Question about Northwestern Bell 23110 Corded Phone (nwb-23110)
How to set up memory numbers - Northwestern Bell 23110 Corded Phone (nwb-23110)
How do I delete a speed dial number
Lift the head set. Press PROG button twice. Then press MEMORY then the speed dial number. Hang up. Done. Or..Lift the head set, press PROG, enter a phone number you'd like to set to speed dial, press PROG, MEMORY, the speed dial number (1,2,3,4 etc), then hang up..
Jun 19, 2011 | Clarity Ameriphone JV35
Pin code number
You can set the pincode number yourself. Please follow the instruction that came with the memory card. If you have forgotten, then format the card. Then you will get option to set pin/passcode for it.
Jan 11, 2011 | SanDisk 2GB microSD Memory Card
A incorrect fax number got loaded into the memory by mistake. How do I delete it. It is a Pixma MX320 model
If you mean the fax number for your fax machine, you should be able to press the Fax button on the printer and then press the menu button, then go to settings. You should be able to change the original set-up information, including the fax number and other identifying features for your faxes.
If you mean for memory for other fax numbers, you should be able to to to the directory in the settings and edit or delete the memory settings much the same.
Sep 23, 2010 | Canon PIXMA MX310 All-In-One Printer
When reciving text messages the phone number shows up instead of contact name
this may happn in two cases:
1) when contact is not saved in memory
2) contact is saved twice means
contace saved in phone memory as well as sim memory
so delete contact from both and sav that in any one memory either in sim memory or in phone memry :D
Mar 06, 2010 | Samsung Finesse SCHr810 Cell Phone
I need to know how to program the numbers into the speed dial option. My mother's phone is a table set with large numbers #29267A ... close enough?
Before you store a telephone number in memory, make sure the dialing mode is
correctly set for the type of service you have. The default dialing mode is tone
(touch-tone), so if you have pulse (rotary) service, you must first change the dialing
mode. See “To Set the Dial Mode.” The following buttons can be stored into any
memory location: 0-9.
STORING FREQUENTLY CALLED NUMBERS
1. Pick up the handset.
2.Press the store button.
3. Push the desired memory location button.
4. Press the store button.
5.Use the handset number keys to enter the telephone number (up to 16-digits)
and press the store button.
6.Hang up the handset.
NOTE: If you make a mistake, use the delete button to delete wrong digits.
CHANGING A STORED NUMBER
Repeat the storage sequence above. The new number replaces the old number at
the memory location.
ERASING A STORED NUMBER
3.Press the memory location (0-9) to be erased.
4.Press delete for three seconds until the number in the display is erased.
5.Hang up the handset.
DIALING FREQUENTLY CALLED NUMBERS
1. Pick up the handset and press the mem button.
2. Press 0-9 for the memory location. The number dials automatically.
OR
1. Pick up the handset and press the dial button.
2. Press the review button for the desired memory location.
3. Press the dial button to dial the number.
OR
1. Press dial button while the handset is still in the cradle.
2. Press the review button for the desired memory location, lift the handset and the
Download User Manual
If this information was helpful, please give me a big thumbs-up when you rate my answer. Thank you.
Feb 02, 2010 | GE 29267GE3 Corded Phone
I want to find out how to set up our Canon CFX0-L4000 fax Machine
CANON CFX-L4000 UNOFFICIAL MANUAL
RIGHT KEYPAD
FUNCTION
SET
01 DATA REGISTRATION
02 DELAYED TRANSMISSION
03 POLLING
04 MEMORY REFERENCE
09 REPORT
11 UP
13 +
14 LEFT
15 SPACE
16 RIGHT
18 CLEAR
19 DOWN
Keys 1-20 are speed dial keys. If speed dial is not set, message is displayed and manually entering the telephone number is prompted. Press STOP to clear.
Pressing FUNCTION accesses the menus associated with keys 1, 2, 3, and 4. After accessing a menu, the cursor keys, SET, and occasionally the telephone key pad are used for selecting options and setting values.
EG. Setting a speed dial number:
FUNCTION - DATA (01) - SET - SET - UP/DOWN to select speed dial number - SET - UP/DOWN to set number/name - SET - UP/DOWN/LEFT/RIGHT/PHONE KEYPAD to enter value - SET
EG. Setting unit telephone number
FUNCTION - DATA (01) - DOWN once - SET - DOWN once - SET - PHONE KEYPAD to enter number - SET
EG. Retransmit from memory (assumes memory light is on)
FUNCTION - MEM (04) - DOWN once - SET - UP/DOWN to select document number (LEFT/RIGHT to view associated telephone number) - SET
EG. Delayed transmission
place document into feed - FUNCTION - TX (02) - SET - PHONE KEYPAD to enter time to send - SET - PHONE KEYPAD to enter phone number - SET - SET - document is scanned and will be transmitted at set time
for full guide you will have to search and purchase one.
May 28, 2009 | Canon Office Equipment & Supplies
How to set up Speed Dial on a Uniden phone?
My Mom had this same problem.   I found these instructions on Uniden's website (uniden.com) under the "Owner Manuel" section.
Here you go - good luck!
Using the Speed Dial Memory
Storing Numbers in Speed Dial Memory
Your cordless phone can store up to ten numbers (up to 20 digits each) in the speed dial
memory. To store number in memory:
1) When the phone is in standby, press [memory]. The talk/batt low LED flashes.
2) Use the keypad to enter the phone number.
 (To enter a 2-second pause between numbers, press [redial/
pause]. Each pause counts as a digit. )
3) Press [memory] again.
4) Select the speed dial location where you would like to store the
number ( [0] to [9] ). You will hear a confirmation tone indicating
that the number has been stored.
NOTE:
• Storing a number to a speed dial location will
overwrite the any previously stored number without
warning.
• When storing numbers into memory and the handset is idle (i.e., no key is
pressed) for more than 0 seconds, it will beep rapidly, and then the phone
will return to standby.
Dialing a Stored Number
1) When the phone is in standby, press [talk], and listen for a dial tone.
2) Press [memory] and enter the speed dial entry ([0] – [9]) that has the stored number
you want to dial. (If you enter a digit that does not contain a stored number, the
handset will beep rapidly, and the phone will not dial.)
Chain Dialing
The speed dial memory is not limited to phone numbers. You can store any number (up
to 20 digits) that you need to enter once your call connects. This is referred to as Chain
Dialing. An example is a frequently refilled prescription number. Store your pharmacy
phone number in one speed dial and your most frequently refilled prescription number
as another speed dial. To use, once you ring your pharmacy's automated prescription
line, simply press [memory] and the speed dial number where you stored your account
number.
Erasing a Stored Number from Memory
1) With the phone in standby, press [memory] twice.
2) Press the number of the speed dial entry. A tone indicates that the stored number is
erased from memory.
Jan 11, 2009 | Uniden Cordless Phone
Binaton big button combo telephone
Press Speakerphone button
Press Set/Store
Enter the telephone number
Press Set/Store
Enter the memory number (M1, M2, M3 or 1-9)
Press Speakerphone button to hang up.
To use the memory feature,
For M1, M2 or M3, just pick up the phone and hit that button.
For memory number's 1-9, pick up the phone, press auto button, then enter number 1-9 for who you want to call.
Apr 16, 2008 | Lands Phones
Nokia 6233, mobile asking security code to set "phone memory" for saving contacts.
It's a 5 digit number.
You should have a:
PIN,
SECURITY,
PUK, numbers
PIN locks your SIM card.
SECURITY locks your phone.
PUK unblock everything.
Dec 27, 2007 | Nokia 6233 Cellular Phone
Ge cordless model 26930 memory dial
hit memory, choose a number, hit memory, enter name, hit memory enter number, hit memory
Aug 11, 2007 | GE 26930GE1 Cordless Phone
Northwestern Bell 23110 Corded Phone (nwb-23110) Logo
22 people viewed this question
Top Northwestern Bell Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Northwestern Bell Lands Phone Expert? Answer questions, earn points and help others
