. Good luck.
Jul 04, 2011 | Refrigerators
I just replace my control board and freezer fan. I plug the refrigerator in and I get the PE0000 code. I try to go into the program mode by pressing door alarm and then freezer down key for three seconds...
I just fixed mine. With the PE00 0000 flashing press and hold the door alarm key, press the freezer down (-) button and hold, then release the door alarm button. after about a second release the freezer down button and the display should change to a steady PE00 0000 after about 3 seconds. Using the refrigerator + - buttons you change the code. The freezer + - buttons now control the position of the decimal point to change each number position. My code was 0302 (found on the sticker on the inside of the frig, right hand upper side. I had to follow the programming code found behind the kick plate on the right side twice, the second time it worked.
Apr 08, 2011 | Maytag MFI2568AES Stainless Steel Bottom...
Programming code not working
Go to this web page to find the text answer below: http://www.fixya.com/support/t233614-reprogram_hv_board
HERE TIS RIGHT OFF THE INSTRUCTION SHEET.  THE TECH JUST LEFT. POWER UP REF. PROGRAM CODE IS LOCATED ON SERIAL PLATE ON THIS UNIT AFTER THE WORD CODE.-1. PRESS & HOLD THE DOOR ALARM KEYPAD.-2. PRESS & HOLD FREEZER TEMP DOWN KEYPAD.-3. RELEASE DOOR ALARM KEYPAD AND WAIT 3 :WILL DISPLAY PE TO INDICATE PROGRAMMING MODE-5. ENTRY IS CONFIRMED BY PRESSING TEMP DOWN - KEYPAD ONCE MORE.-CONTROL WILL DISPLAY CURRENT PROGRAM CODE. THIS VALUE SHOULD BE VALIDATED THE THE PROGRAM CODE PRINTED ON UNIT SERIAL PLATE.-NOTE: IF PROGRAM CODE IS CORRECT, THE PROGRAMMING MODE IS EXITED BY CLOSING THE FRIG DOOR.-7.PRESS REFRIG TEMP UP KEYPAD + OR REFRIG DOWN KEYPAD -TO CHANGE THE DIGIT VALUE WITH EACH KEY PRESS.-8.THE DECIMAL POINT INDICATES THE SELECTED DIGIT. PRESS THE FREEZER TEMP UP KEYPAD + TO SELECT NEXT DIGIT.-9.ONCE DEIRED PROGRAM CODE IS DISPLAYED, PRESS AND HOLD THE FREZZER TEMP DOWN KEYPAD - UNTIL UNIT PROGRAM CODE BEGINS FLASHING INDICATING IT HAS BEEN SAVED. *note* IF YOU ATTEMPT TO ENTER AN INVALID PROGRAM CODE, THE CONTROL WILL NOT SAVE THE NEW CODE, BUT WILL BEEP! (THE UNIT WILL NOT RUN RUN WITH A UNIT PROGRAM CODE OF 0000). ONCE THE PROGRAM CODE HAS BEEN SAVED THE PROGRAMMING MODE IS EXITED BY CLOSING THE FRIG DOORS.
Aug 03, 2008 | Maytag MFI2568AES Stainless Steel Bottom...
Personality code
osborne, you can try this procedure.
PROGRAMMING MODE: (FOR PROGRAMMING A NEW CONTROL)
NOTE:
1. Open the Fresh Food door and press and hold the Door Alarm Keypad.
DIAGNOSTIC TESTS
6. The control will display the current Program Code. This value should be validated with the
Program Code printed on the unit serial plate.
NOTE: If the Program Code is correct, the Programming Mode is exited by closing the Refrigerator
door(s).
9. Once the desired Program Code is entered, press and hold the Freezer Temperature Down
Keypad until the Program Code begins flashing indicating it has been saved.
NOTE: If you attempt to enter an invalid Program Code the control will not save the new code,
but will beep. (The unit will NOT run with a Program Code of 0000).Once the Program Code
has been saved, the Programming Mode is exited by closing the Refrigerator door(s). If the new
code is incorrect this process should be repeated after closing the Refrigerator door(s).
The Programming mode can be exited at any time by closing the Refrigerator Door(s) or
will exit if unattended for four minutes.
i hope i was able to fix your problem.
Jul 02, 2008 | Maytag MFD2560HES Bottom Freezer French...
Maytag MFI2568AES Stainless Steel Bottom Freezer French Door Refrigerator Logo
203 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
