Master
- Posted on Sep 16, 2010
Re: I have compaq presario V3000 model when i open the...
You may need to take the lid apart and check the connecting ribbon cables, sounds like you have a loose connection.
You may also have a loose solder connection, that only connects at a certain angle. A little heat from a soldering iron should do it
thanks for prompt advice i opened LCD part and when i press the screen from the edges and tilt a bit then display works else doest work. i think now i have to change the screen or that too can be repaired ?
