Question about Kenmore 24 in. 15689 Built-in Dishwasher
My dishwasher doesn't drain water at all. i try to put drainex also not working at all. nothing is stuck there still clean water isn't drain .
    Champion:
  • 202 Answers
Water pump out or not going into the pump cycle could be a timmer problem or some thing stuck in drain hose to despoial or could be the plug in the despoial if a new one was just installed
Posted on Sep 16, 2010
My dishwasher isn't draining after it's cycles.
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Aug 30, 2011 | Whirlpool DU912 Dishwasher
The second led is flashing. Water did nit drain at first. Then drained. Cannot press the start/reset button, nothing happens. Sounds like the pump was working, now doesn't seem to be. Help!!!
Hi
Daniel
Aug 27, 2011 | Dishwashers
Our dishwasher isn't draining
Hi
Daniel
Aug 04, 2011 | Kenmore Dishwashers
My dishwacher isn't draining and make a noise..
Hi
Daniel
Jul 21, 2011 | Frigidaire 24 in. FDB1050REC Stainless...
Water does not empty from dishwasher
Hi
Thanks for using FixYa. Dishwasher not draining properly or not draining at all issues can arise due to different reasons. Usually, these issues are related to kinked hoses, knocked out disposer unit (if connected with the dishwasher drain hose) & clogged drain pump & filter. Also note that dishwashers do not drain completely after a finished cycle and this is normal. Dishwashers are designed to leave some water in the unit to ensure that the heating element doesn’t overheat. If you suddenly begin to experience a large amount of water being retained in your dishwasher, you have a problem. Some of the most common reasons include that the drain hose isn’t working properly, the drain pump isn’t working correctly, or possibly there is a plumbing problem in your home’s drain lines. First check whether the drain is not clogged or blocked and the line is not kinked. Check all the hoses for blockages & also clean the air gap. If you have checked the drain hose and can’t locate the problem, then it is an issue with the drain pump of the dishwasher. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 04, 2010 | Maytag MDB9750AWS Built-in Dishwasher
WHICH BUTTONS DO I PRESS TO FORCE THE DISH DRAWER TO DRAIN EXCESS WATER?
Just run the shortest wash cycle and check if it empties in the end. If not, then you have some blockage in the filter sump.
Go to the part of the user guide which explains how to clean drain filter and filter plate.
Hope this solves the problem.
Jul 04, 2010 | Fisher and Paykel 24 in. DD603H W Built-in...
The door on my dishwasher everytime you open it is making a loud creaking sound and there is water at the bottom of the dishwasher always. what to do?
Hi
First check whether the drain is not clogged or blocked and the line is not kinked. Check all the hoses for blockages & also clean the air gap. Has the disposer been replaced recently? If so, chances are the knockout is still in place. Simply remove the drain hose from the disposer, and knock out the plug. If the disposer has not been replaced, try removing the drain hose from the disposer and use a wet-dry vacuum (prepared for water, of course) to **** any water (and hopefully anything else) from the drain line. Then reconnect the hose, and test the unit. If you have checked the air gap and the drain hose and can’t locate the problem, then it is an issue with the drain pump of the dishwasher.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Mar 03, 2010 | KitchenAid Dishwashers
Does not drain water out at end of cycle, I have tried cleaning out all the screens,have opened the impeller cover and checked that the impeller is clean and free. When I put together, it runs for 2 or 3...
Hi
Thanks
Rylee
Dec 23, 2009 | Bosch 24 in. SHX33A02 / SHX33A06...
My electrolux 6115 dishwasher will not drain, it beeps constantly. when i reset it nothing happens
Hi
Thanks
Rylee
Dec 10, 2009 | Zanussi 24 in. DE6965 Built-in Dishwasher
My dishwasher keeps washing, doesn,t go through the cycles, i have to push cancel and drain.
Hi
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Oct 27, 2009 | Whirlpool 24 in. DU1100XTPS Built-in...
Kenmore 24 in. 15689 Built-in Dishwasher Logo
54 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
