Question about Xerox DocuColor 3535 Copier
On My Xerox Copier Docucolor 3535, I get an fault error 010-372.
  • sgreene229 Sep 16, 2010
    I was printing posters. The paper was 11x17, glossy, 80lb weight. I printed about 100 sheets using the bypass tray. The first error was 010-348 then replace the fuser, turn the machine off. Cut the machine back on then this error appear 010-372.
    I was printing 11x17 posters using the bypass tray. The fault error 010-348 appeared, changed the fuser turn the machine off then on, the machine now appeared with 010-372. HELP!!!
    Genius:
  • 1,035 Answers
Hi. I provided you link where you can check for the fault codes of your copier. Please click here.
Posted on Sep 16, 2010
    President:
  • 1,961 Answers
The 010-372 is an error pertaining to the Control Thermistor not being detected within the specified time to the specified temperature.
I would like to know the exact operation that you have done when this error code first appear.
I might as well give you some advise for possible solution for this error.
Please post back.
Alp
  • Danilo Baraquiel
    Danilo Baraquiel Sep 17, 2010
    The thermistor circuit needs a replacement.This thermistor is a device that that charge/gives supply voltage to the auxiliary lamp. after this lamps is lit for a couple of seconds the thermistor will heat up and then cuts off the supply voltage Printing will now then start.In this case thermistor is not working that's why you got the error 010-372 .replace the thermistor first.
  • Danilo Baraquiel
    Here's a sample of thermistors..It is available on the electronic supply
Problem with a Xerox Docucolor 3535 Copier
Reset the tranfer unit counter,and change the transfer unit chip fuse(located in transfer unit contact house)
Apr 12, 2012 | Xerox DocuColor 3535 Copier
Xerox DocuColor 3535 103-208 error I accidentaly
There isn't much you can do, except perhaps buy at least one new board. But those are expensive
In this case, a better solution is to call Xerox. This correction must be done by an Authorized Xerox technician, with their proprietary laptop called a PWS.
They will run the procedure called GP-10 Replacing Billing PWBs.
Whit Item, Inc.
Nov 19, 2010 | Xerox DocuColor 3535 Copier
Xerox Docucolor 3535 fault code 006-372
That is a problem with the laser or ROS polygon mirror motor.
It most likley has failed.
Google a business called The Parts Drop, call and ask for Britt.
They can help you parts wise. Its not real difficult to replace.
Oct 24, 2010 | Xerox DocuColor 3535 Copier
116-325 error code on docucolor 3535
Hi the 116-325 error for the 3535 is a 24Volt communication error.
The 24V power supply 105E18641 is probably bad, or possibly some wires that connect them.
Whit
Item, Inc
Sep 22, 2010 | Xerox DocuColor 3535 Copier
Error code list
Hi, you can find the error code list for the DocuColor 3535 in the Troubleshooting section of the manual. If you don't have a user manual, you can download a PDF version from Xerox here:
http://download.support.xerox.com/pub/docs/DocuColor_3535/userdocs/any-os/en/3535_User_Guide.pdf
Mar 08, 2010 | Xerox DocuColor 3535 Copier
Xerox 3535 error code 102 372
have a xerox 3535 with one blinking light and error code 102 372 on start up any ideas ?
Oct 15, 2009 | Xerox DocuColor 3535 Copier
Xerox docucolor 3535 - error 010-348
Hi, you have to reset this code entering into diagnostic mode, If this fault is declared 3 times in succession, print and copy mode will be disabled. In order to clear this condition, reset NVM location 744-003 to 0. Saludos from mexico
May 10, 2009 | Xerox DocuColor 3535 Copier
went to xerox site , look for 3535, type in error code, saw what the problem was.
Jul 16, 2008 | Xerox DocuColor 3535 Copier
174 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
