Question about Hotpoint Ariston Aquarius WD420 Front Load All-in-One Washer/Dryer
Were is the filter on my hotpoint aquarius WF240 washing machine thanks..
barkencoa
  • 3463 Answers
SOURCE: does machine have a filter
The filter is to be found at the rear of the washer.
Remove lower rear panel of washer, remove large black hose fastened to bottom of tub.
Watch out for water running out.
Remove plastic`filter inside hose and clean.
Refit filter and hose.
Dirty washing can somtimes be attributed to washing at too low a temperature, so make sure you have selected right temp for washing.
Please leave a fixya rating for my solution.Thanks.
Posted on Feb 08, 2009
jsrock516
  • 5911 Answers
SOURCE: hotpoint aquarius extra wma46
The first question you need to ask yourself is, "is the drain pump running?" If you can hear the drain pump running when it tries to drain, then more than likely you have a clogged drain pump, or drain line. Here's how you can determine which one: You can check the drain line by seeing if it collapses when the pump starts to run. If it does, then you know you have a clogged line somewhere BEFORE the pump. This usually means an article of clothing has gotten between the wash basket and outer tub and is stuck in the line. If the line is full of water and doesn't seem to be going anywhere, hook up a wet/dry shop vac to the drain hose in the rear of the machine to see if you can pull water from the tub, through lines, and through the pump. If you can't, you know you probably have a clogged pump, or drain line AFTER the pump. If the drain pump does not come on, you may have a pump failure. In either case, you need to drain the water from the tub. A wet/dry shop vac does a great job at pulling water from the tub, so you don't have to bail. Let me know if this helps.
Posted on Jul 22, 2007
barkencoa
  • 3463 Answers
SOURCE: i cant find the filter on the hotpoint aquarius wd440
Depending on which model you have ,there are 2 possible locations for the filter.
Check to see if there is a removable plastic panel at the botom front of washer, if there is then remove it and if there is a filter there , you will see it, unscrew the cover anti clockwise and clean same.
If no filter there then remove lower rear panel of washer,locate large black hose, and remove clip and hose from bottom of tub,be careful as there will be some water run out.
Remove plastic filter and ball ,clean and replace, and refit hose, making sure it is secured properly.
Test for leaks.
Plz rate my solution.
Thanks.
Posted on Jan 15, 2009
barkencoa
  • 3463 Answers
SOURCE: Noisy spin on hotpoint aquarius WF530 6kg washing machine. Suspect bearing how do I replace them.
If you spin the drum by hand, and it is niosy and rumbling then the main drum bearings have failed.
If under 5 years old, then you should be able to get it repaired under Hotpoint 5 year guarantee, You just pay for labour and call out, cheapest option, it is not really a D.I.Y job, as it is quite involved, and entails a lot of work.
Please rate my advice.
Thanks.
Posted on May 27, 2009
barkencoa
  • 3463 Answers
SOURCE: am trying to replace the belt on a hotpoint aquarius wf240 washing machine. I have removed the 2 bolts which appear to hold the motor in place ( 1 bolt on each side). However the motor still will not
Hi. The motor is non adjustable on this washer. Tilt washer forward, get someone to hold it steady, and put belt round motor pulley first, then slip belt on drum pulley, and slowly turn drum by hand, feeding the belt on as you turn drum, be careful not to trap fingers, as it is very tight, this is normal, as the belt is a stretch type, this is the reason the motor is non adjustable. Please rate my advice. Thanks.
Posted on Jun 03, 2009
Where is the filter on the on the Hotpoint Aquarius washing machine
The filter is inside the machine accessed from the back, see /www.youtube.com/watch?v=R__JTUX9nk4 . Hope this helps
Jun 19, 2016 | Hotpoint Washing Machines
Hotpoint wf240 has stopped working, sounds like the motor or brushes. Problem is there is washing in the tub and we cannot get the door open.Please advise how to open the door ?
Return the program dial to a finished position. Power the machine off (Unplug it). Leave it 20 minutes and it SHOULD reset. Note, if there is water above the level of the door, it is a good idea to pull the machine out and tip it back slightly until the water is not against the door, then you can remove clothes and bail the tub out
Jun 21, 2011 | Hotpoint Aquarius WF000 Front Load Washer
How to fit a belt on a Aquarius WF240 washing machine
Remove the lower rear panel of the washer and the top cover also.
Tilt the washer forward, and from the top fit the belt round the motor pulley first, and slowly feed it round the drum pulley, turning the drum pulley at the same time.
Watch your fingers as the belt will be very tight and difficult to get round the pulley.
but this is the best way to do it, trust me on this.
If it comes off, just start again., once you have the belt on, you can then easily align it up properly on the 2 pulleys.
Feb 19, 2011 | Hotpoint Aquarius WF220 Front Load Washer
Hotpoint
Check level of machine as may be leaning slightly forward. Use front feet to adjust to level or slightly lifted at the front. This will compensate for any slight buckle in the plastics on the drawer compartment.
Feb 07, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Am trying to replace the belt on a hotpoint aquarius wf240 washing machine. I have removed the 2 bolts which appear to hold the motor in place ( 1 bolt on each side). However the motor still will not
May 30, 2009 | Hotpoint Aquarius WF220 Front Load Washer
Wont emtry
can you hear the motor spinning.
May 12, 2009 | Hotpoint Aquarius WF220 Front Load Washer
Error code on my Hotpoint Aquarius WF240
my hotpoint Aquarius wf340 when switch on 5 secs later on/off button flashing along with mini load lights. could u tell me the error codes for this machine?
Apr 04, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
The drum bangs on the spin
Two possibles for this are aloose balance block or cracked drum spider.The front block is most prone to coming loose.
To check spider rotate drum little by little and pull towards you to check for movement.
Post back if further help needed.
Thankyou
Dec 19, 2008 | Hotpoint Aquarius WF220 Front Load Washer
Hi there please my problem
Make sure the rinse hold button has not been selected, deselect if it is, possible pump blockage
There is a filter located in the sump hose at the rear of the m/c.
Remove lower rear panel and undo large hose onto drum , filter inside there, remove and clean if neccessary.
Make sure nothing is stuck inside pump, try a drain only prog and you should be able tohear and see if oump is working BE CAREFUL.
Dec 11, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint Ariston Aquarius WD420 Front Load All-in-One Washer/Dryer Logo
349 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
