Question about Whirlpool Refrigerators
Whirlpool fridge edslhaxmb00. not defrosting, freezer not freezing
  • Whirlpool Master
  • 17,129 Answers
If freezer is not cooling then the chance of frost forming is also out of question. So we need to start of by checking on the prrimary component, the compressor. Make sure the speed of the motor is humming welll or check the motor capacitor. Use a clamp tester to measure the current factor to see the load. If the pumping is low then check for gas pressure in the unit. If not you will need to check why the gas leaked check the leak with compressed air pumped in and monitored.for leak.
Only then recharge and seal.
Test the motor before gas filling to confirm the performance.
Once it cools and freezes then you will need to check if the auto timer defrost works.
Posted on Sep 16, 2010
Can you tell me why please?
All the big cooling happens inside freezer compartment. Freezer gives little cool air to fridge compartment. Now when the vent blocks that little cold air cannot go into fridge compartment. Thus your freezer works good but not fridge compartment. Milk goes bad but frozen meet keeps good.....
Vent freeze up either due to defrost problemt, defrost drain line problem, Evaporator fan problem or even can be your damper motor not opening due to unit failure or frozen damper door.
Sep 19, 2014 | Whirlpool GX2FHDXVY Gold Stainless Steel...
Whirlpool gs6heXnl00
Its defrost problem, the freezer should cool, then freeze, then defrost cycle should start. In your case freezer is cooling, then freezing, but its not defrosting. That's why fridge section is not cooling.-------
Click this link below and follow the troubleshooting:----
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
This will help.Thanks.Helpmech/.
Oct 23, 2011 | Refrigerators
Fridge not cooling whirlpool model gd5rhaxn000
Aug 28, 2011 | Whirlpool S20DRSS33 Side by Side...
Fridge is not cooling. lights are working. freeer is working
Jul 24, 2011 | Whirlpool 24.8 Cu. Ft. Side-by-Side...
Model WBM412 - Freezer works but fridge does not cool at all.
Its due to freezing behind the freezer coil by which freezer fan gets logged to function. Defrost the refrigerator and then run. Keep freezer temp between -14*F and 8*F and fridge temp between 36*F and 46* F. And also check defrost cycling is properly working.
Thanks, helpful?
Feb 26, 2011 | Whirlpool WBC3525 (12.36 cu. ft.) Bottom...
I have a whirlpool gb9shdxpq bottom freezer fridge. It stopped getting cold in the fridge part so i started troubleshooting. The freezer was still frozen and the frost is what was causing the fridge to not...
Part 5 in this diagram is your electronic control which controls the defrost cycle. Like you said you know the heater and the defrost thermostat works. So the control is all that's left.
Oct 10, 2010 | Whirlpool GB9SHDXPS Stainless Steel Bottom...
I have a Whirlpool fridge freezer ART 731. The freezer is working fine but the fridge has started to get too cold and freeze the items inside although the control is at its lowest.
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Aug 27, 2010 | Whirlpool ED5FHEXMQ Side by Side...
Whirlpool Mod ET18LKXHWo o Fridge not freezing,
Your defrost timer located inside the control panel is bad OR the defrost thermostat located on a freezer coil is bad.
Get down low and look up at the bottom of the control panel.
You will see a small round hole. Onside the hole is the defrost timer advance knob.
Use a flat blade screwdriver and SLOWLY turh the slotted knod clockwise until the refrigerator clicks off.
Wait a few minutes then open the freezer door and listen for a sizzling sound from the freezer compartment.
If you do hear a sizzling sound that would be the defrost heater melting ice.
If you do not hear a sizzling sound,unplug the refrigerator and remove the rear freezer panel to expose the cooling coil.
Clipped to the coil will be the defrost thermostat. It will need replacing.
If you do hear the sizzling sound the defrost timer will need replacing.
Jul 20, 2010 | Whirlpool Refrigerators
Water is collecting in the refridgerator
defrost drain under coils in freezer is blocked or frozen with ice down in defrost hole. defrost hole with hairdryer but be careful not to melt the plastic.
Jun 09, 2009 | Whirlpool ET1MHKXM Top Freezer...
Water dripping from freezer
a quick fix I found is to hang a peice of copper wire from the defroster bar in the freezer and let it hang into the drain tube when the defroster bar gets hot it heats the copper to prevent the freezing,but the thing you should do is check the resistance with an ohm meter across the defroster bar,if its ok its the defroster assembly located in the fridge
Jun 03, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
Refrigerators Logo
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
