Question about Kenmore 98702 Stacked Washer/Dryer
Regarding the washer, I set the dial to 8 minute wash, and for a small load, it fills with water for a small load then the washer just "Hums", it does not start the agitator cycle. I can then set the washer to drain and the water will drain out. Could it be the Motor Transmission or could it be something with the dial?
  • 10 more comments
  • robert_m_pir Sep 16, 2010
    Would like a second opinion to my problem. Thanks
    I received to reply's with 2 different answers, Let me try one more from another expert.
    I currently am not at the location where my washer/dryer is. Its located at my cabin in the mountain.
    Can I get back to you next week? I will be going there this week and I will get the model number of the unit.
    Thanks
    I just thought of something, i have the motor & Pump at home, If I get the P/N off the motor, can you tell what model of Washer/Dryer it goes into ? Please advise.
    Thanks
  • robert_m_pir Sep 17, 2010
    I went home last night and looked at the motor and pump and these are the P/N's I read off the parts:
    Motor:
    P/N: 131902822
    Model: C68PXGJR-4556
    Pump:
    Askoil
    Model M66
    10 Min on / 60 Min off
    So based upon the above Part Numbers, can you tell what model of Kenmore Washer/Dryer it is ?
    I need to go to the cabin this weekend and check the Tub Bearings and the Lid Switch.
    But the Motor Pully turns Freely
    I have submitted my question to 3 different "experts" and received 3 different answers, just looking for 2 of the same answers with a solution
  • robert_m_pir Sep 20, 2010
    Ok I have the Model & Serial now
    Model: 417.92702200
    Serial # : XE24600851
    Built: 11/02
    Went to my cabin this week and got the #'s
    Also another thing I noticed, with the motor out of the machine, the drum will only spin counter-clockwise with your hand, could that mean a Transmission problem ?
    Shouldn't the drum go both ways during the agitation cycle ? This could be the culprit, please advise.
    The Kenmore Model/Serial #'s are as follows:
    Mod - 417.92702200
    Ser - XE24600851
    Also should the Drum be able to turn both ways with the belt off ? Right now it will only turn Counter-clockwise
    The Model/Serial #'s for my Machine are as follows:
    Model - 417.92702200
    Serial - XE24600851
    Another possible problem : With the belt off the drum Pully, should the drum be able to spin by hand both ways ? Right now it will only hand spin counter-clockwise, should this be the case ? or is this my problem ?
    Thanks,
    I obtained the Model/Ser #'s for the subject unit
    Serial - XE24600851
    While obtaining the above numbers, I also noticed that when I hand turn the Tub, it only goes Counter-clockwise (With Belt removed) in the agitation cycle does the tub go both ways?
    Does the tub spin both ways? I checked it this weekend and the tub spins counter-clock wise by hand with the belt off.
    Also the Model # is a Kenmore 417.92702200, Ser # XE24600851.
    So I have been told, its the Motor, Lid Switch, tub bearings and so on. I'm getting all kinds of answers, maybe I should just buy a new one. Please help !!!
  • robert_m_pir Sep 22, 2010
    Also the drum spins only counter-clock wise with the belt off.
    The Model/Serial numbers of the unit is as follows:
    Serial - XE24600851
    I have received 4 different possible solutions.
    Just looking for a common thread here.
    Thanks
  • 2,272 Answers
Remove the main access panel (usually in the back). Is the motor spinning, but the drive belt isn't? If so, then you have a drive belt problem.If the motor is not spinning then its motor fault. Try this procedure as follows:--- Upon removing the main access panel, you observe the motor spinning but the drive belt is not or is moving intermittently. This is a drive belt problem which may require replacement. Try these tips first:
1) If the belt has a lot of play, loosen and slide the motor so there is a 1/2 to 3/4 inch in the belt.
2) Check that the pulley is tightly attached to the motor. If not, then tighten
3) If the belt is worn and frayed looking, replace it.
If the belt still won't turn there is a problem in the washer transmission.
If your washing motor hums, but otherwise refuses to spin, there are a few things to check before replacement of the motor becomes necessary.
1) With the power off to the washer, remove the main access panel, then pull the drive belt that's attached to the motor and see if it moves freely and is not bound up. If the belt refuses to turn, then suspect a burnt motor that will need replacement.
2) Check the connections to the motor. Make sure they are tightly secured. Loose connections can cause a reduction in power to the motor, allowing enough for it to hum, but not enough to turn the motor.
Replacing a washer motor is a fairly simple process:
1) Disconnect the wires, remove the mounting bolts, then remove the motor. Bench test it, if you wish to confirm failure.
2) Order a replacement that matches the original, especially in regards to its mounting arrangement. Compare the old one to the new one. Is the mounting bolt(s) in the same place?
3) Mount the motor and reattach the wires. When attaching the drive belt, give it a 1/2 -3/4 inch deflection at the midpoint. Your tub should spin now.
But if both the motor,the drive belt and even the transmission is functioning properly and you are confirmed that all is working,but still there is a problem,then the problem is there is something wrong with either the timer control dial or the agitator solenoid.
You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation
Posted on Sep 22, 2010
  • 10,865 Answers
Hello Robert. In order to reset the water level you must turn the dial to the highest setting and then back to what you want. So in your example, turn the water level to max and then back to small load. After you do this, see if it works properly. If it does, great. If not, the problem is most likely in the dial. Joe
Posted on Sep 17, 2010
  • Kenmore Master
  • 43,501 Answers
If the motor hums when it should be agitating in all cycles it is the motor...
If the motor just hums in that one cycle, then it is the timer...
So check out what is going on and then replace the bad part...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Posted on Sep 16, 2010
    Top Expert:
  • Kenmore Master
  • 75,817 Answers
98702 is not the model number of the washer, please provide the full model number
  • 11,896 Answers
Sounds like either a motor problem, or your tub bearings are seized up and tub is not spinning which is common. Try spinning the tub by hand. It should spin really easy if the the bearings are good.
  • 3 more comments
  • Nate Stansfield
    Nate Stansfield Sep 16, 2010
    A Faulty start capacitor or faulty clutch could also cause the motor to hum and not operate normally.
    The motor should be running in drain and spin. If the motor is not
    running or humming then the most likely cause of this problem is not the
    motor or timer but the lid switch.
    If it hums, it could be motor, tub bearings or clutch.
  • Nate Stansfield
    Yes not a problem.
  • Nate Stansfield
    Nate Stansfield Sep 17, 2010
    From what I have been told by Kenmore. There are several machines that use these parts including other brands that aren't even kenmore. There are over 20 machines that use these parts.
    So what you are saying, is that I need to get the Model # of my specific machine before we can go further, is that what I hear you say ?
  • Nate Stansfield
    Nate Stansfield Sep 20, 2010
    The tub only spins one way, the agitator rotates back and forth and up and down. The motor or tranny doesn't do with the draining. That would be the pump.
  • Kenmore Master
  • 17,129 Answers
If the motor is having a starter capacitor it has gone weak. Look into the motor and see that a capacitor is fitted on the windings. Remove to connect the same value of MFD/Voltage.
The motor should run now.
If this wont solve also check iff there is friction on the spindle that is preventing the motor to turn.
Remove the belt and check for free movement of the spindle or else remove to refit.
  • Donald DCruz
    Donald DCruz Sep 17, 2010
    Your Welcome.. hope you get this right!
Have a whirlpool washer that now hums when I turn the cycle on, no water just a hum
I had a similar problem - had to get a technician out - there was a valve at the back of the machine that allows the machine to fill. It had split (apparently its a common problem? there are separate valves for hot and cold water, so I'm not sure if using a different cycle choice (ie cold only), may let the machine fill?). 10 minute fix job
Jul 14, 2012 | Whirlpool Washing Machines
My Kenmore 400 washing machine is relatively new and has always worked well, until yesterday when we were washing a load like normal and the washer just stopped working after filling full of water. We've...
My would fill up with water then not spin. Then it would do nothing. I called a repair man out it was the safety switch. You remove the top where the dial is and to the left side of the machine you will see a black connector, it plugs into the switch, the swtich will have a green ground wire. I replaced the switch it works great. The switch is $8 on amazon.
Feb 19, 2011 | Washing Machines
Washer on normal wash only hums , will not fill with water
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Nov 29, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Washer hums
Under the tub is a round coupling that wears out. This needs to be replaced. When the washer is over loaded it puts to much stress on this coupling and wears it out. You have to take out the drum to replace it. As for it not filling, check the water vavles that supply the washer they may have been turned off
Sep 14, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
The washer only fills up full even when I put the load size on sm
Check the other knob or switch on top. Perhaps it has some settings regarding small, medium, or large load. This switch may be defective. Go to
www.repairclinic.com for more help on removal and replacement. You can also order a new one from them.
Mar 14, 2009 | Washing Machines
Maytag Atlantis MAV7600AWQ Washer. Delayed fill
ALL WASHERS COME WITH SCREENS AT THE
WATER CONNECTIONS.DISCONNECT THE HOSES AFTER TURNING OFF THE WATER.THEN,CHECK THE SCREENS FOR MINERAL BUILDUP.CLEAN THE SCREENS IF
NEEDED AND GO FROM THERE.
Mar 07, 2009 | Maytag MAV7600 Top Load Washer
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Its fills with water but then sits & hums - dont agitate,drain
It sounds like the controller/timer is bad. If this is an old dial timer type control, can you turn the control and cause the washer to drain? If so, replace the timer control.
If it's an electronic control, then look for a failed sensor as it's very unlikely to be the control.
Jan 15, 2009 | Roper RAX4233PQ Top Load Washer
GE washer repair
to start I will never again buy another GE product for as long as I live. I am having the same problem w/my GE washing machine. I have to manually turn the dial to make it go thru its cycles. the problem is the 'timer' must be replaced. good luck trying to get their customer service dept to help you with anything. they are useless.
May 06, 2007 | GE WDSR2080D Top Load Washer
Kenmore 98702 Stacked Washer/Dryer Logo
105 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
