Question about Samsung MC5694 Microwave Oven
My samsung micro wave oven model no. M183DN unable to start no display nothing is displayed
3 Suggested Answers
MicrowaveSvc
  • 9098 Answers
SOURCE: samsung MR6699GB
This model was one of many subject to a recall due to defective membrane keypads.
Details of the recall are here: http://www.allworldauto.com/recalls/NHTSA_03E044000__SAMSUNG_MICROWAVE_MR6699GB_recall_55168.html
Long story short, please unplug it and contact Samsung with you model and serial number at 800-932-3837.
If your serial number was not one subject to a recall, E2 usually means a temperature sensor problem but it may also mean you have a bad door switch.
If it's not in the recall, please post back and I can give you info on checking the other parts.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Feb 17, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: built-in microwave: display works but oven does not.
You didn't mention your model number. If I knew that, I could check to see if it's one of the models subject to a recall for failed membrane keypads.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
Posted on May 04, 2010
How to set the clock on ge space maker micro wave
http://products.geappliances.com/appliance/gea-support-search-content?contentId=17872
Quoted from link above:
To set the clock on most GE microwaves:
  1. With the microwave door closed, press CLOCK.
  2. Touch number pads that reflect the time of day (1:45 would be 1, 4, 5).
  3. On some newer models, indicate AM or PM for morning or evening.
  4. Press CLOCK or START to lock in the time.
If you prefer not to display the time:
Disconnect the power for 30 seconds. After restoring power, do not set the clock. If your model has an ON/OFF clock display, you can choose not to have the time displayed. To choose this option, press the 0 pad for about three seconds. To Turn the display back on, press the 0 again.
Mar 21, 2018 | GE Microwave Ovens
Micro wave went dark on display screen, but outlet has power; where is the fuse
The fuse is located inside. The outside cover has to be removed to gain access.
Sep 16, 2014 | Frigidaire Microwave Ovens
My micro wave reads that it is locked how do I unlock it. it is sears ultra wave
The "lock" function is nice if you have kids who like to push buttons. It disables the microwave oven to prevent it from running unnecessarily,
To disable the lock feature push the "STOP-CLEAR" button. Then press and hold the "START" button until 'locked' is no longer shown on the display panel.
To re-lock it, do the same thing until 'locked' appears on the display.
Have a nice day.
Oct 20, 2013 | Kenmore 63662 / 63664 / 63669 Microwave...
Try2910227 serial ywmh2205xvb-0 model arcing on the back corner were the rack sits.Is there a way to repair this seen is the unit was purchaced in June of 2011.
Yes, take the rack out and recycle it. I do not know why these micro-wave company put racks in the micro wave ovens. You get some insulation on the inside the micro flaking off next the rack.
The mega-tron tube is a very high energy transmitter. The energy will come out of the top inside the micro wave oven in a wave guide. Micro wave energy that generation by the tube is high frequency into Gega Hertz. You have a metal tray in side the micro wave acts like a big capacitor it stores energy in form of heat the next you know it look like Marconi is putting on a lighting display.
Leave the wire tie on a loft of bread and put in you micro wave oven to defrost. The next thing you might see is a load bread burning, instant toast. ----The use of micro wave were invented by the British before WWII. The mega tron tube generation very high frequency radio wave and these wave struck an object 100 miles away some of this beam energy would balance back to a receiver-----You have Radar.... I wish you and your family well being and be careful of micro wave ovens it can burn from inside out. GB you...stewbison
Aug 22, 2011 | Microwave Ovens
After closing door micro wave turn table continues to turn and light stays on after you open door and take out food.
The problem is most likely caused by a defective door switch, and should be rectified for safety reasons.
Apr 05, 2011 | Whirlpool WMH1162XVS Microwave Oven
Boiling waer under micro wave lots of steam into micro wave, turn on micro wave ,pop noise like glass miro wave comes on louder hum than normal no heat
Q - The microwave display counts down and the inside light is on,  but nothing is heating and the fan is not running.
A - This most commonly is a bad door switch, other possible problems are a faulty relay or solder joint on the power module, but a bad door switch is most common.
 Q - My microwave is running and sounds like it is working but will not heat up anything.
A - Many thing can do this but, common things are....loose high voltage wire.....poor solder joint on board.....magnetron.....power relay.....
Q - The microwave makes a loud "hum or buzz" noise but will not heat up the food?
A - 9 times out of 10 this is usually this is a bad magnetron, the other time is sometimes a bad high voltage diode. See components section.
Mar 03, 2009 | Amana Radarange Microwave Oven
Samsung MR6699GB
Feb 13, 2008 | Samsung SMH7174BC Microwave Oven
KitchenAid KHMS155L 1000 Watts
According to the owner's manual for model KHMS155L:
To Lock/Unlock Control: The microwave oven and Timer must
be off. Touch and hold START for 5 seconds until 2 tones sound and a lock icon appears on the display. Repeat to unlock and remove the lock icon from display.
You can download the manual here:
http://www.kitchenaid.com/custserv/service.jsp
Jan 16, 2008 | KitchenAid KHMS155L Microwave Oven
Samsung MC5694 Microwave Oven Logo
57 people viewed this question
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Oscar Netto
Oscar Netto
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
