Question about Whirlpool Duet GHW9150P Front Load Washer
Controls locked, how do you unlock them - Whirlpool Duet GHW9150P Front Load Washer
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. To unlock the controls you'll need to press and hold the END OF CYCLE button for 10-15 seconds. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Sep 16, 2010
Where is located the door lock relay on 2009 saturn aura xe
Doesn't have relay , controlled by the BCM - body control module .Circuit/System Description
Each door lock switch is wired to the body control module (BCM) through a separate door lock/unlock signal circuit. While these circuits are separated between the BCM and respective door lock switch, they are connected into a single circuit within the BCM. The BCM supplies voltage through the door lock/unlock signal circuits to each door lock switch. When either door lock switch is operated, this supply voltage is pulled to ground, providing the BCM with the required lock or unlock signal. In order for the BCM to distinguish between a lock and unlock signal, the lock switch contains two separate paths for this voltage to flow to the same body ground. When the switch is operated to the unlock position, the supply voltage flows to ground through a 1.5K ohm resistor. When the switch is operated to the lock position, the supply voltage flows to ground through a different part of the switch circuit, which has no resistor. The BCM then interprets the flow of voltage as a lock or unlock request and powers the door lock actuators to the appropriate lock or unlock position.
The BCM powers the reversible door latch assemblies by providing battery positive voltage and ground to the appropriate lock and unlock control circuits of the door latch assemblies. The lock control circuits of the driver and passenger door latch assemblies are all connected together; however, the unlock control circuits are connected in a slightly different way. While the unlock control circuits for the passenger door latch assemblies are connected together, the door latch assembly has a separate unlock control circuit. The system is designed this way so that the keyless entry transmitter may be used to unlock only the driver door. Despite this difference, all lock actuators perform much the same way. When the door latch assemblies are not active, all actuator lock and unlock control circuits are at ground potential within the BCM. Transitioning of the lock actuators to the lock or unlocked position depends upon which control circuits receive voltage and which control circuits receive ground.
Your best bet , take it to a qualified repair shop .
Jan 20, 2018 | Saturn Cars & Trucks
Where are the fuses for the power dock locks on a 2006 montecarlo06ss
DR/LCK fuse 25 amp . located in the I/P block
Fuse Block - I/P
In the right front kick panel
Power Door Locks System Components
The power lock system consists of the following components:
• Body control module (BCM)
• Driver door lock cylinder switch
• Front passenger door lock cylinder switch
• Driver door lock switch
• Front passenger door lock switch
• Door lock actuators in each of the doors
• DR LK Fuse 20-amp
Door Lock System Controls
The Power Door Lock System is controlled by the body control module (BCM) and can be activated by any one of the following:
• A door lock switch lock or unlock actuation
• A door lock cylinder switch unlock actuation
• A keyless entry transmitter actuation
• An automatic door lock actuation (Personalization function)
• An automatic door unlock actuation (Personalization function)
Door Lock Operation
When the body control module (BCM) detects a transition of either of the door lock switches to the lock position, it switches the door lock actuator lock control circuit to voltage. Since the lock actuator unlock control circuits are at ground potential within the BCM, the door lock actuator motors transition to the lock position.
Driver Door Unlock Operation
When the body control module (BCM) detects a transition of either of the door lock switches to the unlock position, it switches the driver door lock actuator unlock control circuit to voltage. Since the door lock actuator lock control circuit is at ground potential within the BCM, the left front (LF) door lock actuator motor transitions to the Unlock position.
The driver door lock actuator unlock control circuit is a dedicated control circuit used only for the driver door lock actuator motor. This is done so that the driver door may be unlocked by itself using a keyless entry transmitter or an automatic door unlock function (if programmed).
Passenger Door Unlock Operation
When the body control module (BCM) detects a transition of either of the door lock switches to the unlock position, it switches the door lock actuator unlock control circuits to voltage. Since the door lock actuator lock control circuit is at ground potential within the BCM, the passenger door lock actuator motors transition to the unlock position.
The door lock actuator unlock control circuits are dedicated control circuits used only for the passenger door lock actuator motors. This is done so that the driver door may be unlocked separate from the passenger doors using a keyless entry transmitter or an automatic door unlock function (if programmed).
Mar 23, 2017 | 2006 Chevrolet Monte Carlo
2005 Buick Rendezvous you can hear the relay clicking but the door locks will not open and close
Check for broke wires inside the boot from body to driver door , this is a common problem . If you don't find broke wire's , pull the door panel to get at driver door switch . Check for voltage an ground circuit .
Rendezvous Door Lock System Components
The power door lock system consists of the following components:
Door lock system fuse into the BCM (BCM D 25A fuse)
Door Lock Operation
When the BCM detects a transition of either of the door lock switches to the LOCK position, it switches the door lock actuator lock control circuit to voltage. Since the lock actuator unlock control circuits are at ground potential within the BCM, the door lock actuator motors transition to the Lock position.
When the BCM detects a transition of either of the door lock switches to the UNLOCK position, it switches the driver door lock actuator unlock control circuit to voltage. Since the door lock actuator lock control circuit is at ground potential within the BCM, the LF door lock actuator motor transitions to the Unlock position.
When the BCM detects a transition of either of the door lock switches to the UNLOCK position, it switches the door lock actuator unlock control circuits to voltage. Since the door lock actuator lock control circuit is at ground potential within the BCM, the passenger door lock actuator motors transition to the Unlock position.
The door lock actuator unlock control circuits are dedicated control circuits used only for the passenger door lock actuator motors. This is done so that the driver door may be unlocked seperate from the passenger doors using a keyless entry transmitter or an automatic door unlock function (if programmed). This video on testing computer controlled door locks on a Subaru , doesn't matter . test yours same way > The BCM controls your door locks .
Are all of the power door locks inoperative from both door lock switches?
Oct 12, 2016 | 2005 Buick Rendezvous
Passenger door locks don't unlock.
You need to understand how they work , do you know about automotive electronic controls ? Your switches are just inputs to the BCM - body control module !
Door Locks Power and Ground
For door lock operation, the IP Fuse Block supplies battery positive voltage, through the 15 amp DR LK/TRUNK fuse, to the BCM. The BCM uses this circuit exclusively to apply power to the door lock actuators. The BCM is also supplied a ground circuit, which it uses exclusively to ground the door lock actuators. When a door lock is pulsed, the BCM internally connects these two circuits to the appropriate lock and unlock control circuits to actuate the locking or unlocking functions.
When diagnosing door lock malfunctions, these circuits must not be confused with the other battery voltage and ground circuits of the BCM. The appropriate wiring schematic must be used to locate the correct circuits. Failure to identify the correct battery voltage and ground circuits of the BCM during diagnosis of door lock concerns may result in misdiagnosis and unneccessary parts replacement.
When the BCM detects a transition of either of the door lock switches to the Unlock position, it switches the door lock actuator unlock control circuits to voltage. Since the door lock actuator lock control circuit is at ground potential within the BCM, the passenger door lock actuators transition to the Unlock position.
The door lock actuator unlock control circuits are dedicated control circuits used only for the passenger door lock actuators. This is done so that the driver door may be unlocked individually before unlocking the passenger doors using a keyless entry transmitter or an automatic door unlock function, if programmed. When the keyless entry transmitter is used to unlock the passenger doors, the BCM requires a repeated unlock command before it performs the unlock function. However, when the unlock input is from a door lock switch, a single unlock command is all that is required to unlock all doors.
How to test computer controlled door locks
Sep 12, 2015 | 2006 Pontiac Grand Prix
2005 Chevy Impala. The door locks keep locking during drive.
It's probably a bad input to the BCM - body control module ! Have it checked for DTC'S - diagnostic trouble codes .
The automatic door lock function can only be enabled by the body control module (BCM) if the driver door open switch and door ajar switches are in the Closed state. For information on programming the automatic door locks, refer to Vehicle Personalization in Personalization.
DTC B3064 or B3069
DTC B3127
DTC B3128, B3133, or B3138
DTC B3132
DTC B3137
DTC B3272
Your best bet , take it to the chevy dealer . Unless you own a GM factory Tech 2 scan tool an have access to factory sevice repair info.
The outputs to the door lock actuators are controlled by the body control module (BCM). When the BCM receives a lock input from a door lock switch, or a keyless entry transmitter, it applies battery positive voltage to the door lock actuator lock control circuit, a ground to the door lock actuator unlock control, and the driver door lock actuator unlock control circuits. When the BCM receives an unlock input from a door lock switch, it applies battery positive voltage to the door lock actuator unlock control, the driver door lock actuator unlock control circuits, and a ground to the door lock actuator lock control circuit . When the BCM receives an single Unlock input from a keyless entry transmitter, it applies battery positive voltage to the driver door lock actuator unlock control circuit and a ground to the door lock actuator lock control circuit to unlock the driver door. A second Unlock input from the transmitter applies battery positive voltage to the door lock actuator unlock control circuit, and a ground to the door lock actuator lock control circuit to unlock the passenger doors.
This diagnostic procedure supports the following DTCs:
• DTC B3128 Left Front/Driver Door Unlock Circuit High
• DTC B3133 All Door Unlock Circuit High
• DTC B3138 All Door Lock Circuit High
Jul 21, 2017 | Cars & Trucks
CONTROL LOCK GE GAS DRYER
  1. Press and hold for 3 seconds the "Control Lock/Unlock" button on the control panel to lock the control panel.
  2. Listen for a double beep and observe the "Control Lock" status light is lit when the control lock is in effect.
  3. Press and hold for 3 seconds the "Control Lock/Unlock" button on the control panel to unlock the control panel. The "Control Lock" status light is goes out when the control panel is unlocked.
Jan 31, 2015 | GE Dryers
I bought a honda civic sport 2005 got it resprayed and i built it up and now the alarm keeps going off the key fob doesnt work etheir the battery has been flat . does any body no how to reset the fob or...
Programming
When
Remote control added or replaced. System malfunction.
How
Obtain all remote controls. A maximum of 3 remote controls can be programmed. Switch ignition ON. Repeat procedure below 3 times: Within 4 seconds: Press lock or unlock button. Within 4 seconds: Switch ignition OFF. Within 4 seconds: Switch ignition ON. Within 4 seconds: Press lock or unlock button. System should now lock or unlock vehicle. Within 4 seconds: Press lock or unlock button. Within 10 seconds: Press lock or unlock button of first remote control. System should now lock or unlock vehicle. Press lock or unlock button of second remote control. System should now lock or unlock vehicle. Press lock or unlock button of third remote control. System should now lock or unlock vehicle. Switch ignition OFF. Remove key. Check operation of all programmed remote controls.
IMMOBILIZER CAN ONLY BE SET BY DIAGNOSTIC EQUIPMENT
May 13, 2011 | 2005 Honda Civic
The controls locked is displayed. what causes this and how do i get the controls unlocked.
Jan 11, 2011 | Whirlpool GEW9250 Electric Dryer
As to me to stitch the second key from ignition (with immobilizer) in memory of my car (Honda CRV-2,4 EX 2002, made in UK) if nearby is not present diller from Honda.
Programming
When
How
Obtain all remote controls. A maximum of 3 remote controls can be programmed. Switch ignition ON. Repeat procedure below 3 times: Within 4 seconds: Press lock or unlock button. Within 4 seconds: Switch ignition OFF. Within 4 seconds: Switch ignition ON. Within 4 seconds: Press lock or unlock button. System should now lock or unlock vehicle. Within 8 seconds: Press lock or unlock button of first remote control. System should now lock or unlock vehicle. Press lock or unlock button of second remote control. System should now lock or unlock vehicle. Press lock or unlock button of third remote control. System should now lock or unlock vehicle. Switch ignition OFF. Remove key. Check operation of all programmed remote controls.
NOTE: If less than 3 remote controls are to be programmed, remove ignition key after programming last remote control
NOTE THIS IS FOR YEAR 99-02
Mar 02, 2010 | 2002 Honda CR-V
How to recode remote to vahicle
Programming
When
How
NOTE: If less than 3 remote controls are to be programmed, remove ignition key after programming last remote control.
Jan 18, 2010 | 2003 Honda Civic
Whirlpool Duet GHW9150P Front Load Washer Logo
29 people viewed this question
Dan Webster
Dan Webster
Sal De
