Question about Sylvania G-Netbook
It says I am connected to the wireless with excellent connection and still it wont let me get on the internet it says cannot find server-This page cannot be displayed-DNS error. I bought three of these netbooks for the kids I have called a million times and have had them for two weeks I need to get them running or I'll have to take them back to the store can you please help me, as the others I have had no response and left my number a million times please help?
Mine had a default ip address for dns server of
192.168.20.1 which was not the address of my router.
When I went into the router and changed it to that number it connected and I am happily on the internet.
I have not tried it at a public hot spot.
Posted on Sep 21, 2010
  • Tracy1220 Dec 07, 2010
    hello, you said that you had the same problem. So do I but i cant even figure out how to change the ip address. can you help??
I have just installed netgear wireless ADSL2 modem router. The wireless works fine on one laptop and iphone but even though my other laptop says it is connected and the signal strength is excellent, I...
is your laptop getting a DHCP address? is it getting the correct DNS? Do this by going to control panel. Network Connections. Right click on the wireless connection. choose properties. double click oo TCP/IP. set to DHCP
Also check your Internet Explorer settings to see if it is using a proxy server under internet options. connection settings. If it is on or set to a proxy server. turn it off.
Mar 06, 2011 | NetGear DG834G 54 Mbps 802.11g Wireless...
I just moved into a new apartment and I am currently attempting to use the same linksys router that I used at my old place (without difficulity). My lap top in the bottom right corner displays...
> excellent connectivity
This refers to the wireless connection between your computer & your router, not to the connection from your cable-modem (or DSL-modem) out through your ISP to the Internet.
If you use an Ethernet cable to connect your computer directly to the cable/DSL modem, do you still have "intermittent" problems?
If so, then your router (or other wireless devices, such as your neighbours' router, or your neighbours' wireless telephones that are trying to operate on the same broadcast frequency) is the problem.
Aug 21, 2010 | Linksys Wireless-G WRT54GS Router...
Excellent Wireless signal but limited or no connectivity
You will need to check the wireless settings of the router.
If your network is secured then make sure that you are typing the correct network key.
also make sure that the DHCP server is enabled on the router.
is there any computer connected to the router ?
If yes then you can open the router set up page on that computer.
Router set up page is the page where you can check all the wireless settings of the router.
Click here for step by step instructions
Apr 30, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
The other night I thought that one of the connections to my internet server went out and I unplugged it and my router. Now my server and desktop are working but my laptop say that it is connected and has...
Plug in Internet cable into WAN Port, Switch OFF your Router and then ON, Disable Wireless Network Card of your Laptop and then Enable. Verify IP configuration of the router and Internet Server. Also check if it is DHCP or Manual. Follow instructions.
Best of Luck,
Regards;
Hassan
Aug 04, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
I have a modem with a wireless card that AOL Broadband provided. It is a Comtrend CT-534 and works great when connected to my desktop. But when I try to use the wireless card to connect to my laptop I get...
If you are getting a connected and excellent signal for your wireless connection then you need to double check the IP address. If you are not connecting to your Internet Service Providers Web server then this would block you from being able to connect to the web. While you are connected to your wireless card click on start>run>type in "cmd". This will bring you to the DOS prompt. Type in c:\ to get to the root directory. Then type in "ipconfig /release, then type in ipconif /renew. This will reconnect your network to your ISP's web server. If this does not work then the problem is at the ISPs end and there is nothing you can do to correct it immediately. You need to call your Internet Service Provider and explain your problem to them. What is happening is that your router DHCP protocol is not providing you with a proper IP address and they can only fix it on their end if the ipconfig does not fix it.
Don't forget to rate this solution with 4 stars.
Jan 14, 2009 | Computers & Internet
Belkin wireless problem
If you are connected straight from the modem, your router will not have internet access, only if your modem is connected to the router you will be able to go online wireless. connect your modem to the router nad router to the desktop, so that you can access both wired and wireless connection
Aug 12, 2008 | Belkin (F5D9230-4) Wireless Router...
I can't connect to my wireless Netgear WNR834B because of "improper proxy or firewall settings". I am connected with an excellent connection strength but cannot view any web pages etc.
No problem, I am here to help. Here is a step by step instructions to solve this.
1:Open Your Internet Explorer.
2:Go to where it says Tools.
3:Click On Internet Options.
4:Now go to the tab that says Connections.
5:Now click Where it says LAN Settings.
6:Make sure the box is unchecked where it says Proxy Server.
(Note: If that box was checked on that was causing the Problem.
Thank You!!!!!!!
Jun 23, 2008 | Computers & Internet
Internet Explorer cannot display the web page
your router needs to be configured to let your laptop in the network
Apr 09, 2008 | IBM ThinkPad R50e Notebook
Enuwi-g2 problems
What operating system are you using, Win XP?
Go to the control panel - look at Network Connection, click on properties on your USB adapter, click on Internet Protocol (TCP/IP), then Properties, make sure Obtain an IP address automatically is selected.
Also make sure your USB adapter settings (SSID, WEP/WAP etc) matches your Access Point settings.
Mar 04, 2008 | Encore Wireless Ethernet Network Adapter
Sylvania G-Netbook Logo
599 people viewed this question
Top Sylvania Computers & Internet Experts
Mike
Are you a Sylvania Computer and Internet Expert? Answer questions, earn points and help others
