Question about Samsung CLX-2160N All-In-One Printer
How to fix transfer belt error for samsung printer CLX-2160
  • 903 Answers
Did you try turning the machine off, unplugging it, then plugging it back in and turning it on? Usually this procedure will cause the error message to go away.
If the error does not clear, you'll need to call a service technician.
Posted on Nov 27, 2010
4 Suggested Answers
picipolman
  • 9 Answers
SOURCE: replacement transfer belt on my Samsung CLX-2160 not recognised?
enter tech mode by pressing menu>idcopy>left>right>menu>back>menu ,then in data setup clear all memory and clear count
Posted on Jul 28, 2010
  • 903 Answers
SOURCE: transfer belt error samsung CLX-2160 help
The first thing to try is to turn the printer off, unplug it from the wall, then plug it back in and turn it on. If the error message goes away, you can resume normal operation. If the error message still appears, you'll have to call your service technician.
  • 1116 Answers
SOURCE: samsung clx-2160 printer is showing
transfer belt (and other consumables) will reset follow this procedure:
1. go in diagnose mode:
menu - # - 1934 - menu
2. in tech mode -consumables counter - transfer belt -reset
3. after 20 sec. power off and power on
When transfer belt count 60.000 image need to reset.
good lock!
Posted on May 28, 2011
Printer toner black reset firmware for samsung clx-2160/see
It seems that there are no Samsung CLX-2160 firmware reset/fix, if i'll find something i'll keep you posted
Jan 27, 2012 | Samsung Office Equipment & Supplies
Samsung clx-2160 printer is showing transfer belt error. how do i sort this
good lock!
May 28, 2011 | Samsung CLX-2160N All-In-One Printer
Belt Error, clx 2160
Your printer has a "IMAGE TRANSFER BELT". This belt has a marker on his surface. This error means that the image belt does not move, or is damaged. Probably you will have to replace the belt with new one( This part is made for 20000pages).
pifonski
Feb 19, 2011 | Samsung CLX-2160N All-In-One Printer
I have a Samsung CLX-2160 print. It says "transfer
Try this steps it might help,
1. detach the paper tray and push it back correctly.
2. open the front door and remove toner cartridges, on left inner side u may see a light sensor which detects the toner cartridges.. simply clean this section by a small cotton bud. and in the left side of toner unit there is a sensor door, behind that door there is also a light sensor bulb, which needs to be cleaned by a cotton bud.
Please rate this solution if found useful.
Thanks
Jan 17, 2011 | Samsung CLX-2160N All-In-One Printer
I need to reset the transfer belt counter Samsung ClX -2160
Mar 09, 2010 | Samsung CLX2160 Multifunction Color Laser...
Transfer belt error samsung CLX-2160 help
Feb 09, 2010 | Samsung CLX 3160fn All-In-One Printer
Replacement transfer belt on my Samsung CLX-2160 not recognised?
Dec 12, 2009 | Samsung CLX2160 Multifunction Color Laser...
I have a clx 2160 printer and it has come up with message "replace transfer belt" can anyone advise what this is and best place to get one and can i do it myself
Check at www.precisionroller.com they have many of these parts for Samsung. Once you get the new one you replace it by first removing the toners and drum, the transfer belt is next to remove from the front.
Nov 12, 2009 | Samsung CLX2160 Multifunction Color Laser...
Re Samsung CLX-3160FN & Transfer Belt Error
Take out the Imaging unit ,transfer belt and fix it properly.
Also take care that you will keep the printer on even surface.
IF nothing is solving the problem then you need to replace the transfer belt as a final solution.
Jun 18, 2009 | Samsung CLX 3160fn All-In-One Printer
Samsung CLX-2160N All-In-One Printer Logo
2,315 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
