Question about Sub-Zero 650 / O Bottom Freezer Refrigerator
I need to clean the compressor and I have the panel taken off but not sure what to do from there
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 56 Answers
You need to clean the condenser. Looking from the right to left you will see the condenser that closely resembles a radiator. Vacuum this using the brush attachment for your vacuum. Use an up and down motion being careful not to bend the fins by going left and right. Once this is done use a light to look through the condenser to ensure it is clean. To do this you may have to remove the two number two phillips head screws that hold the cover panel up. Looking at the back of the condenser fan motor light should pass through and you should see no build up inside. If you do you need to blow that out with compressed air. I use a compressor or nitrogen.
Posted on Sep 21, 2010
After cleaning frige and plugging it back up it blows air but not getting cold I can here what I think is the thermastat clicking on and off
You are most likely hearing the compressor overload device tripping and resetting as the compressor is probably not starting. remove the rear lower panel of the unit and verify your possible buzz/click is coming from the compressor. If this is the case you can replace the starting and overload device to see if this fixes the issue, if not your compressor may be in need of replacement. Pleazer Appliance...
Apr 18, 2014 | Amana Refrigerators
Refrigerator and Freezer not cooling
Wayne, lower back panel, the fan in back (condensor) should be running with the compressor. If the compressor is running,( you should be able to hear it) and the condensor fan is not running. Then the condensor fan motor is your problem. Another sign of a failed condensor fan motor is that the divider between the freezer and refer is extremely warm to touch. If the compressor is not running, it could be the compressor relay and overload (PTC) might be shorted. They made a bunch of these, white in color that failed quite often. Check yours out, it will be mounted to the front of the compressor. Take it off and shake it. If it rattles, there's your problem...Catriver.
Jun 11, 2007 | KitchenAid Superba Architect KSCS25INSS...
My Frigidaire Freezer is not getting cold and the fridge is higher temp then normal.
I read your problem and a lot of times when it is running but not cooling it can be as simple as just cleaning the coil. Take off the bottom back panel. (make sure you unplug fridge) and once you get the panel off, look in there if you see the hoses/coils dirty, they need to be cleaned and use a shop vac to really clean it and sometimes I will use a can of that compressed air that people use for computers. ANYWAY, if it is at all dirty, it needs to have a good cleaning. IF your compressor motor is real hot, then it has overloaded. In other words, its working to hard because of the dirt build up. A lot of people say, hey my compressor is running, but its not getting cold. Most the time it is running, but not at full capacity because it is dirty the coils and vents etc... Now, you have to let the fridge compressor cool down completely after you have cleaned it real good, then plug back in fridge and keep an eye on temp to see if it gets cold like normal. IF not, then what needs to be checked or replaced is the starter relay and most likely the capacitor. that is the switches the plug right into the compressor. You trace the wires that go to the compressor, and you will notice it hooks into a couple parts that plug into the compressor, that is your starter relay and capacitor. This can be replaced yourself. But first lets try the good cleaning method. AS a note: even though the compressor is running and if it is cleaned and still does not cool, the starter relay and compressor could have gone out, and those parts are designed to kick start the compressor at higher amps to have compressor operate at full capacity. I hope this helps you. Mike from fixya.
Oct 24, 2011 | Refrigerators
Dometic rooftop a/c compressor will not shut off. The only way to stop the compressor is to shut it off at the breaker. The fan and all other funtions operate properly from the thermostat. I tried...
E1-Automatic filter clean reminder.
Turn the air conditioner OFF and unplug it. NOTE: The air conditioner must be unplugged for the automatic filter clean timer to reset.
Clean the filter. See the Care and Cleaning section in your use&care manual. After cleaning, replace the filter and plug the air conditioner back in.
Oct 03, 2011 | Dometic 57915531 Air Conditioner
Flame on infrared wall heater ceramic burners burns blue on the surface and the burners no longer turn red or only partially turn red. I have taken the gas lines loose from the bottom of the burners and...
Check the gas line pressure before the heater then after the regulator. It sounds as if you are not getting sufficient gas pressure to the burners. Two possibilities bad regulator and or bad gas valve! Sorry I can not be absolutely sure on this one you can try blowing the ceramic burners with a compressor this will clean them rite out.
Dec 13, 2010 | Desa International GWP20T GLOWARM Wall...
Two imperial isf40 fryers taken apart and cleaned, inside did get wet. Now trying to light them both and neither will light and no gas getting to pilot light but gas is for sure working up to the unit.
Disassemble the pilot light tube and blow out with clean compressed air from a compressor.
This should get rid of any residual water in there that is blocking the pilot light.
Also, check the thermocouple if so equipped to make sure its tip is in the flame once the pilot light tube is cleaned out.
Good luck on this repair.
Oct 28, 2010 | Imperial IFS40 Deep Fryer
Out kenmore side by size freezer 10 years old with never any problems, notice the freezer isn't very cold and stuff is softening. Help!
First, check to make certain the compressor (underneath the refrigerator) is running. Second, make sure the compressor fan (near the compressor) is running. Third, make sure the evaporator fan (inside the freezer, likely behind an access panel) is running.
In checking on the compressor and compressor fan, look at the refrigerant coils. If they are dirty, they need to be cleaned.
Oct 18, 2009 | Refrigerators
The panel between the freezer and refrigerator heats up - too hot to touch for a while then cools off again. GD5SHAXLT01
You need to clean the coils under the front of the refrig of dust , lint , pet hair , etc . Pull the refrig out and remove the back panel covering the compressor . Make sure the fan there , next to the compressor is working . Usually , if this fan is not working , the center strip gets very hot , and the compressor may cut off , from getting too hot . The compressor can burn out , if the fan doesn't work for a while .
Sep 13, 2009 | Whirlpool ES5FHAXS Side by Side...
Our refigerator works on and off. Cools fine for a few days and then compressor stops. Wait 24 hours or so and then it works again.
Look under it for the cond fan to not be turning, find the condencer fan pulg it up and see if it comes on. If not she is bad and needs to be fixed, untill you can find a fan to fit. get a small fan from the store and aim it at the coil, clean the coil good so air can flow.
Sep 10, 2009 | Refrigerators
I have some severe free flow goin on, on my hpbcs iwata eclipse
It sounds like you have a problem with the air valve. Possible deterioration of the valve material? I am not sure what they use, but if it is a rubber the cleaning thinner MAY have destroyed its properties if the cleaner got into the air path and valve.
Aug 12, 2009 | IWATA -CS Eclipse AIRBRUSH w/COMPRESSOR...
Sub-Zero 650 / O Bottom Freezer Refrigerator Logo
74 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
ACME Sub Zero...
ACME Sub Zero...
Sal DeAngelo
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
