Question about Kenmore 33721 Upright Vacuum
How do I change the belt on my Kenmore 12 amp upright vacuum
Agent Don
  • 310 Answers
SOURCE: installing belt on hoover self propelled upright vacuum
http://geeksquad.fixya.com/ThreadView.aspx?prdid=40544&thid=641399
Installing belt on Hoover self propelled upright...
Posted by Fryeburger on Jun 02, 2008
Need help installing belt on Hoover self propelled upright vacuum
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Hoover Ultra U6430-900 Wind Tunnel Bagged Upright. The best way to install the belt on a Hoover to replace one or both of the belts @ the same time for the best cleaning. The average belt change is every 4 to 6 months for best results. There is a tool that looks like a screwdriver that has a right or left angle on the end that serves as a belt puller and to hook the belt(s) onto the brushroll 1st and then take your puller and then pull or stretch the belt onto the motor pulley. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
http://www.a-1vacuum.com/ 1-800-657-1874 Customer Service
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jun 02, 2008
ukvacfan
  • 328 Answers
SOURCE: How to change a belt
A very easy procedure!
Look at the front hood of the Purepower (where all the lettering is including the 1600 or whatever the model number and name is located at) and you'll see at the back two screws either side where the back wheels are. Unscrew these and then prise using your hand/fingers the floor selector dial knob off. Once that's done the hood will pop off and you can get into the roller brush and drive belt. Then simply lift out the roller brush and fit a new belt.
This method is for all Hoover Purepower models and DustManager uprights.
Posted on Sep 27, 2008
  • 6 Answers
SOURCE: Kenmore Elegance Upright Bagged Vacuum Belt Broken and Smelling
It sounds like the brushroll has caused your belt problem and will be the cause of your burning smell as well. What commonly occurs is that carpet fiber,hair,string, thread,etc got wound around the brushroll and some will get caught in the end caps which is where the bearings are.The end caps need to be removed and cleaned so that the bearings can allow the brush to rotate freely.Check that there is no melting of the end caps or the base plate where the end caps fit into the machine._Good Luck
Posted on Oct 26, 2008
Vac Belts
  • 701 Answers
SOURCE: how do I change the ******** belt in a Hoover
Here is a link where you can view the manual:
Hoover EmPower Manual and Belts
Posted on Dec 02, 2009
odiebugs
  • 949 Answers
SOURCE: Is there an easy way to see if a drive belt may be
Well there is only turning the vacuum over and see if the brush is rotating.
If it is not moving then you need to replace the belt.
If you need to know how to remove the bottom plate to replace the belt, please post the model number, the numbers you posted above are not the kenmore model numbers, the model numbers will look like this
316135912,FPF311PHSB, FGF316WGSK
Posted on Feb 15, 2010
How do I change the belt on the 116 model?
To properly fix a belt on a Kenmore vacuum, you will first need to indicate whether this is an upright or a canister vacuum. The model given, 116, is only the first part of the model number, and all Kenmore vacuums, upright and canister style, start with 116. There is a period first, then a whole string of numbers, 116.255553 etc.
Kenmore vacuums are mainly made by Panasonic for Sears, and most will use a Panasonic belt. If the belt is an upright, this makes it simple, and will be a Panasonic "UB" belt.
For a canister vacuum, most models use what's referred to as a cogged belt. This type of belt has little teeth on the inside of the belt, and is Panasonic CB-5 belt.
Instructions on How to Replace the Belt for an Upright;
There will usually be to plastic screws on the top of the agitator housing on the base of the vacuum, that will say belt access. Simply take a flat head screw driver, and turn the screws so that the screw is pointing up and down on both sides. Then pull the plastic agitator housing, or the top of the base of the vacuum off. Inside you will see a the roller brush, and the belt (or broken belt). Simply take the new belt and wrap it around the silver pulley located in the back of the machine, opposite the roller brush, and wrap the other end of the belt through the roller brush. Stretch the roller brush back into the housing of the machine, and replace the top of the base of the vacuum back on the machine. You should give the belt a tug, to ensure that the brush is spinning when the belt is being pulled..
Aug 02, 2012 | Kenmore Vacuums
Bissell Clear View Plus 12-Amp Vacuum
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
kjf
Jul 14, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
Lever & belt placement in Kenmore Progressive upright vacuum
You are correct. The belt is supposed to go around the peg that is connected to the lever so that when it is on the Floor /Tools setting the belt is not driven by the drive shaft.
Dec 05, 2009 | Kenmore Vacuums
My purple proggesive kenmore upright motor works but beater not beating help thank you
I just had the same problem - reset button didn't trip - cleaned the roller - ultimately found there is an override switch at the point where the hose attaches to the base of the vacuum - it disables the roller when you use the attachments. The hose had become loose (but not disconnected) enough to trip the switch. An easy fix after alot of tinkering... p.s. All those "experts" that said to change a belt obviously don't understand that this model is beltless...
Nov 09, 2009 | Kenmore 31913 Progressive Direct Drive...
How do I to change the belt on an eureka altima 12?
the belt is on the bottom right (looking at it from the front). the Eureka website does have the manual for download, http://www.eureka.com/service/manuals/80244.pdf
With the vacuum flattened (straightened) out, turn it over and remove the back roller cover, (2 screws) once off, the roller should just pop out on the opposite side (opposite from the belt). Don't forget to turn the roller to center the belt once you have it on.
Jun 14, 2009 | Eureka Altima Upright Vacuum Model 2996AVS...
My bissell clearview 12 amp vacuum's motor races. Belt seems to be fine.
heatman101
rrugf
May 02, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Change the belt in my kenmore power-mate 120 amps...how to open it to get to where the belt is???
HELLO, JUST REPLACED THE BELT ON OUR'S. FIRST TAKE LITE LENSE OFF THERE WILL BE 2 SCREWS, REMOVE. THEN FLIP OVER POWER MITEON EACH SIDE PRY WITH 2 SCREW DRIVERS WHERE THE ARROWS ARE TO SEPERATE & THERE IT IS THE BELT. MIKE
Sep 13, 2008 | Kenmore 23313 Whispertone Bagged Canister...
Bissell 12 amp model 6850
That would be the motor shaft, if it has power to it and is froze up, you will have to replace the motor.
Jun 14, 2008 | Bissell Lift-Off(R) Revolution(R) Turbo...
Kenmore 33721 Upright Vacuum Logo
53 people viewed this question
Top Kenmore Vacuums Experts
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
