Question about Maxtor Hard Drive
Maxtor 93073u6 jumper settings
Drive is set up like this, :::.: The far left two r connected vertically. The next TOP two r connected horizontally. How do i set them so that this drive is slave?
    Brigadier General:
  • 3,614 Answers
Primary -or- secondary slave..?
Posted on May 17, 2008
Hi, I have a burned element on my HD. Need to know the exact type of the element. Can you help? I'm able to describe the position of the electronic element. Thanks! HS
Posted on Sep 12, 2008
I have a maxtor 51536h3 harddrive, I need to know the jumper settings for running single as a master and slave to transfer the data to another harddrive. THANKS
If you have two hard drives on the same IDE cable, then set one as Master and the other as slave.Set which ever one has your operating system on it as the master (though it doesn't really matter). Once you get them both plugged in and your computer boots up. You should see both drives and can transfer data as you see fit.
Mar 03, 2011 | Computers & Internet
What is the master setting for d740x
Here is the Maxtor Jumper settings guide:
The jumper configuration you're looking for looks like a horizontally flipped L next to the single top-left jumper.
Mar 29, 2010 | Maxtor Hard Drive
I need jumper settings for maxtor n256 model 96147h6 i wish to run it as a slave pls help. thx
For use as slave there is no jumper connected. (Master on/slave off0
Oct 04, 2009 | Maxtor Hard Drive
Jumper settings for a maxtor N256 master with slave
Select the maxtor HDD as master by setting the Jumper to the extreme left of the hdd; i.e. next to the data cable.
Remove all jumpers from the other HDD which you want to put as slave.
Sep 02, 2009 | Maxtor DiamondMax 80 (96147H6) 61.4 GB...
I want to install the Maxtor 32049H2 N256 as slave Hd in my new computer how do I set the jumpers ?
hi frnds... step by step way are following link
Apr 25, 2009 | Maxtor Hard Drive
Can not find Jumper diagram on N256 Maxtor model 33073H3
Hello there soggytundra, here's your GEEK-steer ...
Despite your question being posted here 5 days ago, I'll presume you still (and if not, then someone else will) need the answer ...
Virtually all Maxtor drives adhere to the following general rules concerning jumper settings (at least up until now):
= MASTER (M): Insert jumper over the FIRST COMPLETE pair of VERTICAL pins.
Xoo o oXooo Xooo
Xoooo Xooo Xooo
= CABE SELECT (CS): Insert jumper over the SECOND COMPLETE pair of VERTICAL pins.
oXo o oXooo oXoo
oXooo Xooo oXoo
= SLAVE (S): Do NOT insert ANY jumpers (or at least NONE VERTICALLY, but you may HORIZONTALLY across the TOP row as simply a means of storing the jumper).
ooo o ooooo oooo oooXX oooXX ooXX
ooooo oooo oooo ooooo oooo oooo
TIP: As a general rule, if you KNOW the role of the jumper capable device you're installing, it is better to NOT use Cable Select (CS). In this case you do, therefore it would be best to specifically designate the (33073H3) drive as (secondary) Slave [and your other (primary) drive as Master].
Good luck and GOD-speed. Please post back if you have any further questions, and/or just to let me (and others in similar need) know how well this steers to solution.
"Today's the best day of my life...and NOW you're part of it!"
Mar 28, 2009 | Maxtor Hard Drive
Need to make maxtor drive a slave
Hi There, See the below link.Notice the picture of where the slave wording is located. That is where the jumper should be placed. Thanks, Mike
Nov 04, 2008 | Maxtor Hard Drive
Old maxtor harddrive
Most Maxtor Drives have jumper setting so that if "Jumper 50" is set; the two pins farthest from the power jack, is Master Drive. No pin jumper set, Slave or Cable Select. I hope this helps.
Aug 30, 2008 | Quantum Fireball Plus AS (QMP20000AS-A)...
Maxtor 500 gig internal diamondmax 21
external USB hard drives do not need to be jumpered, if your computer does not recognize the ext. drive probably it is because the enclosure is defective, when you connect the USB cable you should get the "ding-dong" connection sound.
If you think that your computer recognizes the hard drive then jumper it as "secondary" or "cable select" and install it INTERNALLY, then transfer your data, that will prove that there's a problem with the ext. enclosure.
One more thing, maybe the USB port you use is malfunctioning, try one that you know that works (assuming that you have other USB devices that work).
May 04, 2008 | Maxtor Hard Drive
Maxtor Hard Drive Logo
2,675 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
