Question about DeLonghi MW535-U 1000 Watts Microwave Oven
How do i replace interior light bulb in delonghi microwave model am820agx
  • 4 Answers
SOURCE: GE microwave interior light bulb replacement.
It's pretty simple as long as you have an offset phillips screwdriver...
Of course, be sure to disconnect power to microwave and be sure not to touch the new halogen bulb with fingers.
STEP-BY-STEP:
First, remove upper vent panel and remove inner filter (same directions for just replacing inner carbon filter):
Then, remove inner plastic grille (2 screws) and final screw on left side of metal "air duct" - here's where you'll need the offset screw driver (and a little patience!):
Then, you can gently lift the sheet metal panel, find the light housing, squeeze and remove/replace :)
That's it...just replace bulb and reverse for reassembly. Be sure to keep track of screw locations there are various sizes/lengths used.
Doug
Posted on Dec 26, 2007
freetek
  • 5568 Answers
SOURCE: Burnt bulb in GE JE1590sc001 convection microwave
You can locate it by looking inside the cavity for an area that is perforated.
If this area is not a panel that can be removed, replacing it may (often) require removing a few sheet metal screws along the rear edge of the unit; rarely is the housing held on with more than that.
With the screws removed, lift up on the rear edge and pull toward the back.
DO NOT LEAVE IT PLUGGED IN!
Also, because there are components that may keep a charge (capacitors) for hours, I would recommend letting it sit unplugged overnight before removing the housing.
The bulb may be either a cylindrical type such as many sewing machines use or a smaller version of a standard bulb.
Neither of which anyone ever has at home, of course.
Any of the large 'home improvement' stores should have these 'made in China' bulbs at an inflated price.
Posted on Jun 03, 2008
SOURCE: Interior Light
The interior oven light can be accessed in the following way:
1.Open door and remove the top grill via the 2 screws along the top edge.
2. In the interior light will be under metal plate with fasten by single screw. The halogen bulb is rated at 120V 20watt. Looks like a G-8 bulb with 8mm pin spacing with o.a.l. 1-5/8" long
Get these bulbs cheap at http://www.1000bulbs.com/120-130-Volt-G8-Base-Halogen-Light-Bulbs/
Posted on Aug 31, 2008
SOURCE: Delonghi AC930AMQ Microwave, Interior Light Bulb
Managed to figure out what the problem was ,I was a bit heavy handed with the solder/flux which caused a short cleaned up the area around the solder joints and now working great
Posted on Feb 05, 2009
SOURCE: Microwave interior light
Very easy to replace...at least on my JVM1790. Remove the top vent....the long plastic thing that runs along the top of the MW. Two screws on top of the micro. Behind the charcola filter (if you installed one) is an access area to the bulb. remove one screw and the entire assy comes out. Simply R & R the bulb.
Posted on Apr 02, 2009
I need to change the interior light bulb in my Frigidaire over the counter microwave. The model # is FMV156DCA.
Good Morning Evelyn, thank you for allowing me to assist you!
Here are some simple troubleshooting tips to help replace the light bulb on your Frigidaire microwave, FMV156DCA.
    ·First, disconnect power to your microwave. This can be done by either unplugging it or at the circuit breaker panel.
    ·To release cover, remove the screw on the light cover (light cover may become very hot, do not touch glass when light is on).
    ·Remove old light bulb and replace only with equivalent watt bulb available from parts distributor or the manufacturer directly. Bulbs are also available at most hardware stores or lighting centers. Bulbs larger than 30 watts are NOT recommended.
    ·Close light cover and secure with screw removed in step 2.
    I hope this information proves to be helpful. If you have further questions, please do not hesitate to reconnect.
Nov 25, 2013 | Frigidaire FMV156DC Microwave Oven
My Delonghi AM820AGX microwave no longer heats up liquids/food. It turns on and looks like it works, but when I test the liquids/food, they are still cold. I could have possibly changed the settings...
It souds like a busted MAGNETRON, and replacing it usually costs almost the price of a new oven...
Nothing to do with a setting... Sorry!
Apr 15, 2011 | Microwave Ovens
Need instruction manual for a AM820AGX
You should be able to find help at the DeLonghi customer service site.
Jan 16, 2010 | DeLonghi Microwave Ovens
The bulb is usually run by one of the door switches, but in some cases they are run by a relay on the board.
I would suggest you look over our files on safety & door switches here:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/doorsw.txt
Please write back with more details if you need further help.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 05, 2008 | DeLonghi MW 605 Convection/Microwave Oven
Your post has two distinct model numbers shown, so it's hard to be precise, but I'll try my best.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
I have a diagram at my site which helps you find & replace many GE cooktop and cavity light bulbs. Other models are similar. It's at
http://207.234.249.73/mwd/ge_lamp_replacement.jpg
Always unplug a microwave before removing or installing any bulbs!
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there.
There may be a panel on the bottom covering the light(s), too.
If not, chances are you'll have to remove it from the wall, then remove the outer cover.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
If yours is an Advantium type, the following instructable should help: http://www.instructables.com/id/SZFF4WSF44XYT8X/?comments=all
Jun 03, 2008 | GE JES1289SK Microwave Oven
Interior Light
Jan 01, 2008 | GE JVM1790 1000 Watts Convection /...
Ge Spacemaker microwave - Model # JNM1851
They sometimes have a plastic cover over the bulb cavity that you can take off from the oven interior
Dec 23, 2007 | GE XL1800 1100 Watts Microwave Oven
DeLonghi MW535-U 1000 Watts Microwave Oven Logo
319 people viewed this question
Top DeLonghi Microwave Ovens Experts
William Miller
William Miller
Steve Mason
Are you a DeLonghi Microwave Oven Expert? Answer questions, earn points and help others
