Question about Dynex DXR24TV 24" TV
DX-R24TV I had just 3/4" Horiz. I change 680mfd & Vertical IC * Now I need to open the service memu ."Can You Help??'Picture Is not linger* I've changed 4 other cap in vertical circuits Raster has About 1/2" black at bottom till tv warms up 5-10 minutes &
  • 4 more comments
  • oleman09 Sep 16, 2010
    NEED TO OPEN SERVICE MEMU
  • oleman09 Sep 17, 2010
    just need to open service memu
    if can't help ,just credit my credit card
    I Remeber Now Funai Told Me About How To Change The Remote To A Service Remote
    still have 3/4" at botton of raster/have checked resistors changed cap./wish I could find A Service Manuel
  • oleman09 Sep 23, 2010
    been there/i'm 75 years into electronics service since 1956/(what i really need was service manuel. But I Do Thanks You For Your Comments
    i think that what i got (no service manuel
  • oleman09 Sep 28, 2010
    don't know what you speak of.
    BUT,PLEASE JUST REMOVE ME FROM YOUR E-MAIL LIST !!
  • Dynex Master
  • 19,396 Answers
Hi..
About the service mode, service manual for Dynex CRT models is not easy to find.
Test the following, it works on some Dynex and Insigna TVs:
Take apart the remote and find the hidden buttons inside the remote.You should find several switches not connected to keyboard. Locating the right ones is a problem that you must solve on the spot.
Turn the TV on and push down first the left hidden button and then the right hidden button without holding. If that worked the word TEST will be displayed in upper right corner of the TV screen. Use number keys to select menus, nr.1 and nr.3 have video adjustments needind in convergence.
That is the way it used to work on Dynex/Insignia CRTs.
by the way if the "Raster has About 1/2" black at bottom till tv warms up 5-10 minutes" that means that the problem cannot be fixed with service mode adjustment. Problem is a defective component. Check STK ICs soldering joints, read Ohms on resistors and ensure they have continuity
If any of this help, do not forget to accept the solution.
Regards.
Ginko
Posted on Sep 17, 2010
  • 456 Answers
The best thing I can suggest for this is to contact the TV manufacter or the closest authorised repair agent as the guide to access the service menu will be located in the service manual, often restricted to the brands tech support team or the authorised service agent.
I do not have a servive manual for this brand so I can't offer any assistance on what it is.
I hope this helps. Good luck.
  • Dynex Master
  • 5,807 Answers
Sometimes new capacitor doesn't really mean OK,
especially for low value capacitors, ( like 1uF and 2.2 uf )
There still other causes besides capacitor, a changed-
valued resistor , If it looks OK after warming up
Trace the input of the vertical IC , replace the capacitor
shunted to ground.
Check the diode ( Boost stage )
Check/replace output capacitor
Check the capacitor for the supply of the Vertical IC
It could also be coming from the Vert osc.
Posted on Sep 16, 2010
  • 3 more comments
  • Rommel Cana
    Rommel Cana Sep 19, 2010
    A slightly low B will produce the same effect.
  • Rommel Cana
    Rommel Cana Sep 23, 2010
    thanks!
  • Rommel Cana
    and i know , you still can remember what is the effect of changing the resistor value,
    and the consequences on changing values
    on the service mode,
    it doesn't include the linearity but only height
  • Rommel Cana
    i have converted Vertical IC using Power Transistors which started year 86, when the IC of Toshiba TV is very expensive and hard to find, if there is a will, there is a way.and I hope
    also by now you have all the equipments that you need.Good luck !
  • Rommel Cana
    Rommel Cana Sep 28, 2010
    check /replace also the 100 uf after the diode ( boost )
HLN507W Samsung DLp Horiz. lines
it sounds like the dmd board is failiing
Mar 13, 2009 | Samsung DLP HL-P5663W 56" TV
Red power light flashes on then goes out
ok i think u have a bad vertical ic that is the burning smell i think. i should have i think la7836 ic but u have to change the 12 volt zener dioe and a 470 mfp at 50v cap with the ic and that should fix it.now there is one thing u could chek right behind the horiz output transistor u should see i little cap it may be yellow or blue the top of the cap will be dark black and that part will cause the same thing u have to cange it to 474pf at 2kv . i hope this help u marty
Sep 16, 2008 | Hitachi 53UDX10B 53" Rear Projection...
No picture
if there is only one horizontal line you have a problem with vertical deflection section
May 28, 2008 | Panasonic PV-DM2794 27 in. TV/VCR/DVD...
Vertical section problem? Part of screen is blank
replace cap. 2465, cap. 2561, cap. 2460, and d6460
Feb 23, 2008 | Philips 27MT3305 27" TV
Tv problem
Bad capacitor in vertical output IC circuit + check power supply
Last, replace IC.......................T.
Nov 09, 2007 | Philips 27PT6441 27" TV
Picture shows only about a 2-3" blue,green,or red vertical line down the middle
If your seeing vertical line across the screen you need to check the components in the vertical stage as well as the vertical IC could be bad, or the yoke could open.
Also check if any voltage reaching the vertical stage.
Good luck.
Was this help full.
Oct 31, 2007 | Panasonic PT-47WX53 47" Rear Projection...
Mitsubishi cs-35401television
HORIZONTAL FAILURE AND LINE DOWN THE SCREEN. REPLACE T5A1 LOCATED ON PCC-3-PCB. PT#349P145030(FOR CS-35401,CK-35402 ONLY) Hope this helps! Troy
Sep 11, 2007 | Televison & Video
Vertical output problem
you probably just need to resolder the vertical output IC. It will be mounted on a heat sinc. probably 7-10 pins. Part number may start with "LA" like LA7845 or similar, there are others though. You will probably see the rings around the solder joints on the bottom of the board. Good Luck
May 17, 2007 | Toshiba 36AFX61 36" TV
Toshiba 36afx61 tv
You have a cold solder connection on the vertical output IC or in the sweep power supply that feeds the voltages to the vertical output IC. You can download a service manual from here: http://www.servicemanuals.net/results.aspx?type=SM&brand=0&model=36AFX61 Good Luck
Apr 27, 2007 | Toshiba 36AFX61 36" TV
Sanyo TV model DS25710 or DS25730
Set has a bad vertical sweep IC. Also This Sanyo has a tendancy , when the IC blows out , to take the fusable resistor in the sweeo supply that feeds the vertical IC. This set should only be serviced by a trained technician because of ther high Voltage that lingers within. This repair should run you antwhere from 85.00 to 150 bucks. Good Luck
Jul 31, 2006 | Sanyo DS24205 24" TV
Dynex DXR24TV 24" TV Logo
120 people viewed this question
Top Dynex Televison & Video Experts
Jaime Hernandez
Are you a Dynex Televison and Video Expert? Answer questions, earn points and help others
