Question about Canon imageRUNNER 400S Copier
WHERE DO I FIND THE PAPER COUNT? - Canon imageRUNNER 400S Copier
  • 62 Answers
Open front door, on the left hand side there is a hard counter, I believe three of them, top one should be total counter.
Posted on Sep 17, 2010
Will not feed 11x17
You probably need to set the user settings to "long doc" mode.
1) When the machine is in the standby state,
press the NEW FILE key and Count Only key
simultaneously. During the user mode, the
LEDs of the NEW FILE key and Count Only
key illuminate and the address (U01-U10)
and data (the last digit) appear on the
counter display.
2) When changing the address, use the NEW
FILE key. Each time NEW FILE is pressed,
the address changes, cycling from U01 to
U10.
3) When changing the data, use the Count Only
key. Each time Count Only is pressed, the
data changes.
4) Pressing the Stop key exits the user mode.
Long document mode =U10; 0=normal and 1=long document mode.
Happy Scanning!
Scan-R-Store
Scan Store provides service and maintenance contracts on all Canon Fujitsu...
Apr 02, 2014 | Canon DR-9080C Path-Through Scanner
Tip
How to get the page count on a Brother HL-6050
To obtain a page count (also called a meter reading) from a Brother HL-6050 printer, follow the steps below. (This procedure also applies to the HL-6050D and the HL-6050DN models.)
A. When the machine is on and ready to print, press any of the following keys to bring up the menu: Set, Back, +, or -.
B. The first menu heading that appears is Information; press Set to select it.
C. Use the + or - keys to scroll through the Information menu until you see Maintenance.
D. Press Set to select it.
E. The first option that you'll see is Page Counter; press Set to view the count.
The number of pages printed so far will appear on the screen. Once you've seen or recorded this number, keep pressing the Back button until you're back at the Ready screen.
If you would rather have a printout with the page count on it, you can get that instead by simply pressing the Set button three times from the Ready screen. The first time you press it you'll bring up the menus, the second time you'll select the Information menu, and the third time you'll select Print Settings. When you choose Print Settings, three pages of information will print out, showing supply usage, jam counters, and machine settings. On the second page, about halfway down the page under the <Device Status> heading, you'll see the page count. Beneath the page count, you can also find the number of pages printed from each paper tray, as well as the page count broken down by paper size (for example, letter-size paper, legal-size paper, or envelopes).
on Sep 16, 2010 | Brother HL 6050 Laser Printer
How to reset airbag light on 2006 honda crv
under you fuses box is a yellow wire it see is conect to the fuse box but it just plug in to remove it and take a paper clip and conect it into the two pin wires turn ingnition on possition and count 6 second then remove the paper clip and count 4 seconds then plug it in and count 2 seconds and the air bag light flash it 2 time fast and the code are erase
Apr 01, 2014 | Honda CRV Cars & Trucks
Installed new maintenance kit for 9050 printer. Trying to reset page count and now the printer is jamming error code 13.02.00.
No relate with paper jam & page count resetting. Might be maintenance not installed properly..Remove paper jams, restart printer,if error 13.20 appears check some paper/paper particles jammed.. 1. Print from manual tray.
A. If paper is jamming, check registration assembly, clean it,best method for cleaning is vacuum cleaner in this area. chk..
B. Take out registration assembly, check clutch gears, driving gears, solenoids..
2. Check pick up rollers are properly installed in tray 2 & 3..
3. Check PIU unit for paper jams
4. Check Fuser sensor flags.
To reset the counter: Hold enter button & switch on the machine, wait till display shows cold restart, scroll to reset maintenance kit with help of arrow buttons & enter. Printer restarts & counter will become Zero..
Jan 07, 2013 | HP LaserJet 9050 Printer
I need to know HOW TO GET A CURRENT PAGE COUNT.
To get the page count, press Function, then choose Data Registration, then #, then scroll down to Printer, press OK, scroll down to Page Count, press OK.
Mar 29, 2011 | Canon CFX-L4000 Plain Paper Laser Fax
Oki C5500 printer keeps jamming
Open the tray and find yout imput roller. You can remove this roller and put it back on the other side. Normally this is caused because it is worn. The inside of the roller is like a new one.
Jan 11, 2010 | OKI C5500n Printer
Can the Canon Imagerunner 3030 count/sort sheets of paper out for you?
please, the count you want is copies made or you want the machine count the originals ??
The machine count 1 copie for A4 (LGL) and 2 copies for A3, called double count.
Nov 20, 2009 | Canon Office Equipment & Supplies
Page count
Press Function,Dataregistration if user settings is displayed on the screen ,press # button.1 sssw will be displayed on the screen.Use the arrows to scroll down to "printer" press set or ok and scroll down till you get print count press ok or set.
Mar 09, 2009 | Canon CFX-L4000 Plain Paper Laser Fax
Page count
If you don't have the paper manual, check out the manual on Konica-Minolta's website: DI151 User Manual
From page 4-2 and following of the paper manual or page 48 and following of the PDF document: When 12,345 shows on the Total Count display: <the readout shows:> ct 01 23 45
When 1,234 shows on the PM count display: <the readout shows:> CP 00 12 34
To select a Total Check function: Press and hold the Clear/Stop key for three seconds. The total count will be displayed. Press and hold the Clear/Stop key again for three seconds to display the PM count. Press the Clear/Stop key to return to the previous status mode.
From the way it's written in the manual (I've never seen this machine), it sounds like the readout will pop up
ct
01
23
45
ct
... etc., so you may need to have something to take notes on.
Sep 18, 2008 | Minolta Di151 All-In-One Laser Printer
Epson 9800
Low Paper message on the LCD means that the media counter has been turned on and it is now at a point where the printer thinks that there is not enough paper to run a job. Here is what you need to do:
1) Turn the printer off
2) While holding the Pause Button turn the printer back on
3) Scroll down to Paper Count
4) Hit Menu to select
5) Scroll up to off
6) Hit menu again and a star will appear indicating that the Paper Count is off
7) Power down the Printer and then Power it back up
This should take care of it. If you have any other issues, feel free to contact me directly.
Sean McGettigan
sean.mcgettigan@lexjet.com
LexJet - www.lexjet.com
(800)453-9538
Feb 27, 2008 | Epson Stylus Pro 9800 InkJet Printer
Canon imageRUNNER 400S Copier Logo
37 people viewed this question
old marine
old marine
