Question about Panasonic Viera TH-50PX80U Plasma TV
I have a Plasma Panasonic TC-P42UIX chasis GPF12DU. No power\r\nonly flashing 5 times acording with service manual problem is board (A) Short in the 5 volts. There is a short in board (A). I am an electronic technician. Question beside replace this board. Is there a solution for this problem any help will be apreciated. Yes I have the manual
  • 267 Answers
SOURCE: panasonic yh42pa20 shut down issue
there are a number of parts that may cause your problem power supply, z or y sustain boards, drive boards or panel. needs a qualified servicer to check out.
Posted on Jan 24, 2009
djchillsnyc
  • 151 Answers
SOURCE: panasonic viera tv won't turn on. Power light
hello, you have a either your su, sd or sc boards fualty and it is a driver sos1 thats what the manual reads the best thing to do if your not electronically inclined or able to fix it is to get a service manual and make sure it is for your specific model and size you will find what the 7 blink codes mean, on my side i have a 42 in pana the service manual for this set and your is similar so since it is not the same model i cant tell you exactly what the truoble is but your best bet is to find a service manual find the 7 blink fualt then without getting ripped off you will know what the service man needs to do if you dont know or cant replace the parts yourself that is besides having to download firmware from your computer to a sd card and update your set but you need to solve the blinking code first it may solve the entire issue. the tv should come on when you resolve the blink codes or replace the fualty board or boards
Posted on Oct 14, 2009
phil_frye
  • 295 Answers
SOURCE: Panasonic plasma 50PZ85 power led blink 10 times
Either a bad power supply or a bad processor board.
A Good Service Shop should know what the 10 blinks are indicating.
May be a repair cost between $200 and 400 dollars.
Be prepared -
Blessings,
A/V Media Guy
Posted on Nov 22, 2009
  • 8457 Answers
SOURCE: i have a plasma panasonic viera TH-42PV60A stand
Not power supply,it the backlight video board it dead.
Posted on Nov 23, 2009
Testimonial: "cool thanks alot"
SOURCE: red light flashes 10 times - Panasonic TH-42PX6U
I bought this tv in August of 2008. First episode occurred in October of 2009 - after manufacturer warranty had expired. It returned back to normal. Second episode occurred in March of 2010 and never got the unit to power up.
I had an electronic service center check it out. Turns out it's a defective power unit that's misfiring. The misfire triggers the overheat error code.
Panasonic retailer wanted $575 for parts and labor.
Service center executed finely and strapped on a 6 month warranty for $375.
I will be faxing a copy of the invoice and original receipt for a reimbursement.
Posted on Apr 02, 2010
Panasonic 2011 42" plasma Tc-p42st30, 14 blink code. I've checked the non-grounded pins at the connectors on the A, P and S boards as not short to ground. Fuses on the P-board are good. See below..
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Feb 16, 2017 | Panasonic TX-P42ST30B 42" 3D Plasma TV...
Panasonic tc-p50 two clicks but no no power
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Nov 23, 2015 | Panasonic TC-P50S60 50" Plasma HDTV
Panasonic plasma tv TC-TC-p42gt25. The power will
Contact any service technician or the authorized service centre for Panasonic. http://electronicshelponline.blogspot.com/
Oct 13, 2014 | Televison & Video
Panasonic TC-P54Z1 flashing image
Please remove all HDMI cables from the TV and test a different power outlet. If the problem persists then we recommend you use the below link to locate an authorized service center.
www.panasonic.com/repair Welcome to Panasonic Online Repair
Apr 21, 2014 | Panasonic VIERA TC-P54Z1 54 in. Plasma TV
Panasonic TC-P42S30 plasma power light on black screen no sound?
Main digital board should be troubleshooted. If you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electrical shock! Instead, contact any experienced service technician, or the nearest service center
Mar 09, 2013 | Panasonic Viera Tc-p42s30 42" Plasma Tv -...
TC-P50GT25 won't turn on
10 blinks check sc board for a short circuit in the mosfet ,replaces SC board
Mar 27, 2012 | Panasonic Viera TH-42PZ80U Plasma TV
TH-42PZ80U Panasonic Plasma, red light flashes 10 times
Panasonic said "A" board,
A board SOS Detect (Explanation)
10 Blinks SOS: The voltage regulators IC5400 and IC5401 in the A board generate SUB9V and SUB5V. The 9V and 5V from these ICs are monitored by IC1100. Any abnormality on the SUB9V or SUB5V lines, triggers the shutdown circuit and the MPU shuts down the unit. The power LED blinks 10 times.
But need to measure the connection SC2, if it short, it will be the SC board.
The knowledge obtain from: Real case of repair by myself.
Information from Panasonic training manual.
Apr 27, 2010 | Panasonic Viera TH-42PX80U Plasma TV
Panasonic Viera TH-50PX80U Plasma TV Logo
80 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
