Question about Jensen Car Audio & Video
I have a Jensen A-82 Power Amplifier that blows a fuse as soon as power is introduced. I checked continuity between the 12 volt input at the fuse and the metal housing. These two point are connected. Is this the source of my problem? Can I do anything about it? If not the problem, what do I need to check? Thanks Kim
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Jensen Master
  • 2,226 Answers
You more than likely have a shorted part(s) inside the amp. it's not really something that can be repaired if you don't know what you are doing.
Posted on Sep 16, 2010
Will there be interference if I hook a Jensen MDV6115 to a 120 volt tv?
Under no circumstances must you use a different voltage ! The power supply on these units are designed for 12v only.
However, if your question is simply referring to connecting the AV 'outputs' (i.e. yellow, red, white rca's) of your Jensen, to the AV 'inputs' of our TV, then that is fine. The AV outputs can be treated the same as any other video device.
Feb 07, 2013 | Jensen MDV6115
Blows fuse as soon as you put fuze in
Check the connections at the stereo: apparently the 12 volt battery and/or the switch 12 volt accessory wire at the stereo is making contact with ground.
Mar 23, 2011 | Jensen MCC-8320 Cassette Player
Red light comes on but the unit wount turn on
The red light is associated with the memory (constant 12 volt power). You also need switched 12 volt power (power with key turned to accessory)for the unit to turn on. If you installed the system yourself, you are looking for 12 volts on the red wire of the Jensen unit. If power exists at the unit, check the fuse of the unit and the fuse of the vehcile.
Feb 03, 2011 | Jensen Vm9214 Car Video Player
I have a JL Audio 500/1 that powers on just fine. But there is no output coming from the sub.
Did you check the fuse(s) on the amp itself ?
One or more of those fuses are for protection on the output side of your amp.
What about the 12 volt power from your battery, have you checked for 12 volts present at the input power side of your amp?
Don't forget that you need just as good of a ground as you need power supply!!!!!
Good luck !
Jun 24, 2010 | Jl Audio 500/1 Car Audio Amplifier
Blows 15 amp car fuse as soon as switch is turned on nothing plugged into inverter
If the fuse doesn't blow until you turn the inverter on, the problem is in the input circuit. First, be sure the polarity is correct when you're connecting the inverter. If you manage to get the 12 volts hooked up backwards this will blow the fuse. If the input polarity is correct, the diode inside that protects against reverse polarity may be shorted. Beyond that, it's difficult to make any suggestions about what parts to check. You would need to use an ohmmeter to check the parts in the input for very low readings from the 12 volt input to ground. If you can do this yourself or know someone who can, it might be worth a try. But if you try to take this somewhere for service - if you can find a shop willing to look at it - it may be more economical just to replace it.
Good luck with the inverter, and thanks for using Fixya!
Nov 24, 2009 | Powerline 0900-73 Slimline Inverter
I have an spl gorilla series 1250watt amp that blows fuses
REMOVE THE RCA INPUTS AND DISCONNECT THE SPEAKERS, THEN POWER THE AMPLIFIER UP WITH THIS NO INPUT, NO SPEAKER LOAD CONDITION. IF IT STILL BLOWS THE FUSE, THEN IT WILL NEED TO BE SERVICED. IF IT BLOWS THE FUSE BEFORE TURNING IT ON, THEN YOUR PROBLEM IS IN THE POWER SUPPLY SECTION. IF IT BLOWS THE FUSE AFTER ATTEMPTING TO TURN IT ON, THEN YOUR PROBLEM IS PROBABLY IN THE OUTPUT SECTION. ALSO KEEP IN MIND THAT THE P1'S ARE REALLY NOT RATED FOR THAT MUCH POWER AND YOU MAY HAVE DAMAGED THE VOICECOILS. BEFORE REINSTALLING THE AMPLIFIER, MAKE SURE TO CHECK THE SPEAKERS FOR SHORTED VOICECOILS OR YOU WILL POSSIBLY DAMAGE THE AMPLIFIER AGAIN. LET ME KNOW IF YOU NEED FURTHER ASSISTANCE.....V
Nov 19, 2009 | Rockford Fosgate P3001 Car Audio Amplifier
Kenwood KAC-729S keeps blowing fuses. Checked all cables, re-ran power, remote, and ground. All good, still blows them at power-up.
Hello opey_69a,
Here are the troubleshooting steps for fuses blowing.
1) Remove all wiring except ground, power and remote and see if the amp powers up without blowing the fuses. If it does, the problem is in the input cables or speaker wiring.
2) The use of loudspeaker impedances below the recommended minimums will cause the amp to draw excessive current - check.
3) A shorted or grounded RCA cable may cause the fuses to blow - check.
4) If an amplifier fuse blows continually, with only +12 volt, ground and remote leads connected, the amplifier is probably defective, most likely shorted output MOSFET's. In this case the amp needs professional repair or replacement.
Hope this helps.
Sep 19, 2009 | Kenwood KAC-729S Car Audio Amplifier
Blowing fuses
Are you sure you don't have the positive and negative power wires reversed?
Does the fuse blow without remote voltage applied?
Nov 09, 2008 | Jensen JPA285 Car Audio Amplifier
Car amp blows 12 volt wire fuse
the wire from your battery is blowing fuses? and you are using 20-30 A fuses? mine has a 100A fuse..look into getting new wire plus my wire is 4 gauge.., 1600 watts is too powerful for a 12 g wire and a 30 A fuse
Jul 26, 2008 | Car Audio & Video
Amp keep blowing the 20amp fuse
There seems to be a short circuit inside your amplifier. It could be one of the amplifier mosfer/transistors or a diode that is connected nearby the power input.
May 06, 2008 | Alpine MRP-T220 Car Audio Amplifier
Car Audio & Video Logo
154 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
