Question about Nokia 3110 Cellular Phone
I have a problem of connecting my nokia 3110classic of bsnl packet data connection. i also need your advice that how to connect that phone's internet with personal computer through data cable.bye!
    Guru:
  • 317 Answers
First you require pc suite
then data cable connect your mobile on nokia pc suite mode and
in nokia pc suite select connect to internet then if there is access point then enter apn name in setting section etc.
try this link this is for bpl but you can change as per your requirement for apn is deifferent.
http://www.tech2info.com/2009/08/use-internet-on-pc-using-bpl-mobile.html
Posted on Sep 17, 2010
I've a Nokia E63 mobile set with a BSNL connection.. Whenever I try connecting to the internet it shows a message "Packet Data:Packet Data connection not available" & I'm not being...
1 checked first the you have installed nokia pc suit and proper driver installed or not. 2 checked that you have done proper network setting in pc suit. 3 checked that you have sufficient balance in your mobile for connect internet. if you dont have balance in your mobile. then first recharge your mobile
Aug 20, 2011 | Computers & Internet
Nokia 2700 classic :problem subscribe packet data first-my connection is bsnl
This shows that you don't have the GPRS and MMS settings received on your phone.They are to be received from your Network Service Provider.Since you are using BSNL Network please do the following steps to receive the packet data settings on your phone.
Call 9400024365
OR
sms GPRS to 53733 to activate your GPRS service.Thanks for choosing Fixya.
Jun 21, 2011 | Nokia 5310 Cellular Phone
How can i subscribed to packet data?
Packet data (EGPRS) Enhanced general packet radio service (EGPRS), packet data, is a network service ceive data over an Internet protocol which allows mobile phones to send and re (IP)-based network. It enables wireless access to data networks such as the Internet.77 . 2005 Nokia. All rights reserved © Copyright The applications that may use packet data are MMS, browsing sessions, Push to talk, e-mail, remote SyncML, Java application downloading, and the PC dial-up. Packet > Connectivity > Settings > Menu To define how to use the service, select Packet data connection > data . to set the packet data connection to be established when an When needed Select application needs it. The connection will be closed when the application is terminated. to set the phone to automatically connect to an packet data Always online Select network when it is switched on. indicates a packet data connection. Modem settings You can connect the phone using an IR or a data cable connection to a compatible PC, and use the phone as a modem to enable packet data connectivity from the PC. > Settings > Menu To define the settings for connections from the PC, select , activate Active access point > Packet data settings > Packet data > Connectivity Alias . Select Edit active access point the access point you want to use, and select , and enter a nick name for the currently selected access point. for access point , and enter the access point name (APN) to Packet data access point Select establish a connection to an EGPRS network. You can also set the dial-up service settings (access point name) on your PC using If you have set the 121 p. PC Suite the Nokia Modem Options software. See . settings both on the PC and on your phone, the PC settings are used.
Apr 14, 2011 | Nokia 6020 Cellular Phone
Iam not able to install bsnl3gmobiletv on my samsungGT-S5603.I live in barmer(rajasthan).Thereis 3g service avaliable here
You musy define three access points.
1. bsnlnet : a) Connection name - bsnlnet b) data bearer - packet data c) APN - bsnlnet d) Authentication - Normal e) Home page - www.bsnl.co.in
2. Bsnl Live - a) Connection name - Bsnllive b) data bearer - packet data c) APN - bsnllive d) Authentication - Normal e) Home Page - www.bsnllive.com
3. Bsnlstream - a) Connection name - Bsnlstream b) data bearer - packet data c) APN - bsnlstream d) Authentication - Normal e) Home page - www.bsnl.co.in
One more to be defined is Packet data Connection - When needed Access Point - bsnlnet
Mar 15, 2010 | Cell Phones
How can i sign in ptt option?
PTT or push to talk application and availability is depend on your network operator. Try to contact your operator and ask if they support PTT..
Mar 05, 2010 | Nokia N95 Cellular Phone
BSNL GPRS - packet data connecttion not available
You can set your gprs setting manually go to access point and set gprs gprsnorth.cellone.in
Feb 03, 2010 | Nokia 5310 Cellular Phone
I need gprs settings of bsnl for nokia 3110c. my
Go to Menu
choose settings
choose connectivity
go to packet data
go to packet data connection
choose - when needed
go to packet data settings
go to Active access point
type "bsnlgprs"
go to Edit active access point
go to Alias for active point
type "bsnlgprs"
go to packet data access point
type "wapsouth.cellone.in" (Other regions replace south with their region)
now come back to settings
go to configuration
go to preferred access point
type "BSNL Internet"
now go to Menu and Choose Web
You will find Personal Configuration in 'Configuration"
and 'bsnlgprs' in Account
Wherever you find Proxy Server, Enable it
Wherever you find Proxy port No: type 9401
Connection is 'IPv4"
now go to Personal ConfigurationSettings and in options click Activicate. Now Enjoy OPERA MINI
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
Sep 21, 2009 | Handmark Software MobileLists (950142) for...
I need gprs settings of bsnl for nokia 3110c. my no is 9455899951
Customer care at BSNL are so dumb to provide the correct settings for Nokia 3110C. Below are the manual steps to configure your phone for BSNL GPRS:
Go to Menu
choose settings
choose connectivity
go to packet data
type "bsnlgprs"
type "bsnlgprs"
go to configuration
Regards
Anand
Mar 26, 2009 | Handmark Software MobileLists (950142) for...
Nokia 3110 Cellular Phone Logo
108 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
